Author Topic: How would you sand this cookie?  (Read 852 times)
Offline Downstream
« on: July 14, 2019, 11:47:04 PM »
I have purposely let some thin cookies dry so they warp into a shallow bowl shape.  I am looking for comments on how people would try to sand them after they have warped into bowl shape.  what tool or process would you suggest.  Also one issue is how to hold it while I sand both concave and convex sides?  Comments?
EZ Boardwalk Jr,  Granberg Alaskan Chainsaw Mill, Stihl 660 and 211, Logrite 60" cant hook, Dixie 32 Tongs
Offline terrifictimbersllc
    • Terrific Timbers LLC
Re: How would you sand this cookie?
« Reply #1 on: July 15, 2019, 03:43:56 AM »
Put it on a pillow and use a random orbit sander with a light touch and tilting as necessary to fit the contours. Finish up with one of the Beall wood buffing sets.
DJ Hoover, Terrific Timbers LLC,  Mystic CT Woodmizer Million Board Foot Club member. 2019 LT70 Super Wide,  Logrite fetching arch, WM BMS250 sharpener/BMT250 setter.  2001 F350 7.3L PSD 6 spd manual ZF 4x4 Crew Cab Long Bed
Offline doc henderson
« Reply #2 on: July 15, 2019, 04:28:14 AM »
I use the tool box liner rubber matts.  lay it on top and they hold it and pad it until they are saturated with dust.  you can use course sand paper but anything near the edge may chip off if too aggressive.  you could pad a bench dog in a hole on your bench but easy does it.  if you knock off a chunk of bark and want to keep it, just glue it back on.  I assume you want to keep the bowl shape.
Offline Bill Gaiche
  • Home built bandsaw, Kioti DK4510. Sthil 211&361
« Reply #3 on: July 15, 2019, 11:02:26 AM »
Put a 5 gallon bucket down on something solid and put some sand, rocks any weight in the bottom to hold it steady. Then put a piece of old carpet on top, then set your piece on it and sand away. bg
Online Jeff
  • Fearless Leader
  • I know that I do not know.
    • THEE Forestry Forum
Offline low_48
« Reply #5 on: July 18, 2019, 10:37:43 PM »
Bosch 5" random orbit sander. I do all my larger bowls off the lathe with that sander. Just sit it in my lap, put on a good dust mask, start the floor fan to help remove air borne dust, tilt the sander slightly so you are just touching the outside inch or so on the pad, and go after it. 80, 120, 180, 220 Works great.
sad
Sanding irregular surfaces - sand sand sand & sand some more
Started by woodbowl on General Board
Last post April 24, 2006, 05:47:54 PM
by getoverit
Now to sand and put on the finish .
Started by Bill_G on General Woodworking
Last post February 05, 2013, 09:30:33 AM
by justallan1
Tracks in the sand.
Started by Jeff on The Outdoor Board
Last post May 03, 2015, 07:45:20 AM
by thecfarm
Sand Point Well?
Started by jander3 on Timber Framing/Log construction
Last post January 28, 2009, 08:04:00 PM
by jander3
