Dynamic Green Products Inc.
Author Topic: Problem with Protimeter Timberlogger  (Read 296 times)
Offline kelLOGg
  • More is better but enough is best
« on: June 14, 2019, 12:25:22 PM »
I don't read of anyone having this moisture meter. It has hammer electrodes and thermocouple attachment which make it easy to make measurements outside the kiln via wires passing thru an access port to the unit outside the kiln. Mine has bit the dust: it reads either 7% MC in any medium or nothing at all. Its made in the UK and I doubt it will be feasible to repair. Any recommendations for a similar replacement? or repair possibilities? or other ideas?
Bob
Cook's MP-32, 16HP, 20' (modified w/ power feed, up/down, loader/turner)
DH kiln, CatClaw, setter, tandem trailer, log arches, tractor, thumb tacks
Offline K-Guy
    • http://www.nyle.com/
Re: Problem with Protimeter Timberlogger
« Reply #1 on: June 14, 2019, 01:33:33 PM »
Hi Bob
The two best brands on the market are Delmhorst or Lignomat.
I recommend the Delmhorst J2000X Package but I am biased as we are a dealer for them. ;D
I've heard good things about the Wagner moisture meters but I'm not familiar enough with them to judge.
Nyle Kiln Sales & Service
"He has all the virtues I dislike and none of
 the vices I admire." -Winston Churchill
Offline Don P
    • Calculator Index
« Reply #2 on: June 14, 2019, 05:02:48 PM »
It doesn't sound good but try one thing before writing it off. In the electrical aisle at Lowes get a tube of Ox-Gard and smear the paste on all the connections and try it again.
Offline kelLOGg
« Reply #3 on: June 14, 2019, 08:24:44 PM »
"all the connections"? I guess that means where I plug in the electrode wires and the battery connections? BTW, I measured the battery voltage at 5.9 VDC so I'm sure they are good. I burnished the terminals where the batteries make contact so that leaves the electrode receptacle to possibly benefit from Ox-gard. I'll check it out. Thanks
Offline kelLOGg
« Reply #4 on: June 14, 2019, 09:32:48 PM »
Well, well, well, Don P, you put me onto something. I measured the resistance from one of the contacts on the electrode plug to its corresponding electrode. I got about 1 ohm which sounded reasonable. I made the same measurement on the other contact to its corresponding electrode and got infinite resistance - a broken connection. I disassembled the electrode assembly and the wires fell out. It will be delicate soldering but I will attempt it tomorrow. Wish me luck.
Bob
Offline Don P
    • Calculator Index
« Reply #5 on: June 14, 2019, 09:56:44 PM »
Good deal, hope it works  :).
Offline kelLOGg
« Reply #6 on: June 15, 2019, 06:20:14 AM »
IT DID!. Tiny wires but I was able to solder them back and all is well. Hammer electrodes take a beating even though I pre-drill pilot holes.
Thanks.
Bob
I have a problem problem starting Stihl ms290 chainsaw
Started by bardos on Chainsaws
Last post May 07, 2015, 08:42:26 AM
by GAB
Sir, WE HAVE A PROBLEM!!!!
Started by etat on General Board
Last post June 15, 2004, 12:56:53 PM
by Swede
New 462 problem
Started by Kruz17 on Chainsaws
Last post May 06, 2019, 10:26:28 PM
by ZeroJunk
PH 260 problem
Started by ARKANSAWYER on Drying and Processing
Last post August 12, 2008, 12:06:39 PM
by ARKANSAWYER
