Stumped?
Started by Bibbyman, April 23, 2002, 07:10:51 PM
Bibbyman
Twenty years ago dad could tell you who cut a tree in our area buy looking at the stump as each person tends to have their own style.  (The reason he can't today is because most of his contemporaries have stopped making stumps long ago.)
The white oak stave timber was recently cut from my cousins' farm next to ours this spring.  I took my camera on a recent mushroom hunt and took some pictures.  Each stump tells a story about the how the tree was felled.  :P
Here's a typical stump from this crop.  What do you see? :o
View from the other side.
Stump with others.
Sawing since '94
Paul_H
WOW,  :o There is no visible hinge wood,cuts don't meet,and it looks like they couldn't decide where and what they wanted the tree to do.It looks like all the rest were cut off as well.A Beaver with a saw maybe. ;)
Kevin
What I see is inexperience and an accident waiting to happen.
That`s a classic dutchman.
Bud Man
Pinched Blade had to be cut out ?
The groves were God's first temples.. " A Forest Hymn"  by.. William Cullen Bryant
Tillaway
Those are better than ones I was looking at earlier this year.  One of the landowners was doing some "recreational" falling.  He should have got himself killed.  I almost took the camera, they were unbelievable.  He probably went back to the city and told all his friends how good of a faller he is. ::)
btw... Mexican crews cut like that, I've seen them do it in the Redwoods. :o  They are across the border one day then someone hands them a saw and tells them to go cut down trees the next..
Making Tillamook Bay safe for bait; one salmon at a time.
You're right, Tillaway. This is the "work" of a totally inexperienced faller.  Looks like something I would have done, years ago. I'd never laid my hands on a chainsaw till I bought a Mc-Cough-a-lot and went to the woods with it. :o Some of my stumps looked even worse than these. It's a miracle I didn't kill myself, but I eventually learned, on my own. Never had ANYBODY give me any pointers, till I joined the ForestryForum. This is a GREAT subject to be talking about. This thread could be saving someone's life, even as we type!  :P
Bibbyman
One thing that's hard to see from the pictures is how out of square he is cutting the butt of the log.  The two cuts slope in opposite directions as if he's too lazy to bend over to hold his saw level. After looking at hundreds of stumps on the job,  virtually all were cut the same.
Looks like he judges the direction of lean and does not attempt to direct or control it.  Note the aborted cut lower down on the stump – this says he changed his mind and moved up for another guess.   ::)
Looks like he saws until the middle or until the gap starts to close.  Then he cuts a notch opening – not that it's going to do him any good with the almost horizontal cut so deep.  Then he thought he should notch it some more and cuts it a little deeper the second time.
Then he cuts like hell from the backside and hopes it does not split up on him.  Note the splinter and break on the second photo and the break across the face of the stump.  He's sawing until the tree leaves the stump rather than making his exit. 8)
As a result,  he fell a tree out of control and put himself in more danger than necessary.  He also produced a log out of square and with a crack in the butt that,  if it's not showing now,  will by the time the board is dried. >:(
This one must have went down fighting! Note too the lower cut that was for what?
Here you can see all the fracture and the pulled splinters.
Sawing since '94
Ron Scott
Obviously not an experienced sawyer. They wouldn't last long on a veneer log job or any of mine until sent out for training.
Our "good looking" stumps are part of the immediate landscape and must be "visually pleasing". 12" or less in height for sawlogs and 8" or less in height for pulpwod and square across, no splinters or "white wood" left hanging or splintered.
~Ron
Frank_Pender
If OSH A  "saw" that around here someone rear end wouyld be in a "sling" for sure.   There would be a fine for each stump looking like those in the photos.  ??? They would be off the job and in debt for years. :'(
Tillaway
I have seen that inexperienced people make sloping back cuts because they believe it will somehow force the tree in the intended direction eliminating any need for wedges. (I have had some bozo tell me this.)  You can see how in the first pictures the cutter "beavered" the face out.  A clear sign of someone with little saw experience.  They can't get their face cuts to even come close to matching up.  I really doubt the cutter here even carried wedges or knew what they are for.  Did the mill accept the logs is what I want to know.  And if so did the square the butts before bucking?  If they didn't, how did they make the trim requirements?
Bibbyman
Old stumps tell a story too.  Dad would point out old stumps and note ones that were hollowed out.  They may not have been hollow when they were cut but had bad centers.  Most of this was caused by deliberately burning the forest off each year – a common practice up until after WWII.  One old hollow stump may not be enough evidence but if you seen many in one area,  the chances of finding scars and brown rot in live trees as well.
This stump was about 20 yards from the old hollow stump.  Note the scar left of center and the brown rot.  Note too the butted off butt chunk to the right.
In this case,  I say the farm was heavily cut over 75 to 100 years ago and what was left burned in an attempt to create pasture.
Sawing since '94
Kevin
Anyone see the open face notch on the cover of Sawmill & Woodlot?
I prefer to make the cut using a hinge with the face cut a little different.
That cut is usually made on a tree that is on the side of a hill but he appears to be cutting on flat ground ... with no eye protection, although it appears the saw chain isn`t kicking out any chips and the saw is  probably not running.
My method ...
Cedar Eater
My "stump farm" shows that I'm still making mistakes, but hopefully not as bad as these. I have trouble getting my notch cuts to meet, but I'm getting better at it. Cedar is pretty forgiving, but I had to cuts some ash recently and that was humbling. :-[
Cedar Eater
Kevin
Eater,
I don`t know if this will help you but cut your angle face cut first then your straight cut to meet that.
It`s easier to meet the angle cut with the straight cut.
Then you can make your back cut just a little higher to get your hinge.
Tillaway
Kevin,
I was taught the exact opposite.  The first straight cut in is how you "gun" the the tree.  The slope cut that completes the cut has to match at the corners or you leave a dutchman.  Starting with the slope cut impedes your accuracy.
Start with the straight cut and use the sights on the saw or in some cases use the handlebar to aim the tree where you want it to go.  The slope cut has to meet the end of the flat cut evenly all the way across.  This way you accuracy is greatly improved.  You also have to leave a hinge of holding wood that is equally thick all the way across the stump or the tree will pull towards the thicker side.
Paul_H
I'm in agreement with Tillaway.Start horizontal cut for depth,and aim.Bring slope cut (undercut) up to meet.Back cut in level,mindfull of hinge wood.We always take the undercut from the stump,and have a flush cut log.
In the days of axes and misery whips,it was practical to take the undercut from the tree.It was easier to make the horizontal cut with the saw,then chop in and down with the axe for the undercut.
Kevin
Evidently we had different instructors.
I haven`t seen anything documented but I`ll have a look at the books tomorrow.
I distinctly remember my instructor telling us to make the angle cut first on the conventional(common) or humbolt face cut.
It seems easier to meet the angle cut with a straight cut than visa versa.
Anyone have a reference or rule for this?
Tillaway
That would have gotten me knocked upside the head
... try Pratical Timber Falling by D. Douglas Dent.
That first cut is crutial to setting the depth of the face and direction of tree.  Everything matches up to that cut.  Starting with the undercut is easier, but much harder to get an accurate tree placement.  I haven't ever seen any fallers anywhere on the west coast that start with the undercut first.
Kevin
Till,
If the angle cut is into the tree one third of the tree and meets the horizontal cut forming a good notch on the face of the tree what difference does it make?
Is there a specific mechanical reason for making your first cut the horizontal cut other than proper depth because I`m not having any trouble setting the depth of cut by cutting the angle cut first.
Is there really a right and wrong to this or is it merely preference?
OSHA doesn`t mention the cutting sequence for the conventional or humbolt notch but they do explain the the open face notch in great detail although they don`t leave a hinge on it according to their illustration.
Tillaway
Kevin,
It is pretty much a black and white issue out here.  Horizontal is always first.  If you uses the sights on the saw to "gun" tree you will be more accurate.  The sights on the saw are used on the horizontal cut.  You start your cut into the tree in the direction you want the tree to go.  Part of finishing your cut is lining the saw sights up with your intended target.  This is very important out here because putting the top 10 feet one way or the other is sometimes critical to saving the log.
Starting with the slope cut makes the sights unusable therefore your accuracy suffers.  If you go ahead and gun the tree after making the slope cut first you usually end up cutting too deep to make the correctional adjustment.  This can be a problem if you are trying to wedge the tree.  You may not have enough width in your back cut to start a wedge and leave acceptable holding wood.
Something else that is done out here is that a humboldt cut is used by 99.9% of the pro fallers.  This is done for log scaling purposes and has one safety advantage if executed correctly.  That is the "stump shot" is better able to protect you from the log sliding back across the stump.  The coventional cut has less ability to catch on the stump shot to protect you.
I guess all in all greater accuracy equals greater safety.
You guys keep this up. I'm finding answers to questions I hadn't even thought of yet. :P   I was thinking I was a self-taught felling feller, but it looks like I wuz just self-confused. :-/
Till, can you elaborate a little more on the "saw sights" thing?  I kinda think I'm getting your drift, but some more detail may save me a skint place on the brain stem, or some other unpleasantry. :o
Tillaway
DanG... There are actually sights on the chain cover and flywheel cover of professional saws.  They are two raised ridges that are designed to be line op just like rifle sights.  These sights are 90 degrees to the bar.  You cut in... and get down on your knees... and look down the sights just like a rifle (gunning).  That is where your face cut (undercut) is aimed.  Some saws may not have them so use the handle bar.  The handle bar is often (but not always) roughly 90 degrees (perpendicular) to the bar.
Kevin
Stihl is using the method I described in their safety PDF manual ...
http://www.stihlusa.com/manuals/chainsaw_safety_english.pdf
page 19
Ron Scott
An excellent discussion from those with expierience. This subject would make a good video on the Forum.
~Ron
Tillaway
You are right Kevin, the printed instructions say to do this but if you look at the illustration, it demonstrates gunning.  Either the illustrator drew it wrong or the technical writer made a mistake.  The illustration (on the left) is bang on what I was taught.  It almost looks to me that Stihl needs to do a better job editting this manual.  Page 19 for those who wish to look.
