Anybody using WoodOwl bits?
Started by btulloh, May 24, 2019, 10:19:27 AM
doc henderson
with a screw type bit, I agree better to finish from the back, as well with forstners, but with a compound angle can be tough.  backer board and going through so the screw and keep pulling not a bad idea.  If you are doing this by hand, how accurate do you need/want your angles.  I guess if you are squaring them up, you can correct some with a chisel.
btulloh
Only had a few minutes this morning to try a couple test holes.  I forgot I had a breakfast "meeting" which took up much of the cooler period, but I did run down early and give it a quick go.
Both bits are manageable in the regular drill, but just barely.  I like the Irwin design better for most of my needs.  Smoother, more accurate holes.  The Owl is ok, but it tends to wobble in the hole a bit, making the hole less accurate, but still acceptable for what I will be doing with it.  The Owl bits seemed to be aimed at drilling in framing.  It says it's "nail proof", which would be a nice thing for drilling in framing.
HM126
Dan_Shade
Be aware of how hot your drill can get using those augers.
A friend smoked one of my drills when drilling holes for wiring.
lots of dull bands and chains
btulloh
Good point.
Even the 1/2" ship auger has caused my battery protection to trip out.  These bits demand some big power.  I've been on the lookout for an appropriate RA drill that will run these things, but until then I'm just taking it easy.  Between the battery protection and my wrists, I don't have much choice.  Fortunately, I've just got a few holes now and then to deal with.
HM126
tule peak timber
Quote from: btulloh on May 29, 2019, 11:38:37 AM
Yes, I can say that they will chew through nails !
doc henderson
Irwin also makes a "speedbore" with I think 3 flutes.  they work good in soft wood and come in 3 packs or so and not too pricey, available at lowes ect.
