Dynamic Green Products Inc.
Author Topic: Circuit breaker  (Read 550 times)
Offline revid
Circuit breaker
« on: February 16, 2019, 04:37:52 PM »
can an 10 amp
 ac circuit breaker be used in a dc setup?
Offline Southside
    • White Oak Meadows
Re: Circuit breaker
« Reply #1 on: February 16, 2019, 06:22:48 PM »
I tried that once and could not get it do what I wanted, which was serve as a switch. No idea why it didn't work.
White Oak Meadows
Offline Whitman
Re: Circuit breaker
« Reply #2 on: February 16, 2019, 07:23:59 PM »
If the dc voltage is at or over the rated and amps you are trying to break are  over the Max .It will arc over . From dealing with 135 vdc  it can get real nasty. Rich
Offline maple flats
  • Life is what you make it!
Re: Circuit breaker
« Reply #3 on: February 16, 2019, 07:28:19 PM »
No, huge difference between a DC breaker and an AC breaker. The difference is related to the fact that in DC as you break the currant it will jump a big gap, AC does not do that, because the currant flow reverses flow 60x a second in the US, 50x in some countries (60 cycle vs 50 cycle). Inside a DC breaker there is a powder that interrupts the spark as it disconnects, AC does not need that. The breaker you show is for either, it has the powder inside.
Offline revid
Re: Circuit breaker
« Reply #4 on: February 16, 2019, 08:07:09 PM »
So Maple Flatts, I can use this breaker for a 24 v system?
WM 100 amp circuit breaker upgrade with photos
Started by Jim_Rogers on Sawmills and Milling
Last post February 20, 2013, 08:18:30 PM
by Slabs
Debarker Circuit Breaker Keeps Tripping
Started by DR_Buck on Sawmills and Milling
Last post December 30, 2019, 10:04:51 PM
by Stuart Caruk
Electric throttle and 3 amp charging circuit
Started by highpockets on Sawmills and Milling
Last post March 20, 2006, 10:18:51 AM
by jpgreen
WM Power Feed Circuit Board
Started by Bodger on Sawmills and Milling
Last post April 27, 2011, 05:37:08 PM
by ladylake
