Did something dumb today.
rusticretreater and 3 Guests are viewing this topic.
caveman
Yesterday after jointing and planing oak, JohnM and I dove into replacing the water pump on my 7.3, which turned 23 years old this month.  After much consternation and gnashing of teeth, I got the new water pump intstalled, including new upper and lower hoses.  After pouring $70 of antifreeze into the resivoure, I realized that I still had a leak.  Evidently, the leak was not from the water pump, but rather, from the radiator.  This morning I called around and found a new radiator.  After an hour and a half, it was installed and the coolant that I poured in yesterday was recycled and poured back into the engine and new radiator, a test ride ensued.  Thankfully, there were no leaks.  I'm a bit agitated that I replaced a water pump unnecessarily and cross threaded one of the nine bolts when installing.  So far there are no leaks.
The radiator was a relatively easy swap.  Afterwards, I gave it a wash.  The first one in at least half a year.  Next week it will get an oil change and be ready to head to Jake's in a week and a half.
Caveman
jpassardi
End of the day yesterday, sun going down, tired and starting to get cold. I was trying to finish up and was flitching boards, someone stopped and was asking questions and I hit a side stop that was a bit too high. At least the blade wasn't brand new...
   Is flitching boards the same as edging flitches? ;)
jpassardi
Yeah, something like that  ;)
DbltreeBelgians
Quote from: caveman on April 02, 2023, 08:31:25 PM
Nah, bring the Bronco, I wanna see some of the herd ;D
I miss my Bronco. Stupid move on my part. What was I thinking  ???
Brent
Yup, I once owned a '68 and a '74.  Sometime life takes strange twists when the twisted ends don't meet.  :-X
Resonator
Some of those old square body Bronco's are currently listed for sale at $30K, 40K, 50K, or more... :o
I don't want to hear about it.   no_no
Old Greenhorn
It's been a long time since anybody has posted here. I guess folks are getting gun shy and just keeping it to themselves.  ;D
 Well I restarted the shop stove for a morning warmup and was cleaning up a bit and found this crate.
I had set that on the floor behind the stove and put a small fan on it to send warm air down near the front of the shop where I had a project curing. I guess it was a bit too close during a morning burn out stage and I never saw it. I don't worry too much about that stuff because of concrete floors and block walls around the stove. Guess I should pay more attention.... maybe.
Peter Drouin
Crossroads
Was getting ready to leave for a mobile job this morning and was a little distracted because of the weather.
Just before heading out the door, I decided I needed to move a pack of sharp blades to the other side of the garage for safety. I leaned them up against the router table and reached for something. Apparently I got to close the a blade 🤷‍♂️ and had to call the customer to reschedule while I go get stitches.
aigheadish
Got you good Crossroads! I hope it heals nicely.
Tom's milk crate reminded of something dumb I did a couple years ago on vacation...
We were road tripping around California, just me and my lovely wife. We stopped along CA-1 at a hotel, near Santa Cruz, if I'm recalling properly, for the night. The weather was a bit overcast but not too cold. We got in our room and just kind of set our stuff down along the wall, normal junk like our luggage, a backpack or two and we were just hanging out. There was a heater built into the wall, the likes of which I'd never seen, a big toaster of sorts, that had a thermostat on it. As the evening went on it got a little chilly, so I turned the thermostat up a bit so it kicked on as the room got colder, so I didn't have to wake up in the middle of the night. Kick on it did, at maybe 2am or so. I never noticed getting cold or anything but I did notice some terrible smell that woke me up. Turns out I'd tried, almost successfully, to burn the hotel down as the heater was trying real hard to set a plastic coating on one of my backpacks on fire. I guess I set it down much too close to the heater. Doesn't seem like much but that's one of the times in my life I've been most scared, for us and everyone else in the hotel.
Crossroads
It should heal good, I got in there and scrubbed it out good. Got updated on my tetanus shot. No stitches though just a blob of glue. Kinda looks like a pair of boots I repaired with shoe goo. My bandaid didn't want to stick because of the mineral oil on my hands, so I got out the supper 33 electrical tape and put a couple of wraps over the bandaid. The nurse was impressed and said she "loves the logger bandage " 👍🏻
SawyerTed
First aid?  You mean whisky and duct tape?  :D
Don P
A proper course of disinfection keeps cognition at bay.
Southside
On a positive note at least you know you have the sharpener dialed in good.  ;D
Crossroads
Lol, yeah that one was sharp.
Amazing how duct tape and electrical tape can stick to about anything, but a bandaid has to pretty much have a prepped surface to stick.
rusticretreater
I have seen electrical tape that wouldn't stick to anything. Not even itself!  If you want the skin to come off with the band-aid, duct tape is just the thing.
Kubota BX25
Homemade Log Arch
Husqvarna 562xp
Crossroads
I used to work with a crusty old electrician, he always said super 33 is the only real electrical tape.....
And he was and still is correct, 3M Scotch 33.
aigheadish
I did something dumb by not inspecting the kid's car. Bear with me a long but good story:
Prom night baby! My son, junior in high school, has prom tonight. Maybe you've read of his adventures in driving? First time he went out driving (unlicensed) we get pulled over by the cops. Two hours after he got his real license we get pulled over by the cops. Now, prom night.
He's coming to my house, from theater rehearsal, to pick up his suit. He's driving a 2007 dodge caliber. It's junk but fine for a kid, at least up until about an hour ago when I get a phone call.
He says "dad I'm in the middle of the turn onto Dayton-Farmersville (from Rt 4 a busy 2 lane road) and my axle isn't attached to my transmission, at least that's what the guy that stopped said" I told him to make sure he was standing in a safe spot and he said that the guy said he'd need a tow truck. I have a backhoe, so off I go.
It's probably about 3/4 of a mile down the way so, luckily, he was close. I arrive to find he couldn't have got to a better spot in this intersection, it's a big intersection and his car is mostly on the Dayton-Farmersville part so traffic can actually move everywhere without much trouble. There was another guy that pulled up as I was pulling up (then the cops showed up too) and he helped lookout and hook up chains (thanks good Samaritan!) and I dragged her back home. He got very lucky, he was likely doing over 50mph seconds earlier and travels on the highway pretty frequently. I'm assuming this much rust is not conducive to fixing the problem and that I'm now on the hunt for a new(er) car.
Crossroads
Oops, glad he kept it out of the ditch and was close to home
customsawyer
Am I the only one that thinks about changing the title of this to "I do something dumb every day"?
www.thecustomsawyer.com
Walnut Beast
Glad he didn't get hurt and heck yeah on the tow rig 💪
SawyerTed
Quote from: customsawyer on April 22, 2023, 06:54:06 PM
Or "Which Dumb Thing Do I Report Today?"
