Author Topic: Ratchet straps on lumber stacks  (Read 2054 times)
Offline D6c
« on: November 08, 2018, 07:35:24 PM »
I like using ratchet straps to bind stack drying lumber...you can periodically tighten them up as the lumber shrinks.
Gets a little expensive though.  You can get straps without hooks but one end is fixed to the ratchet.
What I'd like to find is the ratchet alone and buy rolls of webbing that I can cut to length and run both ends through the winder and tighten it up.
Anyone seen something like that?
Offline ely
Re: Ratchet straps on lumber stacks
« Reply #1 on: November 08, 2018, 08:10:44 PM »
I have not seen that before, and I also have never used straps on lumber aside from hauling it.
Offline Southside
    • White Oak Meadows
« Reply #2 on: November 08, 2018, 08:36:05 PM »
Poly / cloth binding systems like the ones made by Kubinec work well and you can re-tighten the material as the stack shrinks, just leave a long tail end so you have enough to get the ratchet tool back on. You can even re-use the material and the spring clips.  It is a very affordable alternative to ratchet straps and will get very tight.  I use it on our outbound packs.
Offline charles mann
« Reply #3 on: November 08, 2018, 08:58:56 PM »
Other than 5Ē ratchets on semi trailer, iv never seen just the ratchet mechanism for those 1Ē 500/1000 lb systems.
Temple, Tx
Offline firefighter ontheside
  • I like trees.
Woodmizer LT15
Kubota Grand L4200
Stihl 025 and MS291
2017 F350 Diesel 4WD
Kawasaki Mule 4010
Offline Satamax
  • Location: South eastern alps, in France but right on the italian border.
« Reply #5 on: November 09, 2018, 02:10:18 AM »
D6c, here, the other sawyers i know, use metal or cloth strapping, onto fresh stacks of roofing wood. Iike a stack of rafters, mixed with joists, purlins etc.
I think it could be interesting to use metal, and wedges to re tighten drying stacks.
Offline kelLOGg
  • More is better but enough is best
« Reply #6 on: November 09, 2018, 05:59:09 AM »
I think DC6's intent is to have a ratchet that pulls equally on both sides of the stack. I think it is a good idea. I use ratchet straps in my kiln but they pull from one side and I have to tap beat down the other side with a hammer.
Cook's MP-32, 16HP, 20' (modified w/ power feed, up/down, loader/turner)
DH kiln, CatClaw, setter, tandem trailer, log arches, tractor, thumb tacks
Offline D6c
« Reply #7 on: November 09, 2018, 07:01:23 AM »
Poly / cloth binding systems like the ones made by Kubinec work well ......
That looks like pretty good stuff and can be retightened.
Offline D6c
Offline opticsguy
« Reply #9 on: November 09, 2018, 09:30:44 AM »
I often see the big heavy duty straps on the highways, you could stop and pick those up . . . . have never seen the ratchets.
TK 1220 band mill,  1952 Ford F-2, 1925 Dodge touring, too many telescopes.
  • I like trees.
« Reply #10 on: November 09, 2018, 10:06:16 AM »
I found bigger ones too.  I think they were on etrailer.com
I searched replacement ratchet.
Woodmizer LT15
Kubota Grand L4200
Stihl 025 and MS291
Kawasaki Mule 4010
Offline KirkD
Wood-mizer LT40HD-G24 Year 1989
Offline terrifictimbersllc
    • Terrific Timbers LLC
« Reply #12 on: November 09, 2018, 12:29:07 PM »
I use ratchet straps just to keep the tin on my wood piles.
I like this place for ratchet straps.  Heavy duty, no comparison with ones I see locally.  Sometimes they have sales  too. shipperssupplies
Offline YellowHammer
  • Take Steps to Save Steps
    • Hobby Hardwood Alabama
« Reply #13 on: November 09, 2018, 10:54:34 PM »
We use the Kubinec for just that purpose.  Every load that gets stickered gets two straps, and I have dropped a full pack of boards on itís side and flipped it over and picked it up again with a forklift.
There are some decent videos of Kubinec on the web.
The normal banding ratchet tighteners used for poly straping tighten the material banjo tight, and as long as the Kubinec isnít run through the cutter, the ratchet tightener is easily removed and the Kubinec isnít cut short every time times it is used.  Itís also nice that it can be tightened pretty snug by a little hand leverage or anything else handy like a crobaw or screwdriver.
The material survives well through kiln cycles, and the little spring tensioners are removed and reused as well as the banding.
You can overtighten strapping in stickered, green wood and impart waves so too much tension is not good.
We transport all our wood using over the road using road legal poly ďgreenĒ lumber strapping.  The Kubinec stays at our yard so we can reuse it.
Itís really handy if there are a dozen or more stacks to band, each person wraps their packs and sets the springs hand tight all in parrallel and one person just follows up and banjos them with the one tensioner.  Very fast.
HobbyHardwoodAlabama.com
Offline Brad_bb
« Reply #14 on: November 09, 2018, 11:02:03 PM »
If your intention is long term drying outside with strapping, the problem is the sun attacks the strapping whether it's kubenic or Ratchet Strap strapping.  It fades the strapping, weakening the strapping.  It's great for storing inside, and for transporting.... but long term outside it will degrade.
Offline Brucer
« Reply #15 on: November 11, 2018, 02:18:00 AM »
I used the Kubinec strapping to bundle my slabs for firewood. Same system Southside Logger recommends. I left a bit of extra strap on one side of the buckle so I could tighten them up as they dried. The customers could then put their own ratchet straps around the bundles every 16" or so and buck the whole bundle up into 16" lengths (or whatever).
A lot of my customers would return the straps and buckles and I'd re-use them. They faded in the sun and got a bit stiff where they wrapped around the buckle, but they never got weak enough to break. I'd get three or four years out of a strap before I had to scrap it (and that was often because someone nicked it with a chainsaw :D).
If you're going to use their ratchet tightener, you don't need to get the straps too tight because it's easy to slip it back in and take up more slack as needed. The hand tool works just as well, but needs a longer "tail" to retighten.
Bruce    LT40HDG28 bandsaw with two 6' extensions.
Offline Satamax
« Reply #16 on: November 11, 2018, 04:14:43 AM »
What i was talking about, above as "cloth strapping" is Kubinec.
Offline D6c
« Reply #17 on: November 11, 2018, 06:24:55 AM »
Is 1" kubinec the size to get for lumber stacks?
Do you buy it direct from kubinec or through supply houses?
Looks like the rolls have a 3" center hole so they won't fit my strapping cart that's set up for standard poly rolls that have about a 16" center hole.
Offline Brad_bb
« Reply #18 on: November 11, 2018, 09:54:34 AM »
I use 3/4 Kubenic- for beams.
Best Ratchet Straps for Timber Framing
Started by jb9 on Timber Framing/Log construction
Last post February 12, 2018, 12:01:07 PM
by jb9
ratchet strapping a whack of lumber
Started by rweiss1110 on Drying and Processing
Last post April 05, 2020, 03:51:08 PM
by busenitzcww
Wasps in your air dry lumber stacks
Started by WV Sawmiller on Drying and Processing
Last post June 28, 2018, 09:00:01 AM
by WV Sawmiller
Weighting lumber stacks.
Started by Dave Shepard on Drying and Processing
Last post February 04, 2008, 10:28:45 AM
by Dave Shepard
