Author Topic: Chasing the sawdust dream  (Read 6231 times)
Offline doc henderson
Re: Chasing the sawdust dream
« Reply #20 on: August 25, 2019, 08:45:14 PM »
man killers, those belts and blades. you really had to know where to keep your hand and stuff out of.  thanks for the pics.
Offline samandothers
« Reply #21 on: August 25, 2019, 09:59:39 PM »
Great photos and narrative!  Thanks for the time to do this.
I must admit given modern world of safety consciousness looking at some of these devices makes you think how on your toes you needed and how accidents could happens so easily.
Offline Resonator
  • Board Footage and Cord Woodage
« Reply #22 on: August 25, 2019, 10:00:20 PM »
Thanks guys. Though the sawmill is inherently dangerous, the machine that was scary to watch was a wood splitter one guy had running. He used a hit and miss gas engine to spin a big cast iron flywheel with a sharp wedge mounted to the outer rim. Standing chunks of chord wood up by hand in line with the spinning wheel-wedge to split them.  :o
« Reply #23 on: August 26, 2019, 12:12:49 PM »
i have seen some like that on you tube.  great to watch on a night shift if feeling sleepy.  the adrenaline combined with coffee or diet pepsi keeps me going! :)
Offline thecfarm
« Reply #24 on: August 26, 2019, 01:21:48 PM »
I always enjoy hearing and seeing them things run!!!
Offline Jeff
  • Fearless Leader
  • I know that I do not know.
    • THEE Forestry Forum
« Reply #25 on: August 26, 2019, 03:39:54 PM »
Dont drink diet pepsi doc, its not good for you.  ;)
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
« Reply #26 on: August 27, 2019, 08:27:00 PM »
It's a proven fact that diet Pepsi will make you fat. ::)  Have you ever seen a skinny person drinking one??  ???
Offline Darrel
  • Never throw an unopened log on the burn pile.
« Reply #27 on: August 27, 2019, 08:58:33 PM »
That's true Lynn, also, unless you are a very brittle diabetic, you'd be a whole lot better off with the sugar.
1992 LT40HD
« Reply #28 on: August 27, 2019, 10:13:07 PM »
when i was in undergrad college, i also worked full time as an RT in the Lawrence memorial hospital.  i drank 5 reg. cokes a day in 8 hours.  I also did research for a year and a half, so i needed the sugar and caffeine.  i weighed 135# and was 3% body fat.  we would meet and run for an hour after work at 1 am and go to class at 8 am.  i was burning all the sugar.  i drink diet coke cause I am already fat, and I do not want to get fatter!   :D  .
Offline Resonator
« Reply #29 on: September 04, 2019, 06:00:49 PM »
I do like a good tall cold sweet tea myself, reminds me of years ago driving truck down south in the land of grits, where the waitresses called me "Hon' " ;D
Did a little welding and fabricating recently with some pieces I picked up at the steel supply yard near me. The have a large selection of channel, angle, plate, pipe, etc. and charge by the pound for cut-offs and scraps.
Made a jib hoist out of 6" C channel, 5" tube cut in half, and a couple short lengths of chain with hooks. I use this for lifting logs off of trailers that have sides/fenders that get in the way of the forks.
Also made a trailer jack bracket to mount on my mill. The bracket wraps around the frame, and the removable C channel at the top holds it in place. That way I'm not drilling holes or welding to the trailer monorail frame. I also added a few pieces of 4" nylon cargo strap for padding to keep from scratching the frame paint. The jack itself came with a short steel pipe section I welded in place, and it can be removed by pulling a pin. Adding the jack made a HUGE improvement not only for hitching and unhitching, but also for leveling the mill before sawing. (Wish I would have done this 2 years ago!) :D
« Reply #30 on: September 04, 2019, 06:46:59 PM »
new study in JAMA says all soda is bad, do not know why but worldwide correlation
Offline Nebraska
« Reply #31 on: September 04, 2019, 10:44:20 PM »
Meh.... bad schmad, life is 100% fatal anyway.  smiley_skull  Some days diet Pepsi is a blessing, most all things in moderation.. oh yeah and Resonator nice pictures as well, like your jib hoist,  my heavy trailer has those fenders in the way as well.
Offline btulloh
« Reply #32 on: September 05, 2019, 09:27:58 AM »
Everyday something is added to the list of stuff that's bad for you.  Occasionally something is removed from the list and determined to be OK after all.  It's important to watch the news closely so you know what to scared of.    :D :D
Be careful of excessive moderation.  ;D
Offline nativewolf
  • Forester
« Reply #33 on: September 05, 2019, 09:57:46 AM »
I can certainly believe this, soda consumption has moved pretty much in correlation with declining health.  We just don't need to drink anything more than H20, a soda should be a treat once a day or less and not these 32 oz things people consume like crazy.  Just common sense I'd think.  In the poor south it used to be people drinking cool-aid with just crazy amounts of sugar, now it is soda.  Sigh.
Liking Walnut
Offline Bruno of NH
« Reply #34 on: September 05, 2019, 11:26:34 AM »
My uncle had kidney cancer last year.
Drinks lots and lots of diet soda
I think that did it
Lt 40 wide with 38hp gas and command controls Riehl Steel edger,F350 4x4 dump and lot of contracting tools
Offline Resonator
« Reply #35 on: September 12, 2019, 08:37:29 PM »
Some of the Sugar Maple I sawed last year, is in a friends shop being made into an island countertop. This will go into a repeat customers new house (the tree came from his land). Stay tuned for more future work on this project. ;)
Sold 650 bd. ft. of my rough sawn 1" Spruce.  8)
This customer saw my ad online, and drove about 2 hours each way to buy it, and was glad to fit it all in his short box pickup! While I was helping this customer, another pulled in my driveway and bought a 3' Black Ash natural edge slab. I'm grateful for the business, but do they have to pull in all at the same time?! :D
Offline PAmizerman
    • Byrne Millwork
« Reply #36 on: September 12, 2019, 08:44:26 PM »
I like when customers all come at the same time. That means I don't have to stop what I'm in the middle of to wait on them.
Hydraulics everywhere
Traverse 6035 telehandler
Case 95xt skidloader
http://byrnemillwork.com/
WM bms250 sharpener
WM bmt250 setter
Offline PAmizerman
    • Byrne Millwork
« Reply #37 on: September 12, 2019, 08:46:18 PM »
I've had customers drive over 3 hours one way for hemlock and Ash.
WM bms250 sharpener
WM bmt250 setter
Offline Resonator
« Reply #38 on: September 15, 2019, 02:53:10 PM »
Quote
As promised the Sugar Maple project continues. My repeat customer found a guy with a solar kiln to dry the lumber for his new breakfast nook. (My lumber is stacked in front.)
He claims it can get up to 120 on a good sunny day. I tend to believe him as I was sweating loading lumber inside on an overcast day. The gray metal duct at the bottom of the wall runs to a furnace for additional heat in winter. During the summer the only cost to run it is the electricity for the fans.
I left my lumber in good hands, knowing he had some large animals standing guard. ;D
Offline Resonator
« Reply #39 on: December 04, 2019, 08:43:56 PM »
I had a new customer stop in and buy some full 2" x 12" White Pine I had for sale. Some of the wood was from a huge tree taken down by a tree service, and some wood from my own land. I had originally cut it into random widths, but he requested it be resawed into 12" for stair treads. The lumber buyer is a custom builder who plans to build a playhouse - man cave inside a converted grain silo.
Not long after the lumber customer, I got a call from a many times repeat firewood customer buying the first load of the season. Board footage and cord woodage, just another day chasing the sawdust dream. ;D
Chasing The AMERICAN DREAM !!
Started by Meadows Miller on General Board
Last post March 25, 2012, 03:13:21 PM
by Okrafarmer
Chasing perfection?
Started by JRWoodchuck on Sawmills and Milling
Last post March 21, 2017, 11:36:57 PM
by longtime lurker
chasing chainsaw?
Started by motif on Chainsaws
Last post September 17, 2010, 09:20:03 PM
by Al_Smith
Saw two turkeys chasing a red fox yesterday
Started by btulloh on The Outdoor Board
Last post March 18, 2017, 02:08:04 PM
by Autocar
