Author Topic: 10hp deisel vs 15hp gas  (Read 641 times)
Offline Bruno of NH
« on: April 15, 2019, 08:06:06 AM »
I'm getting an edger
Would a 10hp deisel have enough power to one it ?
I have a 13hp Honda gas
Lt 40 wide with 38hp gas and command controls Riehl Steel edger,F350 4x4 dump and lot of contracting tools
Offline Southside
    • White Oak Meadows
Re: 10hp deisel vs 15hp gas
« Reply #1 on: April 15, 2019, 09:57:36 AM »
Do you have the torque /rpm info for both to compare?
Offline DARRELL1972
« Reply #2 on: April 15, 2019, 10:33:25 AM »
Like Southside said you need to compare spec's. But my eg100 is a 13hp gas. I'm pleased with its performance.
95lt40hd
74 8k windham forklift
2018 eg100
Offline Bruno of NH
« Reply #3 on: April 15, 2019, 11:44:40 AM »
Honda gas 13hp
3,600 rpm
19.5 ft.lbs. @ 2,500
Yarnmar clone 10hp
10hp @ 3,600 rpm
8.6 go @ 3,000 rpm
20 ft.lbs. @ 1,500
Your thoughts
Offline Southside
    • White Oak Meadows
« Reply #4 on: April 15, 2019, 12:57:43 PM »
I don't see a gain. What RPM does the edger want?
Offline Bruno of NH
« Reply #5 on: April 15, 2019, 01:00:18 PM »
Southside it's the same as yours
I have the 13hp Honda it came off my mill
Offline Southside
    • White Oak Meadows
« Reply #6 on: April 15, 2019, 01:27:21 PM »
Then unless you own the diesel I would put the Honda on, actually even if I owned both I would put the Honda on, that's his standard engine anyway so it will be fine, down the road you can always upgrade.  I have a 25 HP on mine, but you don't need that much, I did that because my 35 has the same engine and I didn't have an engine sitting around.
Offline richhiway
  • Rich
« Reply #7 on: April 16, 2019, 07:15:50 PM »
Honda engines are bullet proof and start well in cold weather.
Woodmizer LT 40
New Holland 35 hp tractor
Stihl Chainsaws
Wanted cheap 15hp elec motor
Started by Kelvin on Wanted
Last post July 13, 2006, 06:37:55 PM
by Kelvin
One 10HP motor, or 2-5hp motors
Started by nathandcasey on Sawmills and Milling
Last post September 26, 2019, 10:20:43 PM
by Randy88
opinions on 10hp electric
Started by brdmkr on Sawmills and Milling
Last post June 09, 2011, 11:13:48 PM
by jim blodgett
10hp electric or 20hp gas?
Started by hackberry jake on Sawmills and Milling
Last post December 22, 2014, 08:59:08 AM
by hackberry jake
