Author Topic: what bearing grease to pack cast wheels in kiln?  (Read 287 times)
Offline jimbarry
    • WoodchuckCanuck
« on: December 19, 2018, 12:57:11 PM »
I have Nyle's cast iron wheels for the kiln carts. Any recommendations on a type grease to use? Does it matter? I assume the one requirement is being able to withstand temp when heat treating.
Jim
WoodchuckCanuck.com ? Livin' the rural life in Nova Scotia.
2017 Nyle L200
8ft x 10 ft x 20ft bldg
3.5-4" 2lb closed cell spray foam, Demilec brand HeatLok Soya Spray Polyurethane Foam Insulation
Offline K-Guy
    • http://www.nyle.com/
Re: what bearing grease to pack cast wheels in kiln?
« Reply #1 on: December 19, 2018, 01:25:51 PM »
Hi Jim
Any good quality high temperature grease (rated over 106F)
Nyle Kiln Sales & Service
"He has all the virtues I dislike and none of
 the vices I admire." -Winston Churchill
Offline YellowHammer
  • Take Steps to Save Steps
    • Hobby Hardwood Alabama
« Reply #2 on: December 19, 2018, 06:41:25 PM »
The best grease for high temperature operations is intended to be used for disk brake hubs  They get very hot and there are greases designed for that environment.  I got tubes at the local Autozone, but I dont remember the type.
HobbyHardwoodAlabama.com
Offline charles mann
« Reply #3 on: December 19, 2018, 08:48:29 PM »
don't know of any OtS grease that can withstand metallurgic heat treating. those temps are around 1400-1800F. but for use in the kiln, high temp red wheel bearing grease, sold at auto zone oriley's, tractor supply and so forth. mobile 28, royco 22cf, thixo #2 or #2 synthetic would work too, which work in temp ranges of around 250-300 for extended periods of time.
Temple, Tx
V-Belt Band wheels vs Cast and Trued w/ Crown Band Wheels
Started by Fly Fisher on Sawmills and Milling
Last post July 16, 2010, 09:32:47 PM
by redbeard
Trailer bearing grease
Started by Kindlinmaker on General Board
Last post June 11, 2018, 05:07:28 PM
by Al_Smith
Steel/ Cast bent spoke wheels, and some gears
Started by Ironwood on Wanted
Last post May 06, 2009, 09:01:57 PM
by Ironwood
Kiln wheels
Started by DeerMeadowFarm on Wanted
Last post April 20, 2015, 03:25:23 PM
by DeerMeadowFarm
