Author Topic: LT40 Hydraulic Microswitch  (Read 406 times)
Offline Sixacresand
  • John and Nancy
« on: January 17, 2019, 07:57:50 PM »
Just like that, the hydraulic pump would not run.  I checked everything I could do without tools.  Removed the cover from the hydraulic cavity, hot wired the sylenoid with screwdriver and the pump came to life.   Stripped a little insulation from both microswitch leads, touched and the pump fired up.  Next step, called WM and ordered a new one.  The WM tech suggested I mount a external toggle switch to activate the pump so I could run while waiting on the part.  And I did and got to finish the day.
I did a forum search on this switch problem and found good information and tips from a thread started 8 or 9 years ago.  Good deal.
Offline terrifictimbersllc
    • Terrific Timbers LLC
Re: LT40 Hydraulic Microswitch
« Reply #1 on: January 17, 2019, 08:08:46 PM »
I dont like changing that switch.
DJ Hoover, Terrific Timbers LLC,  Mystic CT Woodmizer Million Board Foot Club member. 2019 LT70 Super Wide,  Logrite fetching arch, WM BMS250 sharpener/BMT250 setter.  2001 F350 7.3L PSD 6 spd manual ZF 4x4 Crew Cab Long Bed
Offline Chuck White
  • Sawing Mobile since 2005
« Reply #2 on: January 17, 2019, 09:02:28 PM »
That microswitch is very sensitive and has a really small area of operation!
Lot of fussing to get it right, just be patient and you'll get it set right!
~Chuck~
1995 Wood-Mizer LT40HDG25 Kohler - Shingle & LapSider, Cooks Cat Claw Sharpener and single-tooth setter, 4-foot Logrite cant hook.
Offline Dave Shepard
  • Geometrically proportional
    • My homepage
« Reply #3 on: January 17, 2019, 09:32:28 PM »
I have a toggle switch in the front of thre hydraulics box, I think where the switch for the live deck goes. I unhooked it when I put the new micro switch in, but it wouldn't take more than a couple minutes to hook it back up. It could easily be left in for an emergency. Yes, the micro switch is a bit fiddly for big hands to install. I think I took the valve bank off completely. A mechanic friend once told me if something is in your way, take it off and toss it on the bench, air conditioning lines excluded, of course.  :D
Offline woodworker9
    • Elite Concrete Raising Co.
« Reply #4 on: January 18, 2019, 12:27:13 AM »
Changed mine, along with the solenoid, 2 weeks ago.  PITA.
03' LT40HD25 Kohler hydraulic w/ accuset
MS 441, MS 290, New Holland L185
Offline Sixacresand
  • John and Nancy
« Reply #5 on: January 18, 2019, 07:24:45 AM »
One tip I read on the forum was to put the bolt nuts on the switch side, which I think I will do.
Dave Shepard,  I think I will also leave the backup switch mounted.
I know this is a minor problem for most of you, but thanks to everyone for your input.
BTW, the part will probably be delivered today
LT40 Super hydraulic/LT50/LT70 DC Hydraulic pumps specs question....
Started by Percy on Sawmills and Milling
Last post August 06, 2017, 12:56:15 PM
by JB Griffin
LT40 hydraulic system Vs LT40 Super hydraulic system
Started by Dan_Shade on Sawmills and Milling
Last post June 24, 2010, 09:54:38 AM
by Bandmill Bandit
Lt40 hydraulic problem
Started by Mbreaux on Sawmills and Milling
Last post January 19, 2018, 05:41:03 PM
by slider
Max. gpm through LT40 hydraulic valves?
Started by Dave Shepard on Sawmills and Milling
Last post March 30, 2014, 07:54:58 PM
by Dave Shepard
