Author Topic: Need help with Hydro Ax 670  (Read 945 times)
Offline Chevy man
« on: February 16, 2019, 01:19:46 PM »
Need help with Hydro Ax 670. Electrical schematics. Someone has went and bypassed alot of the safety switches and now the saw head will run and work but the hydrostatic transmission wont work unless you push and hold down the manual override switch.
Offline kiko
Re: Need help with Hydro Ax 670
« Reply #1 on: February 16, 2019, 05:30:16 PM »
IIRC there are only door switches and a park brake switch.  The door switches are at the bottom of the doors.  Not sure about the parking brake switch.  All the 670 s I have seen have a manual parking brake, so the switch would have to be  located on the on the pb mechanism.  If electrical pb , it would require a pressure sensor of some sort but have not seen a hydroax with electric.
Offline Chevy man
« Reply #2 on: February 16, 2019, 05:39:19 PM »
Thanks for the reply. All the door switches are already been wired around by the genius before me. I tried the park brake switch it works correctly. I dont know of any pressure switch.
Offline kiko
« Reply #3 on: February 18, 2019, 01:57:22 AM »
I did not think the 670 had a pressure switch, and dont have any wiring diagrams for that machine.  So in general terms, there may be a switch under the steering joystick if it has joystick steer.  I am more familiar with the tigercat bunchers . Does the 670 have a pilot reset switch that must be pressed to engage all the hydraulic functions?  I have a timberking  buncher in salvage which is a hydroax with a cat engine , I will have a look at it and see if I can determine any thing, such as a latching relay.
Offline kiko
« Reply #4 on: February 18, 2019, 03:25:44 PM »
Is this the override switch you are talking about?
Also here is the sticker on the door for the relays , I think the brake relay on the left is the one to be concerned with.
Here are the relays being right side cab door.
Hydro Ax 311 C????
Started by redprospector on Forestry and Logging
Last post October 05, 2011, 03:38:56 PM
by redprospector
Lt 35 hydro
Started by rwepinetree on Sawmills and Milling
Last post July 07, 2016, 01:02:43 PM
by Weekend_Sawyer
Hydro-Axe
Started by Woodwalker on Forestry and Logging
Last post January 05, 2009, 07:07:56 AM
by Ed
hydro electric
Started by mometal77 on Alternative methods and solutions
Last post November 04, 2013, 07:26:27 AM
by WoodenHead
