Author Topic: New rubber seals for solar panels  (Read 256 times)
Online farmfromkansas
« on: April 03, 2019, 10:38:35 AM »
Have 6 solar panels planning to clean and use to heat my wood dryer.  Need some 5/16 x 7/8 rubber for 3/16" glass to fit in the grooves in aluminum frame to seal and cushion the glass.  No luck so far in finding new rubber.  Any ideas?
Offline Don P
    • Calculator Index
Re: New rubber seals for solar panels
« Reply #1 on: April 03, 2019, 10:30:41 PM »
Google resource conservation technology and see if any of their shapes will work.
Offline doc henderson
« Reply #2 on: April 03, 2019, 10:37:25 PM »
if you cannot find anything, can you embed into silicone?  can you post any pictures? I have a roll of several hundred feet of rubber caulking that you can have if it works.  how far are you from hutch.
« Reply #3 on: April 04, 2019, 02:02:31 PM »
Am at Gypsum, probably 60 or 70 miles from Hutch.  Would prefer to find channel that fits.  One of the panels so far has new rubber, so someone makes it.  Just having difficulty finding.
« Reply #4 on: April 04, 2019, 02:10:45 PM »
The original rubber is a U shaped channel, you just slip it over the edge of the glass and then slide it into the grove in the aluminum frame.  Just 1/16" on each side of the glass, and 1/8" thick on the edge.  Entire rubber measures 5/16" x 7/8", with a 3/16" groove.
Solar panels?
Started by sbishop on Alternative methods and solutions
Last post August 08, 2013, 08:43:41 AM
by Thehardway
old solar panels
Started by farmfromkansas on Alternative methods and solutions
Last post March 22, 2019, 07:44:13 AM
by farmfromkansas
Polycarbonate Solar Panels?
Started by luke on Drying and Processing
Last post April 30, 2004, 06:28:38 PM
by Carl_B
solar panels are working!
Started by wheelinguy on Alternative methods and solutions
Last post April 22, 2013, 08:03:26 PM
by maple flats
