Tally-I/O
Author Topic: Wood Splitting Has Begun  (Read 2454 times)
Offline J 5
  • Rebuilt and use Bombardier Muskegs and J5's
« on: May 19, 2019, 12:38:15 PM »
      Got started on the wood today, want it done before the hot weather in july . Although the roof addition of last year helps with the sun .
        J 5
Offline Andries
  • Making buildings out of big curvy logs
Re: Wood Splitting Has Begun
« Reply #1 on: May 19, 2019, 01:10:54 PM »
Very nice setup J5!
It looks like a long splitter and a Bombardier Muskeg(?) with a grapple trailer.
Your gallery doesn't seem to show the pictures that you've posted in the past, which seems weird to me . . .
Care to throw a few more photos up?
LT30G24, LT40G25
Ford 545 Series loaders
Stihl chainsaws
Offline sprucebunny
  • Gender: Female
« Reply #2 on: May 19, 2019, 03:04:03 PM »
I want to know more about that splitter !!
Offline Southside
« Reply #3 on: May 19, 2019, 03:22:15 PM »
Oh, how I miss those days....
Offline barbender
« Reply #4 on: May 19, 2019, 03:40:49 PM »
Come visit MN, Southside! We seem to be stuck in early April, highs in around 40 the last couple of days👎
Offline J 5
« Reply #5 on: May 19, 2019, 05:45:26 PM »
       No regrets on buying the 1700 Hardy loader, with extend, giving it a 20 foot reach, which seems never enough . I fabbed a basket for the operator and mounted it on my Muskeg after it's rebuild .
  A crank driven pump powers the clam and winches, a trans pto powers the wood splitter and chain driven hyd gate to push the wood toward the 4 foot splitter. The splitter can follow the trailer , with the wheels mounted the original way, by an articulated joint if I have to travel through gates or swung into position, with the wheels at the ends to split, ending up 13 wide.
                This setup works for us, the trailer was a low budget project and was something whipped up on short notice. Been 5 years , other than a roof, not much has changed on the setup.
                                           J 5
Offline 47sawdust
« Reply #6 on: May 21, 2019, 03:38:46 PM »
Man I love this forum.The creative talent here is remarkable.
Mick
Offline Andries
« Reply #7 on: May 21, 2019, 09:06:03 PM »
I'll second that!
J5 - the four foot splitter is that long because of your OWB firebox dimension?
. . .and the wheels on the splitter are switched from the square side tubes to the square end tubes for splitter use behind the moving tailgate wagon?
Wow!
Ingenious and clever and talk about an 'thinking outside of the box' solution !
Hats off !  8)
LT30G24, LT40G25
Stihl chainsaws
Offline 47sawdust
« Reply #8 on: May 22, 2019, 05:30:32 AM »
Who holds the splitter up when you swap the wheels? I want to be on his good side. ;D
Mick
Offline J 5
« Reply #9 on: May 22, 2019, 06:39:53 AM »
         Yes , this is a great forum, hardest part was mastering the posting pic riddle ( for those of us that are computer  challenged ).
       The four foot splitter was built about  15 years ago by a buddy and I to feed our 450 Empyre furnaces, we man handled the cylinder on a hand truck through a hundred yard obstacle course at the local junk yard. Back then we were both splitting wood our own way, my buddy would put it on a clam trailer and myself I had a boom with electric winch and tongs mounted on the splitter. So the wheels would come off and on depending, either way its now set up like this and my young lads split my buddy's wood for him . Not to much physical work involved doing it now this way , so I think its as good as it's going to get , don't want to go back to the previous way we split,... but they were fun times.
        J 5
Offline jmur1
  • Wood is King
« Reply #10 on: May 22, 2019, 12:46:35 PM »
Awesome!
Easy does it
Offline J 5
« Reply #11 on: June 14, 2019, 05:00:45 AM »
       Finished up splitting , will have to measure up to see where were at, probably get some soft wood later on in the summer. 22 hours of splitting time, we missed one weekend due to a break down. I had to make up 2 new shafts, both got bent from a jammed block, added a couple pillow blocks and turned down the relief valve at the same time.
                J 5 smiley_smash
Offline hedgerow
« Reply #12 on: June 14, 2019, 07:32:44 PM »
J 5
Those stacks of split wood is looking good. That's one thing about processing wood you find the weak spots on your equipment.
Offline J 5
« Reply #13 on: July 08, 2019, 05:39:37 PM »
  Well , I guess the splitting isn't over yet. Got some free wood from the neighbor, as he cleans up his land, mix of elm ,maple and some ash, so going to have to get cracking.
                  J 5 ;D
Offline J 5
« Reply #14 on: July 14, 2019, 08:03:17 PM »
               My 83 year old father in the zone , happy with his stihl saw and international tractor , blocking his wood . The newer generation, can't even come close to that work ethic !
                                            J 5
Offline thecfarm
« Reply #15 on: July 14, 2019, 09:18:17 PM »
Well first off,you have to get up before 11 am to do a days work. ;D
Offline J 5
« Reply #16 on: October 22, 2019, 03:12:23 AM »
                 Started splitting last weekend, around 7 hrs, hope to finish this Saturday,maybe another 5 hrs. Great weather , no bugs , no snow , my favorite time of the year.
                                                              J 5
Offline petefrom bearswamp
  • 70-12 still feel pretty good and going to retire
« Reply #17 on: October 23, 2019, 09:16:10 AM »
Maybe a lot of Youngins are lazy but my 28 yr old grandson is a regular dervish when it comes to work of any kind.
Me not so much as when younger.
LT40SHDD51
Kubota 900 RTV
Polaris 550 Sportsman ATV
241 acres of woodland
Offline NORTH
« Reply #18 on: October 23, 2019, 09:34:51 AM »
You all have some nice set ups. I get by with my old woodbooger ways but that machinery would make life a lot easier.
Husqvarna 346xp, 350, 365, 372XP
Offline thecfarm
« Reply #19 on: October 23, 2019, 09:07:04 PM »
@J 5  nice set up.
Did not see any pictures in this thread. Do you haul a trailer behind that and load that with the loader?
Splitting wood can be fun??
Started by DR_Buck on Firewood and Wood Heating
Last post December 01, 2014, 09:58:50 PM
by DR_Buck
wood splitting
Started by saltydog on Forestry and Logging
Last post October 12, 2010, 07:36:54 AM
by RSteiner
wood splitting
Started by Button on General Board
Last post April 11, 2009, 07:00:36 AM
by Ironmower
wood splitting accident
Started by js2743 on General Board
Last post October 01, 2008, 06:05:26 PM
by Mooseherder
