Dynamic Green Products Inc.
Author Topic: New LT15 blade rising during cut?  (Read 2709 times)
Offline Leigh Family Farm
  • Live life the way you want. You only get one.
    • Isagenix
« on: August 22, 2018, 05:05:50 PM »
A co-worker of mine just bought a brand new LT15 and sawed their very first log over the weekend. As he explained it to me, the saw blade rose about 1/8 - 1/4" during the cut. As the blade left the log, it would drop back down to the original cut depth but the saw head never moved. He had the blade tension to specifications (in the green) and he tried with more tension (orange/red). Still had the same problem. Any ideas as to the cause of the problem?
The log was a 18-20" 5 ft. ash that was freshly cut down the weeks prior.
There are no problems; only solutions we haven't found yet.
Offline WDH
  • April 1998 - August 2008
    • hamsleyhardwood.com
Re: New LT15 blade rising during cut?
« Reply #1 on: August 22, 2018, 08:06:41 PM »
Sounds like the blade is dull, maybe from hitting something in the log like rocks in the bark, dirt, or metal.  Try a new blade and see how that cuts.
Offline bandmiller2
« Reply #2 on: August 22, 2018, 09:07:27 PM »
Sounds like the band is riding too far back on the belted wheels and its pressing the set out on the inside teeth. Frank C.
Offline Brad_bb
« Reply #3 on: August 22, 2018, 09:31:33 PM »
Possibilities:
Dull band or incorrect set (rare)
Feeding too fast.  Feed so that the RPM's of the engine don't drop significantly
Band tension setting not correct.  See Manual for correct setting.
Drive belt tension.  Get the tension checking tool from Woodmizer and follow the procedure with the tool.  It's not hard, you need to do this every 50 hours on the mill anyway.
On a side note, install and hour meter on your mill.  I think it's ridiculous that Woodmizer specs all the maintenance in hours yet do not have an hour meter on the mill!  They are pretty simple to install.  If you have the 18hp Kohler gas engine, there may be a yellow wire with female spade terminal that you can plug the +side of the hour meter into.  My 2014 has this and it's very convenient ignition on power. You will have to make a bracket to mount the hour meter.  I bought one on ebay.
Offline firefighter ontheside
  • I like trees.
« Reply #4 on: August 22, 2018, 09:39:59 PM »
Is the blade set parallel to the bed?
Woodmizer LT15
Kubota Grand L4200
Stihl 025 and MS291
2017 F350 Diesel 4WD
Kawasaki Mule 4010
Offline Lawg Dawg
  • True South Sawmill Lumber
« Reply #5 on: August 22, 2018, 10:05:58 PM »
Probably dull blade, check that first
2018  LT 40 Wide 999cc, 2019 t595 Bobcat track loader,
 John Deere 4000, 2016 F150, Husky 268, 394xp, Shindiawa 591, 2 Railroad jacks, and a comealong. Woodmaster Planer, and a Skilsaw, bunch of Phillips head screwdrivers, and a pair of pliers!
100,000 bf club member
Pro Sawyer Network
Offline Slingshot
« Reply #6 on: August 22, 2018, 11:55:13 PM »
Biggest (and maybe the only) problem is probably the ash log. They are good for that.
Offline Banjo picker
« Reply #7 on: August 23, 2018, 06:33:55 AM »
With out being there to see whats going on, I'll throw my lot in with Slingshot.  Not too long after I got my mill an ash log showed up to be cut.  It just would not turn out a usable product.  I finally took it off the mill and put it out by the fence and it layed there till it rotted.  Only log I ever gave up on. Banjo
Offline WDH
« Reply #8 on: August 23, 2018, 07:22:25 AM »
I have done that with hickory.  Just could not saw it flat no matter what.
Offline ljmathias
  • Been sawing part-time almost 27 years now
    • Polymer Science Learning Center
« Reply #9 on: August 23, 2018, 08:48:14 AM »
Yeah, good old Southern hickory. One just died on the property for no apparent reason (God knows but I sure don't) so it behooves me to cut it down and do something with it. Too hard to split for firewood so I guess I'll try quarter sawing it. Should be fascinating seeing how it twists and turns. Or maybe I'll let it dry for a while (like maybe a couple of years) so it's all locked in place and then cut it... after it's turned hard as nails and dulls the blade after the first few inches. Yeah, good old hickory, put here by the Lord to teach us patience and appreciation of what we can't change.
LJ
LT40, Long tractor with FEL and backhoe, lots of TF tools, beautiful wife of 50 years plus 4 kids, 5 grandsons AND TWO GRANDDAUGHTERS all healthy plus too many ideas and plans and not enough time and energy
Offline sawmilljoe
  • ill try sawing anything once
« Reply #10 on: August 23, 2018, 08:46:34 PM »
I had for yesterday that when I made the last cut to square it up it bowed 6 inches and made a 1/8 twist. First time I gave up on a log. Some just canít be sawed
Joe
Offline dgdrls
  • Learning the Art of Milling Logs
« Reply #11 on: August 23, 2018, 09:08:56 PM »
what are the specs on the band?
hook angle, set, tooth spacing??
could be the log, but fresh cut it should saw better than that.
D
Offline ladylake
« Reply #12 on: August 24, 2018, 04:49:21 AM »
D
 Also what brand, I've run across a couple that wouldn't even cut basswood straight.  Steve
Timberking B20 15000 hours +  Case75xt grapple + forks+8" snow bucket + dirt bucket   770 Oliver   Lots(too many) of chainsaws, Like the Echo saws and the Stihl and Husky     W5  Case loader   1  trailers  Wright sharpener     Suffolk  setter Volvo MCT125c skid loader
    • Isagenix
« Reply #13 on: August 29, 2018, 01:11:30 PM »
Sorry for the delay. Been a busy week.
Brand new blade that came with the brand new mill. I think Vortex or something. My friend mentioned its the general blade that the dealer gave him when he bought it.
I will pass on the characteristics of ash/hickory and the blade positioning on the wheels. He hsould be going back up to VT this weekend as thats where the saw is. I will update next week.
Offline Stephen1
  • Where there is a will, there is a way!
    • muskoka Sawmill
« Reply #14 on: August 29, 2018, 02:02:00 PM »
I have to use a 9 degree blade for ash or sugar maple. I would use a 4degree, but WM tells ne the 24 onan does not have the power to pull that blade.
Most ash that I am sawing  is dead and dry and makes it worse. I bet that not only did the blade drop after leaving the log but that there was waves in the board and cant left on the mill.
Offline SawyerTed
  • Summey Lumber Services, LLC
« Reply #15 on: August 29, 2018, 04:35:08 PM »
Stephen, I have 25 hp Kohler on my mill.  I've used 4 degree and 7 degree turbo blades with very good results. The only blades I used for about the first 15 thousand board feet I sawed were 4 degree.  I started trying the Turbo 7s a few weeks ago, I'm switching to them as I replace blades.
It's just a WAG but the blade rising and diving in the cut makes me suspect cutting speed is the culprit.  Too fast and waves and diving/rising start.  Same for a dull blade.  Put the two together and poor cuts are inevitable.
Woodmizer LT35HD25, WM BMS 250, WM BMT 250, Kubota MX5100, IH McCormick Farmall 140, Husqvarna 372XP, Husqvarna 455 Rancher, Ram 3500 6.7 Cummins
Online Peter Drouin
    • A&P Saw mill LLC
« Reply #16 on: August 29, 2018, 08:44:52 PM »
Cutting to slow will dull the blade in one cut too.
A&P saw Mill LLC.
License NH softwood grader.
Online Jeff
  • Fearless Leader
  • I know that I do not know.
    • THEE Forestry Forum
« Reply #17 on: August 29, 2018, 09:23:32 PM »
Rare?
Online Peter Drouin
    • A&P Saw mill LLC
« Reply #18 on: August 29, 2018, 09:45:15 PM »
Over the years I have gotten boxes of new blades that I had to set and sharpen before I could use them.
A&P saw Mill LLC.
Offline Brad_bb
« Reply #19 on: August 29, 2018, 10:16:52 PM »
Rare that the set is incorrect out of the box.  Has been rare for me.
WM LT15 - blade tension
Started by wayback40 on Sawmills and Milling
Last post May 15, 2017, 07:01:30 AM
by Chuck White
LT15 Just starting out! Get the blade on!
Started by Randy Richy on Sawmills and Milling
Last post September 06, 2016, 07:42:07 PM
by Bradm
WM LT15 Bandsaw Blade Alignment
Started by bradpjohnson on Sawmills and Milling
Last post August 23, 2020, 06:53:55 PM
by bradpjohnson
Woodmizer Lt15 blade roller heating up
Started by Woodpecker52 on Sawmills and Milling
Last post August 10, 2019, 11:36:50 AM
by Mike W
