Author Topic: Router sled for surfacing slabs  (Read 5498 times)
Offline sam-tip
Re: Router sled for surfacing slabs
« Reply #120 on: February 27, 2019, 03:18:57 PM »
My plan is to use a 9 inch insert planner blade on the swingblade/slabber mill.  Will need to adjust the blade offset so the blade is flat.  35 hp should make quick work of the slabs.  I have a garage and barn full of slabs.  Then use the sanding pad to finish the wood off.
CB E WiFi
stumpy 395xp, 346xp Wicked 562xp
Mastermind 355t, 201CE, 3120xp 20" 36" 44" 60" 72"
Super Split Special Editions TM 24 and 30 splitter
D&L 1020 mill
Offline Crusarius
  • Lost in....
    • RockModified.com
« Reply #121 on: February 27, 2019, 04:05:40 PM »
That would definitely be pretty slick. And make short work of it. It doesn't really take all that long with my setup but could definitely be faster.
Surfacing equipment for slabs
Started by Blackhawk1 on Sawmills and Milling
Last post January 03, 2018, 02:34:56 AM
by redbeard
Router Sled
Started by 123maxbars on General Woodworking
Last post March 15, 2017, 12:33:54 PM
by Darrel
Router sled
Started by xlogger on General Woodworking
Last post September 12, 2016, 04:20:58 PM
by OffGrid973
Router sled...
Started by Hooterspfld on Sawmills and Milling
Last post May 03, 2019, 08:38:17 AM
by busenitzcww
