Hi everyone I’m a newbie to the forum and framing....As far as interchangeable pieces Richard totally disagrees that reliable pieces cannot be fabricated using the scribe rule. Trial assembly of the bents is done on the ground but is this not true for square rule framed structures also?Thanks in advance for your comments, advice, and insight.Best regards, Tony
From my understanding, when using square rule - if done properly, trial assembly should not be required.Thats the whole point, to do all the joinery generically so you don't have to mate up individual piece to each other.Then on raising day it all fits together on site perfectly, the first time, with no problems. Gulp Greg
Started by nicdonati on Timber Framing/Log construction
Started by FrankLad on Timber Framing/Log construction
Started by Tony_T on Timber Framing/Log construction
Started by JimXJ2000 on Timber Framing/Log construction
