Author Topic: Vacutherm iDry input  (Read 27068 times)
Offline Glenn1
  • Drying lumber one board at a time
    • GPS Hardwoods
Re: Vacutherm iDry input
« Reply #220 on: January 05, 2019, 07:38:59 AM »
We use 2” ratchet straps every 3’ to put some pressure on the top boards.  It seems to work well and does not take up any extra room.
Vacutherm IDry, Nyle 53 Kiln, New Holland Skid Steer, Kaufman Gooseneck Trailer, Whitney 32A Planer
Offline Glenn1
    • GPS Hardwoods
« Reply #221 on: January 05, 2019, 09:09:42 PM »
We opened the kiln today and the quartersawn sycamore was ready.  The boards are spectacular! They range from 6” to 15” wide.  These were some really wide logs.
We cut the boards at 1 1/4” thickness.  Going with the theory that the IDry can dry 1” per week, we thought that it would take 9 days to dry from green.  Sycamore initially has more than 100% moisture in the log so that will also affect the drying time.  This load took 13 day to get it to 8% Mc.  I am very pleased with the results.
Offline PA_Walnut
« Reply #222 on: January 06, 2019, 08:47:40 AM »
Why no other controls than a big "GO" button?  PCS vac kiln has a control that looks like a NASA command center. What are we missing here?
Calling @GeneWengert-WoodDoc  Calling @Den Socling
LT40HD Wide 35HP Diesel
Kubota M62 Tractor/Backhoe
WoodMizer KD250 Kiln
Northland 800 Kiln
Offline Just Right
    • JustRightSawing
« Reply #223 on: January 06, 2019, 10:01:12 PM »
Looking good Glenn and Busy. .. . . so maybe a silly question,  if you are going to be putting sawed lumber in the kiln quickly . . . . do you still anchor seal?
If you are enjoying what you are doing,  is it still work?
Offline Glenn1
    • GPS Hardwoods
« Reply #224 on: January 07, 2019, 06:57:16 AM »
Yes I do.  I would rather be safe
Offline Just Right
    • JustRightSawing
« Reply #225 on: January 07, 2019, 12:31:38 PM »
Thanks Glenn.  I was just wondering with how the wood dries in this kiln did the anchor seal impede it any.  I did notice that you had your kiln on a gravel flood.  What do you have the kiln sitting on to level it?  JR
Offline Glenn1
    • GPS Hardwoods
« Reply #226 on: January 07, 2019, 06:18:41 PM »
The kiln is actually on crushed concrete.  We rented a 3 ton double roller system and packed it down with a little sprayed water.  Then we added 6x6 for the kiln to rest on.  We were able to shim it just barely to have the water run to the back right corner of the kiln.  I don't believe that the crushed concrete is going to move.
The anchor seal dissipates with heat so it is basically gone by the time that the wood is dry.  No mess, no residue.
Offline ellmoe
« Reply #227 on: January 08, 2019, 06:48:32 AM »
   Just received notice that my kiln is scheduled to be completed on Monday. This is three + weeks ahead of schedule . Now I have to hurry to make a home for it.  ;D
Offline Stephen1
    • muskoka Sawmill
« Reply #228 on: January 08, 2019, 09:23:39 AM »
Thats great. Mine is scheduled for completion March 11. I am on vacation till March 8. I  will have its home all ready before I go. I am starting to paint my shop this week
Offline jfric
« Reply #229 on: January 10, 2019, 10:04:49 AM »
Exciting to hear of everyone’s results so far. I’m expecting delivery of mine on Monday. I’ll probably start milling some 8/4 pecan tomorrow for my first load.
iDRY vacuum kiln, Nyle L200m kiln, Woodmizer LT15-Wide, Bobcat S300, Stihl MS880, 36" and 60" Granberg Alaskan Mills, Ford F550 flatbed.
Offline farmfromkansas
« Reply #230 on: January 11, 2019, 06:19:20 PM »
Watched the Canadianwoodworkers kiln video, and noticed they are using no stickers.  But the pics using this vacutherm IDry is using stickers.  Can someone explain?
Offline canadianwoodworks
« Reply #231 on: January 12, 2019, 09:02:10 AM »
I'm not an owner of an Idry but I have done my research, I do run a Vacuum kiln going on 2 years.
These are types of Vacuum kilns:
Discontinuous - Wood is stickered, heated with air. Then a vacuum is drawn the wood dries and cools, then the vacuum is released, the wood gets heated again with air, then repeat.
Hot Plate - Wood is NOT stickered with heating plates filled with hot water between each layer, a vacuum is drawn and is held until the wood is dry. The vacuum and heat is a constant, no cycling from no vacuum to vacuum. So this is faster and better quality then discontinuous.
High temp steam - I don't know much about this type.
RF - Wood is NOT stickered with a thin .050'' plate between each 12'' of lumber, this provides heat by high frequency. Think microwave, but not exactly the same. The electricity is not floating around in the chamber heating the wood, the electrical signal travels from one plate to the other in a direct path.
The Idry and Idry plus seem to be different then a discontinuous, it sounds like a vacuum is held the entire time, but leaving enough air in the chamber to heat the wood. This is why the wood needs to be stickered, because they are using air being blown through the stack to give the lumber the needed heat.
Once a vacuum is pulled, you can't heat the wood with air because there is no air left in the chamber. This is why hot plate / super heated steam / RF kilns exist. Once the wood starts drying, the energy used to convert liquid water into vapour leaves the wood in the vapour, so we need to continually add heat to the lumber. Most Vac Kilns pull such a strong vac that there is no air in the chamber to heat the wood.  Vacutherm has created a "new" type of vac kiln which pulls a "weaker" vacuum leaving enough air inside the chamber to give heat to the lumber, while drying under vacuum conditions.
My interest is peaked!
Offline Glenn1
    • GPS Hardwoods
« Reply #232 on: January 12, 2019, 06:58:04 PM »
Canadianwoodworks, your post seems to be right on the mark....well done
Offline Busysawyer
« Reply #233 on: January 12, 2019, 09:20:18 PM »
After a very pleasant and informative conversation I had with Mr. Parker I need to clarify a couple things. First of all I was dead wrong about a major feature of the idry.  We as end users do have control over some key functions of the kiln if we desire.  I made a huge assumption based on a lock icon on the setup screen. I saw the little padlock icon on the bottom left hand corner and assumed these key functions were locked . I was wrong.
You can slow down the drying by limiting vaccum and max temp. Both are adjustable by the end user. I believe the fan settings can be adjusted as well but I didnt clarify or try to change those yet. Mr.Parker said you could essentially use the kiln as what he would consider a pre drier for those species that need to be dried slowly. He reccomend partially air drying as a more efficient and economic option but said the idry could be used. Pushing start is a great way to go but knowing I can "play" with the settings is going to make this toy more fun to play with. Sorry to all for making an erroneous assumption and spreading misinformation.
Offline Busysawyer
« Reply #234 on: January 12, 2019, 09:23:47 PM »
Here is a pic of the setup screen where you can input what temp and pressure you want. That lock in the bottom left corner is what led to my assumption of not being able to change these settings.
Offline briankingsbury
« Reply #235 on: January 23, 2019, 10:33:27 AM »
The settings for Temperature and Vacuum are not locked, you can change then anytime. The lock is to setup remote access connection. This setup is usually done before shipping but if it ever needs to change it can be.
Offline Stephen1
    • muskoka Sawmill
« Reply #236 on: January 23, 2019, 01:44:21 PM »
Is the remote access for IDRY, or is that for the owner?
Can we change anything from a remote location?
« Reply #237 on: January 23, 2019, 02:09:36 PM »
The remote access is for the owner and from any location using the internet you can see, run, and change anything.
Offline Stephen1
    • muskoka Sawmill
« Reply #238 on: January 23, 2019, 02:12:54 PM »
When we are drying pine, what temperature do we need to set the pitch?
Offline ellmoe
« Reply #239 on: January 26, 2019, 06:30:29 AM »
Received my kiln yesterday , three weeks early ! Unfortunately , I've had to change its future location , so I have to find time to do some construction. Hope to get this completed soon , we have a lot of thick wood to dry.
New iDRY
Started by boonesyard on Drying and Processing
Last post December 04, 2019, 10:05:02 AM
by boonesyard
Idry vacuum kiln reviews
Started by Walnut Beast on Drying and Processing
Last post March 31, 2020, 07:31:46 AM
by DWyatt
Please welcome our newest sponsor! iDRY Vaccum kilns
Last post December 02, 2018, 08:04:14 AM
by fishpharmer
Looking for some input
Started by summerboy1958 on Chainsaws
Last post June 26, 2015, 09:12:01 PM
by Ianab
