Dynamic Green Products Inc.
Author Topic: Milling my T&G flooring and Molding  (Read 4453 times)
Offline Coffee_Creek
Re: Milling my T&G flooring and Molding
« Reply #40 on: February 24, 2019, 11:07:05 AM »
finishing out the inside,
we spray foamed all exterior walls, attic was blown in with 16", interior walls we use bat for minimizing sound.
Rocked the fireplace using real rock instead of man made, the mantle is an old sweet gum (I think) cross tie that was used as a fence post in our pasture....
Had the custom cabinets built and installed.....
Offline Andries
  • Making buildings out of big curvy logs
« Reply #41 on: February 24, 2019, 11:51:38 AM »
Beautiful work CC!
You're building a beautiful home.
Question: when the exterior walls are foamed-what is used to shave the foam so that it isn't 'proud' to the framing studs?
LT30G24, LT40G25
Ford 545 Series loaders
Stihl chainsaws
« Reply #42 on: February 24, 2019, 03:20:00 PM »
The company I hired used a battery operated saws all with a long blade, the pic showing a guy on the ladder is using it, the long blackand skinny thing on his left side is the blade, I've also seen people use what looks like a big wishbone with a heated piano wire.
Offline gdaddy01
« Reply #43 on: February 24, 2019, 04:47:33 PM »
is it closed cell foam ?
« Reply #44 on: February 24, 2019, 09:11:27 PM »
I went with open cell
Offline gdaddy01
« Reply #45 on: February 27, 2019, 01:48:32 PM »
do you know the pros and cons of both ?
« Reply #46 on: February 28, 2019, 03:10:05 PM »
The company that did mine said the closed cell has a slightly higher R value but a much higher price and considering where I live, central Alabama, he recommended the open cell.
Offline doc henderson
« Reply #47 on: February 28, 2019, 03:27:02 PM »
sorry, I tried to add a comp chart.  you all can google it as well.  cost and water permeability is a big diff.  R value and structural stiffness are also a consideration
Offline DDW_OR
Multitek 1610EZ, TimberKing 2000 & Talon Sharpener,
Offline gdaddy01
« Reply #49 on: March 02, 2019, 08:40:40 PM »
thanks fellows , is the foam in the post the same type stuff used for spare in insulation ?
« Reply #50 on: March 04, 2019, 09:28:31 AM »
I'm not sure what you mean by "spare in insulation"?
Offline terrifictimbersllc
    • Terrific Timbers LLC
« Reply #51 on: March 04, 2019, 01:06:19 PM »
probably spray in, blame Siri
Offline gdaddy01
« Reply #52 on: March 04, 2019, 10:18:47 PM »
yes spray , no bodies fault but mine .
Milling flooring?
Started by mart on Sawmills and Milling
Last post November 25, 2013, 09:26:13 PM
by drobertson
Questions on milling flooring
Started by wayback40 on Sawmills and Milling
Last post July 05, 2020, 07:10:12 PM
by scsmith42
Flooring MC and milling tolerances
Started by jrdwyer on Drying and Processing
Last post March 29, 2006, 06:27:38 AM
by FeltzE
Flooring milling costs
Started by jim king on Sawmills and Milling
Last post March 23, 2008, 11:12:39 PM
by jim king
