Maxi-load Scales or Scales on Truck
Started by supermslogger, November 25, 2018, 02:51:54 PM
supermslogger
Do you use Maxi-load scales or do you have scales on your trucks? Looking at options for dealing with overweights.
barbender
Most trucks up here have an air guage in the cab, for the trucks suspension, and one on the trailer for the trailer suspension. It's not a direct read out, but you can figure out how much weight you have on by the numbers on the guages. Obviously it only works with rigs that have air ride suspension.
Skeans1
We use Vulcan 700 remote with 300 series scales here on our personal trucks so I can watch from the shovel.
Riwaka
Depends where you are and what configurations you use your truck in. Is there a preferred well supported on-board scale in your area?
On-board scales preferably, check with your log trailer designer/ builder/ certifiers. No point in putting on the on-board weigh scales on the  trailer; if the log trailer will not be certified at the end.
relocatable on the ground scales can get stolen or otherwise damaged.
vulcan scales     (other onboard  log trailer scales can use blue-tooth to send the load data to other displays in the loading area)
Vulcan On-Board Scales Corporate Video - YouTube
