Author Topic: Timing of harvest  (Read 602 times)
Offline loggerman1959
Timing of harvest
« on: August 20, 2018, 12:31:00 PM »
Is it truethere are some trees that should be harvested in winter only ? I've heard people talk about it but I am not sure . If so , which , and why ????Thanks in advance
Online Ianab
Re: Timing of harvest
« Reply #1 on: August 20, 2018, 01:24:44 PM »
There are a couple of reasons you might harvest in winter. First is ground conditions and access. Some areas it's just more practical to get in and harvest when the ground is frozen, rather than fighting through mud and bogs. The other is to do with log storage and drying conditions. Logs degrade slower and lumber air dries better if it's cold.
But if you can work around these problems there is no reason you can't harvest all year round. More harvesting would be done locally in summer because winter is more mud and rain. Then logs are sprayed with a stain reducer, milled promptly and kiln dried to reduce degrade.
The actual wood properties don't change, but the weather / season can certainly affect harvesting.
Offline Southside
    • White Oak Meadows
« Reply #2 on: August 20, 2018, 01:53:49 PM »
Around these parts winter harvested pine will keep a lot longer before it stains and spring harvested poplar will loose it's bark like a banana, so there are some potential considerations.
White Oak Meadows
Offline mike_belben
  • Pulp Friction
« Reply #3 on: August 20, 2018, 09:16:00 PM »
I can get up to 70 cents a ft for export poplar thats winter cut but only 40 cents summer.  Theres too much water in summer cut.  I dont know if they blow apart in the container from drying too fast or if its mold, but thats the story i got.
Revelation 3:20
question
Timing
Started by gizmodust on Forestry and Logging
Last post December 15, 2006, 11:02:12 AM
by gizmodust
Timber Framing Timing
Started by scshaw on Timber Framing/Log construction
Last post February 11, 2015, 11:24:59 AM
by vtframer
Injection pump timing
Started by tacks Y on Forestry and Logging
Last post February 05, 2016, 01:00:00 PM
by mad murdock
Timing on White Pine
Started by True North on Sawmills and Milling
Last post April 13, 2010, 10:20:43 AM
by Doug_D
