Author Topic: connecting kiln carts  (Read 231 times)
Offline farmfromkansas
« on: December 23, 2018, 07:01:50 AM »
How do you guys connect your kiln carts?  I have the track finished, and have 2- 20' carts and one 5', was considering using some straps to attach them together, should a guy use short pieces of chain, strap iron, or just weld the carts together?  Thinking my track is not probably absolutely perfectly flat, just good as i could make it, using gravel and ties. Railroad cars are not attached solid, as the tracks are not perfect.
Offline YellowHammer
  • Take Steps to Save Steps
    • Hobby Hardwood Alabama
Re: connecting kiln carts
« Reply #1 on: December 23, 2018, 08:54:08 AM »
I use 3 foot standard Auozone type tow strap and hook them together so they can spread about 6 inches apart when pulled out, but they can butt against each other when pushing in.   Definately dont make a permanent connection, is very useful to have a removable connection so you can remove to isolate carts, load or unload individually or get a little flexibility if the track flexes.  I also use a short tow strap to connect the first cart to my pull out vehicle, such as a UTV, 4 wheeler, tractor, etc.
HobbyHardwoodAlabama.com
Offline scsmith42
    • Whispering Pines Farm
« Reply #2 on: December 23, 2018, 09:36:14 AM »
I use short lengths of 1/4 galvanized chain to keep them relatively tight together.
Tom's 3638D Baker band mill
Kiln carts
Started by JHEPP08 on Drying and Processing
Last post April 24, 2015, 01:23:13 PM
by JHEPP08
Anyone use kiln carts?
Started by oakiemac on Drying and Processing
Last post July 17, 2005, 03:44:41 PM
by Den Socling
kiln carts and track
Started by farmfromkansas on Drying and Processing
Last post April 11, 2018, 08:43:16 PM
by farmfromkansas
my rolling kiln carts
Started by jimbarry on Drying and Processing
Last post April 19, 2019, 08:55:48 AM
by YellowHammer
