Author Topic: Built a arch trailer for oak logs  (Read 716 times)
Offline LoneDuck
« on: June 24, 2019, 09:03:27 PM »
Just thought some of you would like this. I had a chance to get these large white oak but no way to get them loaded. So I had seen a guy using a trailer to load logs on YouTube and so grabed some scrapes from around  the shop, fired up the welder and this is what I ended up with. I was surprised at how well it worked. The first log was so heavy that I pulled the truck and trailer under the log. Got them home now to see if I can get them on the mill.
Offline Old Greenhorn
    • Woodsman Forest Products
Re: Built a arch trailer for oak logs
« Reply #1 on: June 24, 2019, 09:47:48 PM »
NICE ARCH! I have been thinking about one of those too. They look to be about 16-18' and over 22". For WO I am guessing they are well over 2,000 pounds. Nicely done, very impressive.
Oscar 328 Band Mill, Husky 450, 562, & 372 (Clone), Mule 3010, and too many hand tools. :) Retired and trying to make a living to stay that way. NYLT Certified.
OK, maybe I am the woodcutter now.
I can work with wood, but I am NOT a Woodworker, but almost.
Offline Southside
    • White Oak Meadows
« Reply #2 on: June 24, 2019, 11:30:51 PM »
Why does it only work for oak logs?  :D
White Oak Meadows
Offline Tom the Sawyer
  • Converting your logs to lumber at my home or yours
    • Tom the Sawyer Portable Sawmill Service
« Reply #3 on: June 24, 2019, 11:52:24 PM »
That big one is probably well over 5000 pounds.  LoneDuck, please consider adding trailer jacks to the rear corners of your trailer.  A big log, in addition to pulling the whole rig backwards, can also lift the rear of the tow vehicle enough to cause a roll away.  It also places extreme strain on the portion of the trailer that is cantilevered behind the axle.  Be safe.
07 TK B-20, Custom log arch, 20' trailer w/log loading arch, F350 flatbed dually dump.  Piggy-back forklift.  LS tractor w/FEL, Bobcat S250 w/grapple, Stihl 025C 16", Husky 372XP 24/30" bars, Grizzly 20" planer, Nyle L200M DH kiln.
If you call and my wife says, "He's sawin logs", I ain't snoring.
Offline LoneDuck
« Reply #4 on: June 25, 2019, 09:01:44 PM »
Thanks guys. The trailer is still a work in progress and rear supports are on the list of things to modify. Also maybe a roller. As for the big log it was over 30" on the small end and over 15' long, so I'm guessing closer to 6000 pounds.
Offline chet
« Reply #5 on: June 25, 2019, 09:26:39 PM »
That big one is probably well over 5000 pounds.  LoneDuck, please consider adding trailer jacks to the rear corners of your trailer.  A big log, in addition to pulling the whole rig backwards, can also lift the rear of the tow vehicle enough to cause a roll away.  Be safe.
A few years ago we lost a forum member when this very thing occurred while loading his trailer.
Offline John Bartley
  • Location: 13 Critchley Avenue, PO Box 36, Monteith Ont, P0K1P0
« Reply #6 on: June 25, 2019, 09:34:29 PM »
Those are a great way to load odd shaped items onto anything.  Lots of guys are using that style of arch/winch for loading and unloading snowmobiles on/off pickup trucks.  It's simple and it works.
Kioti DK35HSE w/loader & forks
Champion 25hp band mill, 20' bed
Stihl MS361
Stihl 026
Trailer for logs with arch
Started by JMB66 on Forestry and Logging
Last post September 20, 2021, 12:14:42 PM
by charles mann
Another home built log arch
Started by OH Boy on Forestry and Logging
Last post January 11, 2014, 09:00:59 PM
by Sixacresand
Home built log arch
Started by jdrakephd on Forestry and Logging
Last post July 05, 2021, 03:25:18 PM
by jdrakephd
Anyone built a logging arch
Started by WV_hillbilly on General Board
Last post October 11, 2002, 11:29:22 AM
by WV_hillbilly
