Author Topic: How much?  (Read 1007 times)
Offline JMG
How much?
« on: April 09, 2019, 08:44:10 PM »
I have a lt40 electric feed manual mill 27hp gas with good logs say pine how much bf sawing 1󭅅2 should I get in a day 8 HR trying to determine if I'm pushing it hard enough
JMG🚜
Offline dgdrls
  • Learning the Art of Milling Logs
Re: How much?
« Reply #1 on: April 09, 2019, 09:03:32 PM »
Just you doing it all or do you have an off-bearer/helper?
BTW, I have no Idea, but I know some folks will weight in with their experiences.
D
Offline WV Sawmiller
    • Green's Sawmill Services
Re: How much?
« Reply #2 on: April 09, 2019, 09:13:47 PM »
   Do you have a log deck? Skid steer? Tractor with fork? Tons of other questions will impact your question. I too do not know the answer but until you provide some of your equipment and procedural matters I doubt anyone else can give you an educated guess either. Good luck.
Offline JMG
Re: How much?
« Reply #3 on: April 09, 2019, 09:14:42 PM »
Just me
JMG🚜
Offline JMG
Re: How much?
« Reply #4 on: April 09, 2019, 09:17:17 PM »
Skid steer for loading use blade for return on narrow boards stack behind me
JMG🚜
Offline Southside
    • White Oak Meadows
Re: How much?
« Reply #5 on: April 09, 2019, 09:26:42 PM »
I am presuming you are asking if you are pushing the mill hard enough.  The answer lies in the quality of what is coming off the mill. If you are pushing too fast you will see wavy boards, stalling engine, bands heating up and getting loose / falling off. You want to remain just under those factors to achieve maximum production efficiency.
With a manual mill, one man show material handling will be the limiting factor over cutting speed.
White Oak Meadows
Offline 78NHTFY
  • I'm old!
Re: How much?
« Reply #6 on: April 09, 2019, 09:40:38 PM »
JMG--I have the same mill.  Working alone, with log deck loaded I can do 1 log an hour: 25% sawing time; rest offloading boards onto tractor forks; disposing of off-cut slabs; stickering boards; cleaning up sawdust; changing a blade; adding water when needed; etc......  That's a good pace for me, but I'm not 21 anymore :(.  All the best, Rob.
If you have time, you win.
Offline Lawg Dawg
  • True South Sawmill Lumber
Re: How much?
« Reply #7 on: April 09, 2019, 09:44:34 PM »
Carbide can solve all your wavy board issues...gitty up  ;D
Perfect pine lap siding boards sawed REALLY FAST, and a bunch of them!
2018  LT 40 Wide 999cc, 2019 t595 Bobcat track loader,
 John Deere 4000, 2016 F150, Husky 268, 394xp, Shindiawa 591, 2 Railroad jacks, and a comealong. Woodmaster Planer, and a Skilsaw, bunch of Phillips head screwdrivers, and a pair of pliers!
100,000 bf club member
Pro Sawyer Network
Offline Southside
    • White Oak Meadows
Re: How much?
« Reply #8 on: April 09, 2019, 10:05:56 PM »
Absolutely true, with carbides my 35 and the resaw attachment can keep up with the feed rate of the 70, they are impressive.  How thick are you making those?
White Oak Meadows
Offline Woodpecker52
Re: How much?
« Reply #9 on: April 09, 2019, 10:17:24 PM »
Takes about 5 to 7 logs a day on my mill, majority of time spent moving logs, slabs, stacking lumber,  etc. 2 man operation.  This is why this is more of a retirement hobby for us than a business concern.  Just happen to have cypress that a lot of people like at this time.
Woodmizer LT-15, Ross Pony #1 planner, Ford 2600 tractor, Stihl chainsaws, Kubota rtv900 Kubota L3830F tractor
Offline Lawg Dawg
Re: How much?
« Reply #10 on: April 09, 2019, 10:51:28 PM »
This is what I was telling you about at the GA Sawfest...I drop the head 3/4" and get a 11/16" thick board by 8" wide...can't cut them fast enough. My customers are hooked on them!  :D  8)
Small logs too!
Pro Sawyer Network
Offline Southside
    • White Oak Meadows
Re: How much?
« Reply #11 on: April 09, 2019, 11:40:54 PM »
They look really nice!!
White Oak Meadows
Offline JMG
Re: How much?
« Reply #12 on: April 10, 2019, 09:06:09 PM »
Thanks everyone for feedback
JMG🚜
Offline YellowHammer
  • Take Steps to Save Steps
    • Hobby Hardwood Alabama
Re: How much?
« Reply #13 on: April 11, 2019, 07:22:24 AM »
That's kind of an opened ended question, so instead of suggesting solutions, I will suggest a process.  I remember at one of the sawmill shootouts many years ago, two WM sawyers with a fully manual WM LT15 cut 1,150 bdft per hour, and were dead beat when done.  We all know that's not realistic over the long term, or even the course of a day, but shows how important efficiency is when sawing.
I hung a big clock on the wall, and watched it every log and tried to identify the times when when the sawmill wasn't actually making sawdust, and I realized real quick I was wasting a lot of time doing everything but sawing.  So every day, I kept trying new things, deleting steps, trying different techniques, generally being more efficient, not just in small bursts, but day after day. That's why just working harder, but not smarter, isn't the answer, as its impossible to sustain.  The best solution is to work less and produce more.  Every time a new log went on the mill, I looked at the clock.  I started seeing where I was losing time, log after log, and I made adjustments.  Then my lumber production more than doubled over a period of time with the exact same sawmill. That's the genesis of my phrase under my name on the Forum, "Take steps to save steps."
Notice the clock hanging on the back wall.
YellowHammerisms:
If it won抰 roll, its not a log; it抯 still a piece of tree.  Sawmills cut logs, not pieces of trees.
Kiln drying wood: When the cookies are burned, they抮e burned, and you can抰 fix them.  Don抰 burn the cookies.
Offline Southside
    • White Oak Meadows
Re: How much?
« Reply #14 on: April 11, 2019, 08:05:27 AM »
Hammer -  considering your recent upgrade, to paraphrase Chief Broady "Your gonna need a faster clock"  :D
White Oak Meadows
Offline Tom the Sawyer
  • Converting your logs to lumber at my home or yours
    • Tom the Sawyer Portable Sawmill Service
Re: How much?
« Reply #15 on: April 11, 2019, 08:54:33 AM »
Time studies can be quite enlightening.  Rather than relying on a clock, and my memory, I used a video camera to record everything going on during the process.  Still record every client job.
You can reduce the hassle by the equipment you use.  I use a small, 1920x1080, dash cam mounted on a tripod.  Most of them are wide-angle, recording 140-180 FOV.  With a 64 gig micro SD card, it will record about 9 hours non-stop.  It is powered via USB cable to a small powerbank, also mounted on the tripod.  The software lets you overlay date and time on the video, which makes it easy to time processes.
07 TK B-20, Custom log arch, 20' trailer w/log loading arch, F350 flatbed dually dump.  Piggy-back forklift.  LS tractor w/FEL, Bobcat S250 w/grapple, Stihl 025C 16", Husky 372XP 24/30" bars, Grizzly 20" planer, Nyle L200M DH kiln.
If you call and my wife says, "He's sawin logs", I ain't snoring.
