Tally-I/O
Author Topic: Anyone with a portable sawmill in the Lucketts Virginia area?  (Read 350 times)
Offline MuadDib
« on: August 03, 2019, 12:44:28 PM »
I am helping a friend recover usable wood from 20 oak logs (12' length, starting at 29" diameters) from trees felled about a week ago.  We are staging the logs for milling.  We hope to get a few 2-1/2" slabs and cut the rest to 6/4.  There is room to pull a trailer and the road to the property is just off of Rout 15 north of Lucketts.
Please respond if interested in discussing the work further and we will exchange email.
Michael
Offline WV Sawmiller
    • Green's Sawmill Services
Re: Anyone with a portable sawmill in the Lucketts Virginia area?
« Reply #1 on: August 03, 2019, 01:28:25 PM »
   First check here under the Extras tab on the FF home page and select portable bandsaws then click in Virginia under the State dropdown and hit search. See if any of the members listed there are close enough to help.
    If there is nobody there you can next try going to the Woodmizer site and under services check the find a sawyer list and see if that is an option. Good luck.
Offline MuadDib
« Reply #2 on: August 03, 2019, 04:47:35 PM »
Thank you!
Online btulloh
« Reply #3 on: August 03, 2019, 04:53:40 PM »
HM126
Offline CCCLLC
  • It's not to big, load it!
    • Carolina Custom Cut
« Reply #4 on: August 03, 2019, 05:09:44 PM »
Diameter starting at 29", do they go up from there or is that the top end?
Offline Southside
« Reply #5 on: August 03, 2019, 05:18:04 PM »
Possibly, 5% rule would apply, just how big are they and what do you have for support equipment?
Offline CCCLLC
« Reply #6 on: August 03, 2019, 05:30:03 PM »
Southside, I have to ask, what is the 5 percent rule?
Offline Southside
« Reply #7 on: August 03, 2019, 06:10:13 PM »
Any business or sales which happen as a result of Forum postings agree to pay 5% of the proceeds to The Forum.
Offline dgdrls
  • Learning the Art of Milling Logs, Lucas 8/27
« Reply #8 on: August 03, 2019, 06:45:27 PM »
agreed with the 5% rule,
D
Online btulloh
« Reply #9 on: August 03, 2019, 06:55:45 PM »
Lucketts is further up 15 than I remembered.
Sounds like some nice logs.
HM126
Offline JBailey
« Reply #10 on: August 05, 2019, 02:50:21 PM »
This is an excellent resource - thank you WV Sawmiller!
« Reply #11 on: August 05, 2019, 03:36:17 PM »
   Thanks. I started a thread to see if any others offered a similar program and ultimately determined WM was the only brand to offer currently such a service.
portable sawyer in Northern Virginia - DC Metro area
Started by jefprice on Wanted
Last post December 29, 2014, 11:25:50 PM
by jefprice
Anyone with a portable sawmill in the DC area?
Started by MS on Sawmills and Milling
Last post November 08, 2011, 01:22:10 PM
by DR_Buck
Portable sawmill in West Texas - Lubbock area
Started by E-Tex on Sawmills and Milling
Last post November 12, 2018, 07:53:38 PM
by E-Tex
Customer needs to hire portable sawmill in the Charlotte, NC area
Started by RalphV on Sawmills and Milling
Last post April 03, 2012, 08:44:11 PM
by POSTON WIDEHEAD
