BLUECREEPER Poster Award #4!
That far north... umm, we don't actually use that word in polite company around here doc . Typically we go 24" on footings, where DOCatRU is you can probably get away with 18, which is a valid point. Never go less than 12 even if no frost just to be sure you're on undisturbed mineral soil, not much more to frost depth and it allows more weight down below.
SECTIONR403FOOTINGSR403.1General.All exterior walls shall be supported on continuous solid or fully grouted masonry or concrete footings, wood foundations, or other approved structural systems that shall be of sufficient design to accommodate all loads according to Section R301 and to transmit the resulting loads to the soil within the limitations as determined from the character of the soil. Footings shall be supported on undisturbed natural soils or engineered fill.Exceptions:1.One-story detached accessory structures used as tool and storage sheds, playhouses and similar uses, not exceeding 256 square feet (23.7824 m2) of building area, provided all of the following conditions are met:1.1.The building eave height is 10 feet or less.1.2.The maximum height from the finished floor level to grade does not exceed 18 inches.1.3.The supporting structural elements in direct contact with the ground shall be placed level on firm soil and when such elements are wood they shall be approved pressure preservative treated suitable for ground contact use.1.4.The structure is anchored to withstand wind loads as required by this code.1.5.The structure shall be of light-frame construction whose vertical and horizontal structural elements are primarily formed by a system of repetitive wood or light gauge steel framing members, with walls and roof of light weight material, not slate, tile, brick or masonry.
I found these two brackets very interesting.
Started by WineandWood on Timber Framing/Log construction
Started by wkheathjr on Timber Framing/Log construction
Started by woodhick on Timber Framing/Log construction
Started by Dflick on Alternative methods and solutions
