Author Topic: Chasing the sawdust dream  (Read 5065 times)
Offline Resonator
  • Board Footage and Cord Woodage
Re: Chasing the sawdust dream
« Reply #40 on: December 05, 2019, 08:12:23 AM »
Recently I picked up my Sugar Maple from the solar kiln (the one with the cows standing guard). Both my meter, and the kiln owners meter, read the boards at 6 - 7% M.C. after about 2 months of drying. 8)
I was very pleased how straight they dried, the only bad ones were the short pieces on the top of the stack that looked like airplane propellers. I'll make sure to stack some heavy weight on top next time.
    But before I could start building the custom breakfast nook, my best repeat customer had another project to do. I had helped him and his wife move into his new house, and he soon realized he had to much junk, and not enough storage space. (A friend told me once you need to move every 4 - 5 years to get rid of all your junk. :D) After looking at how much pre-built yard barns cost, I offered to build him a 10x12 for less $$$ using my lumber.
I used my air dried Red Pine for all of the joists, studs, rafters, and shelf supports. The only big box store lumber was the plywood and a few 12' 2x pieces I used for the top wall plate, and on the front of the shelves. I used these since I didn't have any pieces that long, and they were extras he had saved from the new house build.
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
« Reply #41 on: December 05, 2019, 09:24:17 AM »
I love it.  Building such buildings actually was my job before I bought my sawmill.  I started using "bandmilled" lumber to save on my costs and then decided that I liked his job better than mine.  Wow, that was 18 years ago.
Offline Resonator
« Reply #42 on: December 29, 2019, 11:27:30 AM »
Got a cool pic sent to me from my friend the custom fishing rod builder. He made the featured rod on his lathe with Black Walnut, Red Cedar, and some Tiger Maple I had sawn for him.
8)
Offline Resonator
« Reply #43 on: January 29, 2020, 08:44:57 AM »
Recently I completed building the custom breakfast nook for my best repeat customer, here's some pics:
The quarter-sawn Sugar Maple had very directional grain, run it through the planer one way and it would chip, switch ends and it would cut smooth ribbons. The first log above the stump I cut at 3' to avoid a bend in the tree. These short boards had some twist when drying, but had a nice red color.
Ray fleck, ray fleck, and more ray fleck. After going through all the work of getting the lumber cut, dried, and planed, I made sure to select the best face / grain figure on each board (with as much ray fleck as possible!) The customers wife requested a tung oil finish, which I hadn't used it before, but I really liked how it made the grain "pop".
The finished project in the new house. I had to build it in two separate cabinets, in order to fit through the front door, and then reassemble them into an "L" once inside.
The entire project was built loosely based off a photo of a similar nook the customers wife found online. There were no plans, and everything was built with "eyeball engineering". This included building mock-ups to check bench and table height, and make sure they were happy with it. (Which they were). ;D
Offline Darrel
  • Never throw an unopened log on the burn pile.
« Reply #44 on: January 29, 2020, 09:02:50 AM »
Wozers! That turned out nice!
1992 LT40HD
Offline WDH
  • April 1998 - August 2008
    • hamsleyhardwood.com
« Reply #45 on: January 29, 2020, 09:13:19 AM »
Jeremy,
Super Fine!
Offline chet
« Reply #46 on: January 29, 2020, 09:16:55 AM »
  smiley_thumbsup  Very nice work , Jeremy
Offline Nebraska
  • Lurked for quite a while, learning !
« Reply #47 on: January 29, 2020, 09:17:31 AM »
Ditto that looks great.
Offline stanwelch
« Reply #48 on: January 29, 2020, 01:06:01 PM »
Very nice Jeremy.
 Especially like the quarter sawn with ray fleck.  8)
Woodworker, Woodmizer LT15, Stihl 026, MS261CM and 460 chainsaws, John Deere 5410 Tractor 540 Loader& Forks, Econoline 6 ton tilt bed trailer
Offline Bruno of NH
« Reply #49 on: January 29, 2020, 01:53:55 PM »
Great work
Lt 40 wide with 38hp gas and command controls Riehl Steel edger,F350 4x4 dump and lot of contracting tools
Offline Resonator
« Reply #50 on: January 29, 2020, 09:38:18 PM »
Thanks for the feedback guys! I put a lot of hours into the project, and wanted it to be a showcase piece. Highlighting what can be done with lumber that I can produce, (and some woodworking). ;)
Thanks also to the customer (and his wife) for generously letting me use one side of their heated 2 car garage for a workshop for over a month, without which the project wouldn't have turned out as nice. Further convincing me that I need to plan to build a new shop of my own, just for constructing projects. Allowing my business to be able to produce "value added product" year round.
"To look around at what you have accomplished in a day gives a man a good feeling. Too many men work on parts of things. Doing a job to completeness satisfies a man."
- Richard Proenneke, from "Alone in the Wilderness"
Online Jeff
  • Fearless Leader
  • I know that I do not know.
    • THEE Forestry Forum
« Reply #51 on: February 08, 2020, 01:57:01 PM »
Definitely a show piece!
Online RichTired
« Reply #52 on: February 08, 2020, 04:18:43 PM »
You do very nice work! Amazing what you can find in an old log... 8)
Wood-Mizer LT15GO, Kubota L2800, Husqvarna 268 & Stihl 241 C-M chainsaws, Logrite cant hook, Ford F-150 Fx4
Richard
Offline doc henderson
« Reply #53 on: February 08, 2020, 04:23:30 PM »
who knows, may solidify a tradition of a family eating breakfast together.  nice work start to finish.  no pun intended. :)
Offline Resonator
« Reply #54 on: March 28, 2020, 10:10:47 PM »
Even with all the nationwide pandemic that's going on, I've been getting a few sawmilling calls. I had taken a break from sawing over winter, but since the snow is melting in the land of cheese, I guess I'm back in the sawmill business. 8)
Bought a new box of blades and a couple B57's. I ran the originals till they were plum wore out, and then picked up a couple auto parts store belts to get by. They worked OK, but there's nothing like the real thing.
A repeat customer brought over a few logs to saw, though he didn't know what they were. My first guess is Elm, but I've been wrong before. Whatever it is, I'm happy to saw it (and get paid)! ;D
Offline thecfarm
« Reply #55 on: March 29, 2020, 08:09:26 AM »
You sure do good work. Both sawing and building!!
Chasing The AMERICAN DREAM !!
Started by Meadows Miller on General Board
Last post March 25, 2012, 03:13:21 PM
by Okrafarmer
chasing chainsaw?
Started by motif on Chainsaws
Last post September 17, 2010, 09:20:03 PM
by Al_Smith
Chasing perfection?
Started by JRWoodchuck on Sawmills and Milling
Last post March 21, 2017, 11:36:57 PM
by longtime lurker
Chasing Bear in da U.P. 2008
Started by Jeff on The Outdoor Board
Last post October 25, 2008, 06:33:36 AM
by SwampDonkey
