Dynamic Green Products Inc.
Author Topic: winter  (Read 714 times)
Offline trapper
winter
« on: December 11, 2018, 10:53:15 PM »
changed my cm 241 and cm261 to winter mode today easiest saws I have ever done Just looking at them without looking at the manual it was easy to see what to do.  Also went to winter bar oil.
Offline sawguy21
Re: winter
« Reply #1 on: December 11, 2018, 10:56:02 PM »
It is a very simple procedure, kudos to Stihl. We are not selling winter bar oil yet, daytime temps are around 40F.
Offline upnut
  • Wood Tick
Re: winter
« Reply #2 on: December 12, 2018, 08:43:17 AM »
Thanks for the tip, didn't even know there was a winter setting! My winter strategy is setting the saw on a shelf and my feet by the fire.....I do run a couple tanks of Stihl Moto-Mix through it occasionally when my siblings need help feeding their wood stoves. I generally use their saws, but the 241 really has me spoiled.
Scott B.
I did not fall, there was a GRAVITY SURGE!
Offline petefrom bearswamp
  • 70-13 still feel OK and am retired
Re: winter
« Reply #3 on: December 12, 2018, 08:49:38 AM »
Scott my winter procedure is pretty much the same as yours.
If we have an old fashioned January thaw I may get into the woods to augment 2019-2020 supply
Kubota 900 RTV
Polaris 570 Sportsman ATV
1 Husky 1 gas Echo 1 cordless Echo vintage Homelite super xl12
241 acres of woodland
Offline lxskllr
  • dummy with saw
Re: winter
« Reply #4 on: December 12, 2018, 10:44:26 AM »
Winter's when I do my cutting. 30-40 is perfect cutting weather. I never used the winter setting on my saw though. It's not like Canada down here. Seems to run fine without it.
Offline hedgerow
Re: winter
« Reply #5 on: December 12, 2018, 12:13:38 PM »
We finished up running chain saws right before corn and bean harvest. Wet weather set in around here early and it took a lot longer to get harvest done than it usually does. Snow came then and the thought of go to the timber and running chain saws left my mind. Sounds like we have some nice weather coming the next ten days may get the saws running again in the mornings when its froze up.
Winter
Started by Texas Ranger on General Board
Last post February 03, 2004, 05:00:44 PM
by redpowerd
Winter bar oil?
Started by Log Hogger on Chainsaws
Last post December 19, 2009, 08:21:10 PM
by sd locke
Winter is Here in Da U.P.
Started by Pudge on General Board
Last post September 08, 2010, 04:17:38 AM
by SwampDonkey
Winter bar oil mix
Started by Weekend_Sawyer on Chainsaws
Last post January 31, 2003, 08:30:23 AM
by jokers
