Author Topic: Building log cabin with green logs  (Read 5886 times)
Offline Nsp0005
« on: December 24, 2018, 11:30:59 PM »
Hello everyone, I知 about to start building a log cabin and would like some advice on what to do. I知 going to be building this with green white pine. Has anyone ever used green pine to build something like this? I have a woodmizer saw mill and I will be millling 3 sides to form a 泥 log. My plan is to get log cabin weather strip lay it right down the middle of the logs and culk each side. I then will stack with the butt and pass and apply long screws every two feet and finish by culking the outside and inside. Is this a good plan? What do you all recommend thank you all in advance.
Offline Andries
  • Making buildings out of big curvy logs
Re: Building log cabin with green logs
« Reply #1 on: December 25, 2018, 12:11:33 AM »
There will be a lot of log shrinking and checking.
- Shrinkage is dealt with a lot of "settling" room above windows, doors and interior walls. Design their frames to use dadoes for the walls to shrink down to their EMC.
- Checking is controlled by ripping a 1 1/2" kerf down the entire kength, on the bottom side of your D shaped log. The checking will localize in that kerf, leaving the log looking Purdy.
From green logs to final dry can take up to 3 to 5 years; let it happen slowly and the building will behave better than if you close the place up and crank the heat to high.
Best of luck, and pictures always are welcomed! 😆
LT30G24, LT40G25
Ford 545 Series loaders
Stihl chainsaws
Online Bruno of NH
« Reply #2 on: December 25, 2018, 07:44:27 AM »
I have built many log homes out of green white pine logs.
Do as Andries has said and you will be fine.
Use a good guality log sealant and chinking.
Lt 40 wide with 38hp gas and command controls Riehl Steel edger,F350 4x4 dump and lot of contracting tools
Offline Banjo picker
« Reply #3 on: December 25, 2018, 01:10:16 PM »
Excuse me for asking maybe a silly question, but is that kerf deep, or wide?  Banjo
Offline barbender
« Reply #4 on: December 25, 2018, 01:52:44 PM »
Deep. Just a single vertical kerf with a chainsaw. On flattened D logs, you could just as well use a circle saw.
Offline Don P
    • Calculator Index
« Reply #5 on: December 25, 2018, 06:01:29 PM »
What you're doing there, a check usually forms along the shortest path from heart to bark, you are scoring a weak line to help it form on the bottom hidden face.
One other thing I've done is to take a power planer and make a couple of passes down the center of the bottom. The flat sawn faces dry convex. By making that relief swath down through the middle of the bottom it helps the timbers bear on the outer edges rather than bearing on the bellied middles.
Offline Escavader
  • Sawmill/Planermill operator since1984
« Reply #6 on: December 25, 2018, 06:18:51 PM »
I have seen the walls shrink so much the trusses are held up by the interior partitions.its called truss lift.im not against a green cabin,ive milled alot of them at my previous company.
Alan Bickford
Hammond lumber company/Yates American A20 planer with dbl profilers Newman feed table multiple saw trimmer destacker automatic stacking machine Baker resaw MS log corner machine  4 large capacity Nyles dehumidification kilns JCB 8000 lb forklifts woodmizer lt 15 and mp100 and blower
Offline Don P
    • Calculator Index
« Reply #7 on: December 25, 2018, 09:33:00 PM »
The usual way of building for settlement is to think through anything that might hang up when the logs shrink and settle. Interior walls should be built lower than the log walls and then another top plate is attached above them to the ceiling, there is a gap between the wall top plate and the ceiling plate at least as large as the settlement allowance. Then vertical lags, timberlocks, long nails, some form of smooth dowel, is run through a loose hole in the wall plate up to the ceiling plate to hold alignment of the wall. As the log walls settle the gap closes. The upper plate is wide enough to carry a trim piece that slides over the wall finish material, so if a 2x4 wall is covered by sheetrock the ceiling plate is a 4-1/2" wide. 1/4" per foot is a typical settlement allowance for green white pine.
Window and door openings need that allowance as well
A 2 story building gets more interesting, any second floor support girders need to be supported on adjustable screw jacks, plumbing drains need slip joints, stairs, well stairs don't work, they can either slide on the floor and go out of level or slide at the upper deck and lose height at the top riser, better to build the finish set when its done settling.
The triangle up in the gable ends is much easier if framed and sided rather than trying to do in green logs.
There are more details like where the frame walls intersect the log walls, window and door bucks, etc. most has been discussed in other threads or ask if you need more. The main thing is think through every instance where the settling logs confront something that doesn't settle. Caulk is an adhesive, consider that in vertical trim.
Online firefighter ontheside
  • I like trees.
« Reply #8 on: December 26, 2018, 07:13:28 AM »
My home was built with green red pine.  My logs are natural with just the bark peeled and thejoints were scribedo the next log.  The log walls were originally 10 high and shrunk about 5 over 10 years.  I have allthread running from top to bottom.  In the basement there is a big spring and nut to tighten every so often.  That keeps the log tight as they shrink.  I had to lower interior posts every so often.  As said, you have to plan door and window openings to be able to to close up.
Woodmizer LT15
Kubota Grand L4200
Stihl 025 and MS291
2017 F350 Diesel 4WD
Kawasaki Mule 4010
Offline ppine
« Reply #9 on: December 26, 2018, 10:39:08 AM »
Building with green logs is as old as the hills.
There will be a lot of settling.  Account for it.
Forester
Offline Nsp0005
« Reply #10 on: December 26, 2018, 09:39:10 PM »
Thanks everyone for the replies! If I use screws and put lord down the middle how could expect my logs to settle? Will the entire wall shrink as one unit or will after time they space out I知 using long log screws every two feet. Also I壇 like to add the cabin will be about 1000 square feet.
  • I like trees.
« Reply #11 on: December 26, 2018, 09:56:19 PM »
I would drill about an inch hole with a paddle bit first and recess your screw in there.  That way when the log shrinks the screw will not lift up on the log above.  I would count on at least a half inch of shrinkage per foot of log height.
Woodmizer LT15
Kubota Grand L4200
Stihl 025 and MS291
Kawasaki Mule 4010
Offline Nsp0005
« Reply #12 on: December 27, 2018, 12:16:06 AM »
That sounds like a good idea! So if everyone could pitch in and tell me if I知 understanding correctly. I知 going to mill a D log I will make 1-1/2 cut down the middle I then will lay my strip and caulk on both sides drill a minimum of 1/2 inch and  recess a screw to leave room for log shrinkage.
Offline Nsp0005
« Reply #13 on: December 27, 2018, 12:17:03 AM »
I will provide a set of my plans on the morning to see what everyone thinks. Thank you all!
Offline Greyman
« Reply #14 on: December 27, 2018, 02:51:45 AM »
I'm planning on something similar (8" D logs).  We built our family cabin back in 1972 with Douglas Fir logs that were literally trees the day before.  We had to stop and go help the old timer with his big circle sawmill at times and I wouldn't be surprised if some ended up in the building the same day they were felled.  We used 10" spikes with a drilled hole in the top log (6" D logs), about every 3 feet.  Just pay attention as others have noted with things like posts, doors, windows, chimneys, etc.  We have a concrete fireplace/stove pad in the middle with steel posts so it sags down some to the walls but it's not noticeable unless you look for it.  It is on piers though, so we've been able to tweak the leveling to compensate to come degree (i.e. jack the perimeter piers up) over the years.  Everyone keeps trying to talk me into a solid concrete perimeter foundation but I like having the piers for that reason.
We didn't cut the relief or anything like that - just flat with a bit of pink insulation in between that probably doesn't do anything.   The pic below is the best one I have that shows the interior - almost all logs have a crack in the center but I don't think that is bad myself.  Hell, I just watched one of those "log home buying" shows the other day and a $380k log home had cracks like that and the realtor said it added "authentic character"...   :D
Offline snowstorm
« Reply #15 on: December 27, 2018, 06:35:06 AM »
here is my option. i built a cedar log home from a kit almost 40 yrs ago. 15 yrs ago we added on. that time i bought the cedar d shape with tongue and  groove. you need that. then 10 yrs ago i bought a repo house to flip. that was pine log. never again. after replacing some rotten logs, several. i put 2" of blue board on the inside then t&g pine. that was the cheapest way to tighten it up. if its just a camp it may be fine
  • I like trees.
« Reply #16 on: December 27, 2018, 09:32:31 AM »
Some of my logs are over 40 feet long and maybe 20 diameter at the big end.  There is almost no visible checking anywhere in the house.  That is because of the saw kerf that is run down the middle of the joint.  I would look for a foam gasket that has adhesive on one side.  Place that close to the inner edge and close to the outer edge.  When the house is done, use a caulk like Big Stretch and run a bead along the outer seams and you should not need it inside.
Woodmizer LT15
Kubota Grand L4200
Stihl 025 and MS291
Kawasaki Mule 4010
Offline Nsp0005
« Reply #17 on: December 27, 2018, 10:12:43 AM »
Thanks everyone! Would anyone know about the shrinkage in that? Like would my logs individually separate some or would the entire wall just shrink together? I really appreciate all the positive feedback! How would I go about putting my roof on if the walls shrink and windows etc.? Again thank you all!
Offline Nsp0005
« Reply #18 on: December 27, 2018, 10:13:29 AM »
I’m thinking about 1 foot logs for anyone who was wondering as well.
Offline rjwoelk
    • countrysidefirewood
« Reply #19 on: December 27, 2018, 02:46:58 PM »
I did dovetail joints also screwed the logs down. was not a good idea as the logs shrink in width they could not come together in the dovetail because of the screws and has caused some gaping, which will be closed up with chinking next summer.
Building a cabin with green lumber?
Started by GDinMaine on Sawmills and Milling
Last post July 10, 2013, 07:55:00 PM
by drobertson
Got a question on building with green logs
Started by Treeclimber on Timber Framing/Log construction
Last post October 21, 2019, 12:29:04 PM
by rjwoelk
building logs for house or cabin
Started by arojay on Forestry and Logging
Last post March 20, 2008, 04:25:48 PM
by arojay
Using green live edge beams in a lake cabin
Started by duaneb on Drying and Processing
Last post March 31, 2012, 04:14:01 PM
by D L Bahler
