Author Topic: Chasing the sawdust dream  (Read 4719 times)
Offline Resonator
  • Board Footage and Cord Woodage
« on: June 02, 2019, 11:59:25 AM »
Some of the first Red Pine from my land I cut into lumber.
This summer it will be 2 years since I bought my first sawmill, and got hooked on making sawdust. I'm going to try doing a thread about some of the equipment I've used, logs I've sawed, and projects I've built with my lumber. Also what I've learned along the way, as I chase my dream of turning a fun hobby into a full time business. All of which I've been able to do with help from what I've learned here on the forum. Thank you FF!
My first mill. A friend of a friend had a used Woodland Mills HM 126 that he had cut all the lumber he wanted, and no longer needed. He did not have it listed for sale, and I was the only one he showed it too. We agreed to price, and he required no down payment. Just a hand shake and come back later with the money to buy it.
The mill proved to be a good basic beginner mill, and I cut quite a bit of lumber with it. Before I sold it I built a frame of 2" x 5"x 5/16" wall tube steel. I bought full 20' long pieces from a nearby steel supplier. (Bringing them home on my 10' trailer there was just a little overhang on the tail end!) This made a continuous frame with no joints, easier to keep in alignment and level. I used heavy angle iron for cross braces, bolted to tabs I welded on. This also made it so the next owner would just have to add an axle and a hitch, and it would be a portable trailer sawmill. When I sold the mill, I came out ahead. I got what I had paid for it, as well as the cost of the steel frame, not to mention the value of all the lumber It had produced.
Offline Resonator
Re: Chasing the sawdust dream
« Reply #1 on: June 02, 2019, 12:30:52 PM »
My second (and current) mill, my Wood-Mizer LT 28, brand new from the factory in fall 2017. I saved the a section of that black plastic wrap, and use it as a rain cover for the engine.
As it is today, cutting some "wood pecker pole" spruce. Very pleased with it's performance, with very few issues since I've had it. And yes my next mill will have hydraulics!
Offline trapper
« Reply #2 on: June 02, 2019, 02:11:06 PM »
nice pictures  Glad I met you last spring
marv
stihl ms241cm ms261cm  echo 310 400 suzuki  log arch made by stepson several Logrite tools woodmizer LT30
Offline Resonator
« Reply #3 on: June 02, 2019, 02:32:52 PM »
One of the first projects I built with the lumber I cut with my first mill, was a deer blind (or "shooting house" to the guys down in the land of grits ;)). I used Spruce for everything from the framing, to the full 2" floor, to the natural edge siding. The only money I had in it was the cost of hardware, metal roofing, clear acrylic for windows, and the waterproof stain. I sold it for less than plastic deer blinds were going for, plus it had the look of a mini cabin.
Inside view, with sliding windows to slide open to bag the buck!
Offline Resonator
« Reply #4 on: June 02, 2019, 02:41:33 PM »
Thanks trapper (Marv), was good to meet you too!
Offline Resonator
« Reply #5 on: June 08, 2019, 05:54:39 PM »
More pics of projects I've built with lumber cut with my mill. This was a small outdoor building built entirely with Red Pine I had logged and sawn. The outside was reverse board and batten natural edge siding with a clear finish. The customer is a relative of mine who's father planted the trees I used, so the lumber had special meaning.
Being built with fresh sawn lumber off my Wood-Mizer in winter 2018.
The structure set in its final location at the customers hunting camp on family land.
The inside I made paneling from blue stain Red Pine, ripping narrow boards with the best color, and making panels from them.
Offline Resonator
« Reply #6 on: June 18, 2019, 09:24:59 PM »
Custom sawn lumber, and lumber from my own supply, sold. 8)
1" random width Poplar boards going to a rebuild a hunting camp.
A different customer order, quarter sawn Sugar Maple.
A repeat customer has asked me to build a breakfast "nook" for a new home he is building. I cut a good sized Sugar Maple tree from my own woods, and milled over 300 bd ft of mostly clear quarter sawn lumber from the trunk logs. Nice part about this time of year is you can peel the bark off a log pretty easy before you saw it. Not so nice part was getting the logs out of the woods, had the tractor buried to the frame in the mud, and got to deal with an army of wood ticks and mosquitoes. :D
Offline Crossroads
  • letís make some sawdust
    • Kevin Bales faith family farm and portable sawmill
« Reply #7 on: June 18, 2019, 11:46:14 PM »
Nice work, you will like the hydraulics whenever you get them, I know I do. That being said, Iím glad I cut my teeth on a manual mill, I feel like the lessons learned were better earned 😉
2017 LT40 wide, Kubota l185dt, 2-036 stihl, 2001 Dodge 3500 5.9 Cummins, l8000 Ford dump truck, hr16 Terex excavator
Offline Darrel
  • Never throw an unopened log on the burn pile.
« Reply #8 on: June 19, 2019, 12:51:03 AM »
Good story so far, I'll stay tuned.
1992 LT40HD
Offline Resonator
« Reply #9 on: July 04, 2019, 09:21:27 PM »
Happy 4th of July! Hottest most humid weather we've had all year! Spent the last few days sawing some of my fresh cut Spruce into 4/4 random width boards.
One good thing this time of year the bark peels easily off the logs, especially with logs that got muddy skidding out of the woods.
I also took the time to trim branch nubs flush with the trunk without bark.
Peeling the bark extends blade life, and makes a clean edge if a board corner has some wane. Though it also makes the logs slippery, and want to slide around on the forks. ::)
Some off the logs I sawed the cant center into a 2" board, which made it easier to avoid splitting the pith.
I'm still practicing NOT splitting the pith. :D
Recently picked up a moisture meter (General MMD4E) to track how my lumber is air drying, and to let customers know what the lumber MC is when they buy it.
And just to see for myself how well the stuff you guys talk about works, I got a gallon of Anchorseal to try on my logs to be sawed into slabs. Hopefully this will make less checking in the wood, and lead to more checking in the bank!  ;D
Offline Chuck White
  • Sawing Mobile since 2005
« Reply #10 on: July 05, 2019, 06:34:22 AM »
Looks like you're doing pretty good with the mill!
Gotta be careful with fresh-peeled logs, kinda like handling a fresh-bathed baby! ;)
~Chuck~
Retired USAF 1989, Retired School Bus Driver 2012, now semi-retired Mobile Sawyer
1995 Wood-Mizer LT40HDG25 Kohler - Shingle & LapSider, Cooks Cat Claw Sharpener and single-tooth setter, 4-foot Logrite cant hook.
Offline Resonator
« Reply #11 on: August 10, 2019, 11:22:17 AM »
New customer, brought his own self unloading truck. :)
Monster Sugar Maple he had me saw, If I'd known how heavy it was, I would of had him set it right on my mill. My Kubota lifted it, but the back tires were almost off the ground. The winch driven claw log turner sure did it's job well.
Cut it into 2" x 14" pieces for guitar blanks (not the first time I've cut pieces for guitars :D). Had some curly grain, and streaks of stain from the ends.
He also brought some old hand hewn barn beams to be sawn in half for a interior project. Amazingly there were no nails! I put an old blade on just in case, and the white cedar cut like butter.
Offline RAYAR
  • Retired May 2/19 more time to play with my mill
« Reply #12 on: August 10, 2019, 01:53:47 PM »
Looks like you're having a great time.
mobile manual mill (local build) (mods & additions on-going)
Shop built auto band sharpener
96 Polaris Sportsman 500
2006 Ranger 4X2 w/cap, manual trans
Offline Resonator
« Reply #13 on: August 11, 2019, 05:40:09 PM »
Yes RAYAR, I do enjoy running my sawmill, and being able to work from home. Trying to start a business from nothing, and worrying about irregular income, is the tough part.
I really liked the camp fire benches that Jeff built at the Pig Roast. (See "Mock Up" and "Pig Roast 2019 RSVP" thread in General board.) I built my own version, with a few things different from the originals:
I used Spruce 6x6 instead of Cedar, (cause I don't have any Cedar). :D
Planed the surface smooth on the seat and arm rests.
Added a 2 1/4" block under the armrest to raise it and the back rest up, and also to serve as a cleat to screw the armrest onto the seat.
Used a router to round over the corners.
Used 10" T50 torx head anchor screws from underneath, to hide the fasteners.
Put the back rest 6x6 on the mill with a 1" sticker to tilt it, and ripped it at an angle to make it more comfortable.
Offline WDH
  • Forester
  • April 1998 - August 2008
    • hamsleyhardwood.com
« Reply #14 on: August 11, 2019, 07:36:40 PM »
Really well done.
Offline doc henderson
« Reply #15 on: August 11, 2019, 07:46:18 PM »
that looks great, and clearly designed for a guitar player, where I think Jeff's was designed for a balalaika player.
Offline Resonator
« Reply #16 on: August 11, 2019, 09:00:32 PM »
 :D :D
Offline Jeff
  • Fearless Leader
  • I know that I do not know.
    • THEE Forestry Forum
« Reply #17 on: August 11, 2019, 09:04:04 PM »
I feel like a grandad!!  :D
Offline Resonator
« Reply #18 on: August 25, 2019, 07:48:31 PM »
Took a trip back in time today at the steam and gas tractor show near me in Edgar Wisconsin. Here are a few pics of the belt driven saws they were running through the weekend.
Was fun to watch the big circle mill inside the shed run, powered by a long belt drive off a steam tractor. It would chug along quietly between logs, and then bear down and chug smoke when sawing a big Pine log.
The main drive line also powered a secondary pulley overhead, which ran a chain elevator to remove sawdust outside into a wagon.
5 man "Armstrong" log turner.
Boards cut off were run through the belt driven edger, and any bark slabs and edgings were then crosscut into firewood size pieces. The lumber is used for restoring buildings on the grounds, and the firewood for firing steam engines.
Offline A-z farmer
  • Still learning
« Reply #19 on: August 25, 2019, 08:03:51 PM »
Resonator
Very nice pictures thank you for sharing
Zeke
Chasing The AMERICAN DREAM !!
Started by Meadows Miller on General Board
Last post March 25, 2012, 03:13:21 PM
by Okrafarmer
chasing chainsaw?
Started by motif on Chainsaws
Last post September 17, 2010, 09:20:03 PM
by Al_Smith
Chasing perfection?
Started by JRWoodchuck on Sawmills and Milling
Last post March 21, 2017, 11:36:57 PM
by longtime lurker
Saw two turkeys chasing a red fox yesterday
Started by btulloh on The Outdoor Board
Last post March 18, 2017, 02:08:04 PM
by Autocar
