Author Topic: My metal detector found some metal. Now what?  (Read 1516 times)
Offline timbercrack
« on: January 06, 2019, 11:01:34 AM »
Good morning all. Been viewing as a guest for over a year now and finally signed up. First post!
Me and my buddy went in on a 2009 Timberking 1600 last summer. Previous owner handed us his metal detector too and we have just now found two places in an ash log that indicate metal. Whats the best approach to avoiding/removing said metal before we wreck a blade?
This forum has been a wealth of info and it is appreciated beyond words. Thanks you guys...
Timberking 1600 owner.
Offline Jim_Rogers
  • Keep your chisels sharp.
    • jrsawmill.com
Re: My metal detector found some metal. Now what?
« Reply #1 on: January 06, 2019, 11:23:32 AM »
When I find a spot where I hear that beep I sweep it left and right and try to figure where the best "line" is. And then I turn 90 and sweep left and right again and develop another line. Where the two lines cross is most likely the spot.
I then take and axe can chop either side of the line and look for the grain too swirl around the metal if it is in deep. And I look for the wood color to change, as well.
Once the metal is exposed by axe or chisel I pull it out with nail pulling tools.
If it is a bolt, I clip on a pair of vice grips and turn it out.
after it is removed, whatever it is, I re-scan the log to make sure that there isn't another piece in there.
Good luck,
Jim Rogers
Offline John Bartley
  • Location: 13 Critchley Avenue, PO Box 36, Monteith Ont, P0K1P0
« Reply #2 on: January 06, 2019, 11:39:12 AM »
Sorta the same here as Jim.  I locate with a "X", then drill a hole on two sides, then use a screwdriver to pop out the metal .... or ... start excavating if it's bigger than a nail or screw.   If I can just "see" it, I'll try pulling it with a drive-in style nail puller.
Kioti DK35HSE w/loader & forks
Champion 25hp band mill, 20' bed
Stihl MS361
Stihl 026
Offline logman 219
« Reply #3 on: January 06, 2019, 05:41:31 PM »
were in indiana are you at???
Offline bandmiller2
« Reply #4 on: January 06, 2019, 08:03:07 PM »
Old wood chisels you can hammer on are handy. I find them cheap at flea markets and yard sales. Sharpen them up and keep a couple handy. Sometimes if something is large or deep I just shorten the log, too many hits and the log is rolled off into the pucker brush. Frank C.
Offline timbercrack
« Reply #5 on: January 06, 2019, 08:21:35 PM »
Jim and John, we nibbled the metal out best we could between a mix of your methods. We sawed on bravely. Saved the blade. A short nail dug out with the chisels and a bunch of nuthin at the other spot. The metal detector at least gives you a moment of pause before sinking the blade into a log. Thanks...
Offline Brad_bb
« Reply #6 on: January 07, 2019, 12:21:24 AM »
Use a cordless drill with an 1/8" when needed to drill around a nail to loosen it up.  I use the black 1/8" Ace Hardware brand bits for this.  They've proven least likely to break off of the brands I've tried.  I keep at least half a dozen bits on my tool cart as doing this you will dull the bit over time doing this.
I also sometimes  use a holesaw on the cordless drill with no pilot bit.  It takes some practice to learn how to start the hole without a pilot bit.  Usually start it on one side then slowly rotate it over.  Once you have a hole started around a nail, it's easy to keep hole sawing.  Once deep enough use a pry bar/nail puller to break the plug off and expose the nail.
You do need some old chisels (sharpened) to ramp either side of some nails to be able to get the old fashioned nail puller on it.  You also have to sharpen the old fashioned nail puller so it will grab the nail.
Offline Chuck White
  • Sawing Mobile since 2005
« Reply #7 on: January 07, 2019, 06:43:48 AM »
Welcome to the Forestry Forum, timbercrack!
~Chuck~
1995 Wood-Mizer LT40HDG25 Kohler - Cooks Cat Claw Sharpener and single-tooth setter, 4-foot Logrite cant hook.
Offline kelLOGg
« Reply #8 on: January 07, 2019, 07:15:37 AM »
If you can see the nail and don't want to gouge the wood then I did this:
Removing nails in Sawmills and Milling
Cook's MP-32, 16HP, 20' (modified w/ power feed, up/down, loader/turner)
DH kiln, CatClaw, setter, tandem trailer, log arches, tractor, thumb tacks
Offline slider
  • sawyer,trucker,tree service
« Reply #9 on: January 07, 2019, 07:33:11 AM »
I use all of the above tools. What works best for me is chisel or drill first then vice grips with a crowbar .On the large nails it work best for me.
al glenn
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
« Reply #10 on: January 07, 2019, 07:54:32 AM »
These are my "go to" extractors.  The red handled pliers with the built-in anvil is an awesome puller (from Home Depot).
Offline Sawmill Man
« Reply #11 on: January 07, 2019, 10:07:15 AM »
After a nail or screw, bolt or whatever is hit I will take a chainsaw and saw a tic tac toe pattern with the metal in the middle. Leave the middle of the pattern large enough for clawhammer claws , take the claws and pop out the center then you can get to the nail to pull it or clamp visegrips on and unscrew it. I have found this method faster and neater for me than other methods.
"I could have sworn I went over that one with the metal detector".
Offline CCCLLC
  • It's not to big, load it!
    • Carolina Custom Cut
« Reply #12 on: January 07, 2019, 01:16:54 PM »
Same procedure here as well Sawmill Man. I then tell the customer that the next board coming off would be ideal for a wall outlet.
Online terrifictimbersllc
    • Terrific Timbers LLC
« Reply #13 on: January 07, 2019, 01:27:23 PM »
I work hourly so it usually works well to put the customer to extracting the metal while I change the blade.
Offline Darrel
  • Never throw an unopened log on the burn pile.
« Reply #14 on: January 07, 2019, 04:05:42 PM »
I had a customer tell me to saw it anyway he'd gladly pay the $25 charge for metal strikes. He wanted the nail and all the associated patina in his wall.
1992 LT40HD
« Reply #15 on: January 07, 2019, 05:32:36 PM »
Exactly right, sometimes the wood is worth more than the cost of blades.  And blade cost is minor when there are 2 or 3 customer employees plus the sawyer getting paid.  Just put on a new blade and keep sawing when this is the case and has been established with the customer.
Offline Blaszer
« Reply #16 on: January 07, 2019, 06:50:47 PM »
I like to use an air chisel to dig into the log and pry it out
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
« Reply #17 on: January 07, 2019, 07:49:48 PM »
Obviously you do not saw portable.  ;D
Offline CCCLLC
« Reply #18 on: January 08, 2019, 05:41:20 PM »
Solar air chisel?
Offline Blaszer
« Reply #19 on: January 08, 2019, 08:18:06 PM »
nobody has a gas powered air compressor they can throw in the back of their truck? If I do travel, my truck toolbox is full, nurse tank on truck is full, also compressor and a saw or two
metal detector??
Started by DOVEMAN on Sawmills and Milling
Last post July 07, 2014, 10:02:59 AM
by dboyt
metal detector
Started by steve phillips on Sawmills and Milling
Last post March 04, 2012, 04:36:16 PM
by POSTON WIDEHEAD
Metal Detector
Started by campy on Sawmills and Milling
Last post March 17, 2010, 10:25:29 PM
by Ivey
question
Metal detector ???????
Started by Sawdustslinger on Sawmills and Milling
Last post September 20, 2004, 03:17:30 PM
by Bruce_A
