Author Topic: Wooden or foam closure strips for solar kiln  (Read 405 times)
Offline Pepe_Silvia
« on: June 24, 2019, 10:40:50 AM »
Is there any advantage or disadvantage to using wood or foam closure strips?  My panel length will be just shy of 8'.  I was thinking four strips - the top and bottom using foam for sealing and the middle two wood for rigidity.
Offline farmfromkansas
Re: Wooden or foam closure strips for solar kiln
« Reply #1 on: June 28, 2019, 09:45:26 PM »
Are you talking about the supports under the glazing, using foam at top and bottom? And the supports in the middle of the glazing just being wood?  Think the company that sells the twinwall poly, makes a channel for between the glazing, and the top and bottom.  The cells need to be closed off or they collect dust, which will mess up your light transmission.
Offline doc henderson
« Reply #2 on: June 29, 2019, 04:15:15 AM »
you must be talking about corrugated panels.  I think wood will hold up better.  heat and humidity.
2" thick foam for solar kiln?
Started by Florida boy on Drying and Processing
Last post January 29, 2017, 10:57:09 PM
by pineywoods
Anyone tried building a solar kiln with R-Max, or other foam insulation panels?
Started by Delawhere Jack on Drying and Processing
Last post September 06, 2015, 08:57:10 PM
by Delawhere Jack
URETHANE FOAM KILN
Started by fencerowphil (Phil L.) on Sawmills and Milling
Last post January 27, 2002, 05:42:54 AM
spray foam on a kiln wall ?
Started by Tom L on Drying and Processing
Last post March 21, 2014, 10:49:23 PM
by GeneWengert-WoodDoc
