Author Topic: Printer problem  (Read 712 times)
Offline sawguy21
Printer problem
« on: September 14, 2018, 07:19:40 PM »
I installed a Canon MX450 printer yesterday and everything seemed fine. Today the printer responds to the commands, spits out paper but no image and no error message. Any ideas on where to go from here?
Online Magicman
  • A "Traveling Man"
    • Knothole Sawmill
Re: Printer problem
« Reply #1 on: September 14, 2018, 07:50:34 PM »
Be sure that the "FINE" cartridge on the left is locked in securely.  Remove it and reinstall.  Be sure that the ink cartridge lock lever is pushed up and secure.
Offline sawguy21
Re: Printer problem
« Reply #2 on: September 14, 2018, 08:26:18 PM »
Now I get a message saying ink is low. That will do it. The machine was purchased used so no idea how much it was used.
Online Magicman
  • A "Traveling Man"
    • Knothole Sawmill
Re: Printer problem
« Reply #3 on: September 14, 2018, 09:02:46 PM »
That FINE cartridge will dry out if not used fairly regularly.
Offline sawguy21
Re: Printer problem
« Reply #4 on: September 14, 2018, 09:20:26 PM »
She said the unit had seen little use so that could well be the problem. They upgraded their system including a new printer. I would have preferred a laser but for 20 bucks I really can't go wrong except new cartridges are probably that much each.
Offline Hilltop366
Re: Printer problem
« Reply #5 on: September 14, 2018, 09:27:07 PM »
If you are using a Mac there have been issues with printing some types of files from webpages (I think it was a pdf), I have had to change the file type to jpeg to get some things to print.
I have pretty much given up on inkjet printers, I seem to have less and less patience for things that don't work properly (I may fire myself some day). I don't use them enough to keep them from drying out so I end up running the clean cycle a bunch of times and run out of ink by the time I get it to work.
At work I got a black ink only laser printer it is way faster and has always worked so far. I almost got a colour laser printer for home until I looked up the price for the replacement cartridges, almost $500!!
If it ends up being a clogged nozzle there are videos on youtube on cleaning them.
Offline lxskllr
  • dummy with saw
Re: Printer problem
« Reply #6 on: September 15, 2018, 01:19:36 AM »
+1 on the laser printer. They work great on everything but photos. For those, I'd just take them to a printer, or better yet, view them on a screen. Takes up less physical space.
Offline sawguy21
Re: Printer problem
« Reply #7 on: September 22, 2018, 10:27:16 PM »
I installed new cartridges today, machine works as advertised. I paid $20 for the machine on a local buy and sell, the cartridges set me back $81!!! I could have bought a machine new for less than that but it is what it is. I hope they last for a while.
Offline lxskllr
  • dummy with saw
Re: Printer problem
« Reply #8 on: September 23, 2018, 10:30:01 AM »
If it makes you feel any better, a lot of printers only come with "starter" cartridges, so you aren't getting a full loadout of ink. Comparing ink cost to a new printers usually isn't a direct comparison.
Offline sawguy21
Re: Printer problem
« Reply #9 on: September 23, 2018, 12:38:34 PM »
Interesting, I didn't know that. I probably got the originals with it.
printer
Started by Peter Drouin on Technical Support Topics
Last post March 15, 2019, 07:18:30 AM
by Peter Drouin
INk jet or laser printer
Started by D._Frederick on General Board
Last post November 16, 2010, 03:31:25 AM
by SwampDonkey
New printer today
Started by jim king on General Board
Last post June 25, 2011, 10:09:21 AM
by jim king
Printer Ink cartridges
Last post November 11, 2010, 01:58:49 PM
by cpstrutt
