Tally-I/O
Author Topic: RE drying furniture  (Read 228 times)
Offline sprucebunny
  • Gender: Female
RE drying furniture
« on: April 09, 2019, 06:05:10 AM »
I had some antique furniture in an enclosed trailer that got soaked. Not leaked on but the vents got blocked and everything is really damp all the way thru. The pieces I'm concerned about are walnut.
I'm guessing I need to dry them slowly to have the best chance of them not warping. Is inside a shed slow enough or should I try to wrap them in plastic with small vents or should I just give up ???
Offline WDH
  • April 1998 - August 2008
    • hamsleyhardwood.com
Re: RE drying furniture
« Reply #1 on: April 09, 2019, 07:41:47 AM »
Inside a shed sounds like the way to go.  If it is an enclosed shed, you could place a box fan about 8' away blowing away from the stack to just keep the air moving a little bit without directly blowing it on the furniture.
Need help on drying wood for a sawing/drying shed
Started by Jeremy2200 on Drying and Processing
Last post May 21, 2011, 10:54:53 PM
by PineNut
New furniture for a New Kid
Started by Modat22 on General Woodworking
Last post February 14, 2009, 05:19:34 PM
by Part_Timer
log furniture
Started by argyle1 on Timber Framing/Log construction
Last post June 15, 2009, 11:12:01 AM
by Stephen1
tf furniture
Started by Alexis on Timber Framing/Log construction
Last post May 29, 2008, 09:49:07 AM
by FrankLad
