Diesel barrel
Started by Bruno of NH, April 27, 2019, 03:40:23 PM
barbender
It's the same up here, heating oil is dyed red
YellowHammer
I hauled 55 gallon drums of diesel and 6 forklift cannisters of propane around in the back of my truck for years.  Biggest aggravation I could think of.  So I started looking aggressively for bulk suppliers of both.  It took less than 2 weeks to track down the diesel source, it was a COOP out of state, where I could get out of state Tennessee's diesel cheaper than I could get in state Alabama diesel.  I have no idea why, except greed and markup.
It took me over a year to find a propane supplier, and surprising it's not even the company who fills up my home tank.  It's a company about 60 miles away who has a bulk propane forklift route in Huntsville, and I'm on the way.
It took lots of phone calls, lots of looking, and some luck, but I was able to find sources.
YellowHammerisms:
Take steps to save steps.
Be smarter than the sawdust
Chuck White
Quote from: LeeB on May 05, 2019, 06:16:55 PM
Which costs more? Is it taxing that makes the difference?
Today's price is:  Heating Oil- $2.90+tax, and Off-Road Diesel is $2.63 if you are tax exempt, add tax if you aren't.
Resonator
Make sure you use the right type of fuel for the engine. While similar to Off-Road, home heating oil is not refined, or intended, for modern diesel engines. By using it you risk damage to the injectors and emissions system. If the owners manual specifies ULSD only, using anything else could void your warranty.
YellowHammer
That was a concern , especially with my new mill.  So I called them and they said they only sell the Ultra Low Sulfur Diesel, even as off road or untaxed use, which was great news for me.
YellowHammerisms:
easymoney
when i was a teenager, a long long  time ago. not admitting anything  but a lot of boys with a car carried a 5 gallon can and a length of siphoning hose in the trunk of their car. sometimes they went late night shopping for gas. if a tractor happened to be parked overnight close to the road the farmer would find the tank empty the next morning. you could tell who did that by looking at the carburetor on his car and seeing the color of the dye from the gas. back then gas was only about twenty five cents a gallon at the pump but money was tight.
Chuck White
The type of fuel was discussed back when I bought the tractor, and I was told to just use the off-road diesel from your home delivery truck.
I don't know of anyone around this area the goes to the pump to get their diesel, they use the off-road from the truck.
