Dynamic Green Products Inc.
Author Topic: New Sawmill Chainsaw  (Read 2363 times)
Offline Florida boy
  • Young sawyer with my first mill
Re: New Sawmill Chainsaw
« Reply #20 on: March 26, 2019, 10:19:39 AM »
I have z 359 husky and several smaller and bigger saws including a 372. The 359 is my best all around saw great power to weight ratio. 59 cc's are the bees nees for me...
Offline 78NHTFY
  • I'm old!
« Reply #21 on: March 26, 2019, 03:32:25 PM »
MM--good choice on the MS362!  I have the earlier version: MS361.  It's my primary logging saw w/20" bar.  So far (7 years) it has always started.  To start on the first pull (after it's been sitting), I burp it a couple of times first by pulling so it turns over.  If I forget and give it a full pull, it takes 7 full pulls to start it.  Starting on the first pull sure saves on the arm/hand strain!  All the best, Rob.
If you have time, you winÖ.
Offline LeeB
« Reply #22 on: March 27, 2019, 03:08:14 AM »
I've been mostly a husky guy but do have a 361. I find myself going for it about as often as the husky 562. I like both of them about the same. What's the difference between the 361 and the 362?
Offline JustinW_NZ
  • Just Hacking and stacking.
    • Logs2Lumber
« Reply #23 on: March 27, 2019, 04:03:23 AM »
I have a ms250 with 'ergostart' and yes its been great - when climbing up a tree dismantling then its REALLY good not having to fight with a saw hanging in a harness..
The wife can also pick it up and get it going in too secs which is handy..
Cheers
Justin
Gear I run;
Offline YellowHammer
  • Take Steps to Save Steps
    • Hobby Hardwood Alabama
« Reply #24 on: March 27, 2019, 08:44:59 AM »
I've got some big saws, some mid size saws, and recently got a little itty bitty saw for use around the mill and edger.  It uses a narrow kerf, fast, picco chain like a limb trimmer, and is great for trimming limbs, spikes off butt logs, the ends of boards before feeding into the edger, etc.  I also used it, just to see how it worked, to limb and trim up a decent white oak, maybe 18 inches on the butt and it did pretty good, with battery life to spare.  Not something I want to do regularly, but for small, limb trimmer sized branches, this thing is fast.
No cords, no gas, no oil, no problems, two year warranty on saw and battery.
YellowHammerisms:
Take steps to save steps.
If it wonít roll, its not a log; itís still a piece of tree.  Sawmills cut logs, not pieces of trees.
Kiln drying wood: When the cookies are burned, theyíre burned, and you canít fix them.  Donít burn the cookies.
Offline doc henderson
« Reply #25 on: March 27, 2019, 09:03:32 AM »
It is a handy saw.  good for inside the shop or for little cuts. or awkward positions.  thanks for the video.  I use mine camping so it is quiet and not a fire threat like a gas saw.
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
« Reply #26 on: April 13, 2019, 04:30:07 PM »
I now have some other work plus a week's sawmilling behind me using the new MS362.  Most of the logs were 22' so I did the bucking along with Bibbying one "too big" log.  Wow, it has the power to spare plus the "decompression" valve makes starting a breeze.  I have run well over a gallon of gas through it, so it should be getting "broken in".
Offline Crossroads
  • letís make some sawdust
    • Kevin Bales faith family farm and portable sawmill
« Reply #27 on: April 13, 2019, 06:02:36 PM »
Congratulations on the new saw! I bought an 036 about 20 years ago. It was the smallest pro saw at the time and has a compression release, but Iíve never used it. The saw runs great and has decent power with a 28Ē bar.
2017 LT40 wide, Kubota l185dt, 2-036 stihl, 2001 Dodge 3500 5.9 Cummins, l8000 Ford dump truck, hr16 Terex excavator, Farmi logging winch.
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
« Reply #28 on: April 13, 2019, 06:11:14 PM »
My arthritic hand is what drove me to a new saw with the decompression valve.  ::)
Offline Simple Jack
« Reply #29 on: April 13, 2019, 06:43:56 PM »
Sorry about your arthritic hand! Congrats on the new saw! I have a MS 290 and it's been a great saw for cut down a few small trees a year. A friend of mine wants to buy a saw and I was thinking about selling him mine and buying a new one. I was thinking about a new Still, but I don't want the m-tronic as well. I've seen a lot of great reviews on them. But I think I would just want to get one of the regular ones as well. I've never had to adjust my ms290. It's always seem to run and start great!  Fuel consumption? I don't care if they burn less fuel, I don't use all that much a year anyway. So the MS362 is the only one now that doesn't use the M-tronic? I might have to get one before they are all gone!!!
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
« Reply #30 on: April 13, 2019, 08:03:24 PM »
The Stihl brochure shows the MS362C (59cc) not M-Tronic and the MS362C-M that is M-Tronic, both being Professional saws.
The new MS311, also 59cc, is listed as a "Farm and Ranch" saw and has a decompression valve.  It also weighs 1.3 pounds more because no magnesium is used.  The MS311 is ~$200 less.
Offline TreeStandHunter
  • ISA Arborist from Michigan
« Reply #31 on: April 13, 2019, 08:19:27 PM »
We run 4 362ís at work they have been great. Get used for several hours each day over last 2 seasons and have only required the bearing on the crankshaft replaces a few times each. Donít forget to check that bearing every few weeks, once they fail it will stall the saw at idle with the brake off.
In the process of building my own mill.
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
« Reply #32 on: April 14, 2019, 07:46:38 AM »
Are they M-Tronic?  If not I wonder about the mix being used or whether they are leaned out a bit too much?
If they are M-Tronic, then I wonder even more.  smiley_headscratch
Offline Dave Shepard
  • Geometrically proportional
    • My homepage
« Reply #33 on: April 14, 2019, 01:40:09 PM »
TreeStsndHunter, are you talking about the bearing under the drive sprocket?
« Reply #34 on: April 14, 2019, 02:30:31 PM »
Yes.
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
« Reply #35 on: April 14, 2019, 08:37:00 PM »
OK, that makes more sense and has nothing to do with the fuel mix.  "crankshaft" threw me off.
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
« Reply #36 on: April 15, 2019, 09:03:15 PM »
I thought that all Stihl chainsaws were made in the USA, but this one has this sticker:
Figured that I had better take a picture quick because it will soon wear off.  ::)
« Reply #37 on: April 15, 2019, 10:54:11 PM »
How did it run for you? They seem to rev quite a bit higher than the older style saws.
« Reply #38 on: April 16, 2019, 07:27:37 AM »
I've got a some standard commercial Stihls of various sizes, and an one M-Tronic.  The M-tronic seems to have more "snap", more response, and I like it.  Never had any trouble with it.
YellowHammerisms:
Offline Sixacresand
« Reply #39 on: April 16, 2019, 07:51:41 AM »
Good looking saw, Magicman.  I trust it is light in weight, also.
Off your bottom and on your feet, out the shade and back in the heat! Back to work boys!
question
chainsaw sawmill
Started by woodwiser on Sawmills and Milling
Last post December 11, 2005, 08:24:38 AM
by PawNature
Now this is a Chainsaw sawmill
Started by Ianab on Sawmills and Milling
Last post June 14, 2009, 02:39:32 PM
by Ernie
Chainsaw Sawmill
Started by AVF on Sawmills and Milling
Last post December 23, 2015, 05:40:51 PM
by Magicman
chainsaw sawmill plans
Started by northener on Sawmills and Milling
Last post January 31, 2007, 03:29:32 PM
by rebocardo
