Author Topic: Chipping trees?  (Read 1206 times)
Offline NorthCaroliney
Chipping trees?
« on: July 06, 2019, 03:21:00 PM »
Any recommendations for how to go about whole tree chipping / equipment to use (rental options needed) and/or what services to look for when hiring? My understanding had been that I could chip/shred downed trees, but now that I have downed trees, I am having a hard time finding actual options for rental equipment or for-hire work.
Online btulloh
Re: Chipping trees?
« Reply #1 on: July 06, 2019, 03:32:36 PM »
Trees. How big?
Usually takes a tub grinder fed by an excavator. No such thing as a rental. Land clearing contractor can provide this service.
HM126
Re: Chipping trees?
« Reply #2 on: July 06, 2019, 03:53:17 PM »
Mostly < 10-12/14" -- only stuff we were comfortable taking out ourselves with a 7500# mini-ex.
Online btulloh
Re: Chipping trees?
« Reply #3 on: July 06, 2019, 04:02:02 PM »
A tub grinder will eat those, stumps and all. Last time I had it done it was 400 an hour 16 hour minimum. Varies from contractor to contractor. Just get some quotes. The rig that was here could produce 800-1000 yds of chips per hour. (That sounds high. Could be a memory issue. It was ten years ago. It did a lot of work in a short time. )
HM126
Online btulloh
Re: Chipping trees?
« Reply #4 on: July 06, 2019, 04:20:15 PM »
Thinking back, it was an amazing thing. They ground up 20 acres of too-big nursery stock including a big area of 30ft arbor vitae. It took 12 hours and then they did 6 hours grinding of blow down I had left from a hurricane. One operator, 45 ton ex, tub grinder run by remote by the excavator op. Kind of amazing really.
HM126
Online Maine logger88
  • Don't force it get a bigger hammer
Re: Chipping trees?
« Reply #5 on: July 06, 2019, 05:25:59 PM »
Not sure if many loggers in your area chip or not but if the wood isnít to dirty a 20in disk or drum chipper would do the trick you might be able to hire them to come chip it up for you. I doubt if you could rent a chipper big enough to do the job most rental companies only rent small hand feed chippers.
79 TJ 225 81 JD 540B Husky and Jonsered saws
Offline Riwaka
Re: Chipping trees?
« Reply #6 on: July 06, 2019, 11:10:57 PM »
Probably be an appropriate rental machine somewhere. Cost likely to be high in diesel etc.
e.g https://www.vermeermidatlantic.com/rental-equipment
Offline treemuncher
  • Committed vegetation terrorist since 1997
    • TreeMuncher.com
Re: Chipping trees?
« Reply #7 on: August 13, 2019, 07:54:50 PM »
Find a local contractor that runs 300Hp class or larger mulchers. The terrain will dictate tracks or tires and carrier or excavator based. I don't care if it's laying or standing, if I can reach it with a cutter head, I can grind it up. The only drawback is that I don't put chips in uniform sizes and neat piles. I can usually spread the chips about a bit and make it look pretty.
I grind stump balls, stems, tops, bits and pieces. It just takes a lot of power to muscle through trees bigger than 4" diameter. Speed is also relative to available power. If the tub grinders get $400/hr with a 16 hr min, my rates would be competitive and half the minimum.
Pictures from a job where I had to completely clear whatever the loggers left behind. Many of those stumps exceeded 30" at the cut.
I was running my Barko 937 on this part of the job. This is after I first started cleaning up the mess.
Finished product after I processed everything. Ready to throw down grass seed and be maintained with a bush hog.
TreeMuncher.com  Where only the chosen remain standing
Offline thecfarm
Re: Chipping trees?
« Reply #8 on: August 13, 2019, 09:07:25 PM »
That looks good. Do that on my land and there would be rocks sticking up all over the place.
Chipping at its best!!
Started by thatchipperguy on Forestry and Logging
Last post June 10, 2016, 08:32:17 AM
by teakwood
Chipping.
Started by BargeMonkey on Forestry and Logging
Last post March 26, 2016, 09:31:09 AM
by thatchipperguy
Best practice for chipping and wet vs dry
Started by redbull on Forestry and Logging
Last post April 30, 2019, 12:03:22 PM
by RPF2509
Finally Chipping
Started by ET on General Board
Last post June 23, 2013, 08:07:55 AM
by ET
