.. i'm about 6 sec. per foot now with electric
just add a dc speed controller. I recently bought one good for 12-24-36 volts and 60 amps full load for less than $20 free shipping. forward reverse and center off, and a potentiometer for speed control, digital readout showing 0- 100 percent. I just installed it to run a geared mobilty cart motor that I installed on my Lm 29 norwood mill to run the carriage. so far the speeds are ok but the true test will be when I put a log on the mill.I also used a harbor freight 12 volt winch to power the head up and down and it works very well. (Image hidden from quote, click to view.) (Image hidden from quote, click to view.)
Looking good. how did you build the hinge bar that looks like 2 pieces of flat plate with a spacer in the center? How bout a closer pic?
Really considering sending it away for galv or even paying to have it blasted and primed.
Started by ljohnsaw on Sawmills and Milling
Started by jay_d on Sawmills and Milling
Started by bugpeople on Timber Framing/Log construction
Started by VooDooChikin04 on Sawmills and Milling
