Author Topic: Air drying some walnut slabs  (Read 812 times)
Offline busenitzcww
« on: June 03, 2019, 10:31:41 PM »
Nothing like that feeling of getting your wood stacked and under a roof.
Do you guys spray walnut with bora care? Iíve got a bunch of ash coming up that I want to treat but wondering if I should have done my walnut too? Other species? I have some bur oak, locust, coffee bean, mulberry,and hedge. Can you spray it good enough after itís stickered if you see bug action? Should have thought this out before I moved all these 3í x10í slabs  :)
Online doc henderson
Re: Air drying some walnut slabs
« Reply #1 on: June 03, 2019, 10:43:50 PM »
very nice.  dark, but very nice!!!
Online YellowHammer
  • Take Steps to Save Steps
    • Hobby Hardwood Alabama
« Reply #2 on: June 03, 2019, 10:48:01 PM »
I donít spray my walnut, bug donít seem to like it much.  I once had termites build a mud tunnel over some walnut to get to some oak.
HobbyHardwoodAlabama.com
Online WDH
  • April 1998 - August 2008
    • hamsleyhardwood.com
« Reply #3 on: June 04, 2019, 09:06:35 AM »
I don't spray walnut either.  PPB's will get in walnut sapwood though.  I have had that happen more than once.
Offline scsmith42
    • Whispering Pines Farm
« Reply #4 on: June 04, 2019, 09:58:57 PM »
Ditto Danny and Robertís advice.  If you spray it, donít use Bora-care on green lumber.  Use Timber instead (cheaper).  Bora-care is best for dry lumber.
If you do spray it, typically you only need to spray the bark and sapwood.
Tom's 3638D Baker band mill
Offline firefighter ontheside
  • I like trees.
« Reply #5 on: June 06, 2019, 04:48:25 PM »
Interesting info here.  Iíve been spraying everything , but maybe I will not spray walnut, at least not the heartwood.
Woodmizer LT15
Kubota Grand L4200
Stihl 025 and MS291
2017 F350 Diesel 4WD
« Reply #6 on: June 06, 2019, 05:04:46 PM »
just picked up 1.5 pounds of tim bor today from the pest guys.  plan to make a gallon in a sprayer.  any other tips.
  • I like trees.
« Reply #7 on: June 06, 2019, 07:05:11 PM »
Use hot water to help it dissolve.
Woodmizer LT15
Kubota Grand L4200
Stihl 025 and MS291
Offline GeneWengert-WoodDoc
« Reply #8 on: June 06, 2019, 07:24:10 PM »
It will be important to cut and then fit together almost right away, as it is not uncommon to have the logs warp and twist as they dry and then the t&g will not align.
Online 123maxbars
    • www.outofthewoodsforestry.com
« Reply #9 on: June 07, 2019, 11:20:46 PM »
Nice timber,
Sawyer/Woodworker/Timber Harvester
W/M LT40HD, W/M KD150 Dehumidification Kiln Mahindra 4550, BMS 250 Sharpener, BMT 150 Setter, MS880 chainsaw mill,
outofthewoods
Youtube page
Out of the
Offline Marshall7199
« Reply #10 on: July 22, 2019, 10:24:38 PM »
Good looking slabs. not to be too nosey but what is the white material under the concrete blocks?
Rookie learning from the masters.
Offline DWyatt
« Reply #11 on: July 23, 2019, 08:56:11 AM »
Looks like limestone screenings/sand to me.
Offline K-Guy
    • http://www.nyle.com/
« Reply #12 on: July 23, 2019, 10:34:29 AM »
@Marshall7199
It is that beautiful Kansas oceanfront beach sand. :D ;D
Nyle Kiln Sales & Service
"He has all the virtues I dislike and none of
 the vices I admire." -Winston Churchill
Online YellowHammer
« Reply #13 on: July 23, 2019, 12:25:18 PM »
Looks like a spilled bag of grits.
Offline busenitzcww
« Reply #14 on: July 23, 2019, 02:33:13 PM »
Thanks! Itís just limestone screenings from the local quarry. Iím kinda wishing Iíd had just poured concrete and then I wouldnít of had to level all by bases, or at least been really close. I started putting cinder blocks down and then shimming a 2x6 on top of that for my pallets.
Drying walnut slabs
Started by Wes06 on Drying and Processing
Last post July 22, 2018, 10:22:41 PM
by GeneWengert-WoodDoc
Could PEG 1000 be used for stabilizing walnut slabs before drying ?
Started by Dough_baker on Drying and Processing
Last post May 24, 2015, 04:09:41 PM
by WIwoodworker
drying slabs
Started by xlogger on Drying and Processing
Last post April 06, 2015, 03:44:40 PM
by beenthere
Drying Oak slabs
Started by JAG on Drying and Processing
Last post March 11, 2014, 07:55:30 PM
by JAG
