Dynamic Green Products Inc.
Author Topic: Guide bars??  (Read 1099 times)
Offline Firewoodjoe
  • Im getting old
Guide bars??
« on: August 04, 2019, 09:18:21 PM »
Well spent today in my garage. Tinkering with saws and bars. I have Oregon and GBs and one Tsumura. I repair and maintain all myself. I have tips for all. I have only cut about 100,000 feet with the Tsumura and itís a good tough bar. Bent in a complete U and bent back fine. And I seem to have much better luck with GB tips vs Oregonís. It would be nice to consolidate a little and I see my supplier has GB titanium bars for a decent price. But have read elsewhere via google the word was stopped production a few years ago. So?? And the Tsumura is a little more money but good. Should I stick with Oregonís buy some more GB or Tsumuraís. Just looking for someone 2 cents.
Offline Haleiwa
  • Clinton county, New York
Re: Guide bars??
« Reply #1 on: November 06, 2019, 06:00:08 PM »
I just bought two GB bars for my Keto, and I am impressed.  Yesterday I cut an ash that was actually a little bigger than the head's capacity, and when the saw was about three fourths of the way through it split and the butt end kicked up when the head tipped (I had already released it about half way through, which in hindsight wasn't a real smart move).  I was practically out of the cab to change bars, but cycled the saw and everything looked good, so I kept on cutting.  those bars seem to have more spring in them than Oregons, and the price isn't much different.
Socialism is people pretending to work while the government pretends to pay them.  Mike Huckabee
Offline Firewoodjoe
  • Im getting old
Re: Guide bars??
« Reply #2 on: November 06, 2019, 07:41:41 PM »
I still havenít done a thing to that Tsumura but close the rails and dress it. And it didnít really need dressed. Itís tough but does seems to be getting a little more flexy and some of the plastic inserts are cracked but seem to be staying it tight. Iím impressed with it. And Oregon tips still suck. It donít matter if I buy $20 Oregon or the $5 Japan ones they last the same.
Offline Bncyom33
Re: Guide bars??
« Reply #3 on: November 12, 2019, 11:37:04 PM »
Hey guys looking for some info. Need to get a bar for a Poulan 655bp I picked up. Havenít had any luck finding anything bigger than a 20Ē. Oregon doesnít list anything bigger either. Strange because itís a 99cc saw. Looking to put a 32 on it. 50ga. 3/8. anyone ran into the same issue? Any help ie.. part number etc would be greatly appreciated. Love those Sugiís but beggars canít be choosy I guess. Thanks
Ben
Jonsereds 70e, CS2152,Stihl MS360, Poulan 655 Bp, poulan 3700 and a 25ton splitter
Online Ianab
Re: Guide bars??
« Reply #4 on: November 13, 2019, 02:27:09 AM »
From what I can see it uses a "PIONEER PRO SAW MOUNT", which Oregon refer to as "D007", and don't seem to stock any more?
They do a D009, but the bar mount groove is 0.5mm narrower. Just enough to stop it fitting.
I'd Email Oregon and see if they had an alternative, even if you needed some sort of shims or spacers to mount it.
It cross references to a Windsor "PP" mount, or a GB "P" mount.
GB do list a couple of "P" mounts, but only to 24".
But if you can do a search on those mount patterns you might find a "new old stock" someplace.
Offline Bncyom33
Re: Guide bars??
« Reply #5 on: November 13, 2019, 09:44:16 AM »
Thanks for the info Iíll check into it. Probably have to end up doing a little retro fitting
Offline Pine Ridge
  • Part-time logger, Full time loafer
Re: Guide bars??
« Reply #6 on: November 13, 2019, 01:01:34 PM »
According to what i can read, you can take a large mount husqvarna d009 bar and make it fit without too much work, that is internet info but i believe the guy knows what he's talking about.
Husqvarna 550xp , 2- 372xp and a 288xp, Chevy 4x4 winch truck
Online Ianab
Re: Guide bars??
« Reply #7 on: November 13, 2019, 02:13:41 PM »
Probably correct. Looks like you would need to make the mounting slot 0.5 mm wider. A good eye, a steady hand, a Dremel and a few minutes would probably make it fit,
Offline Pine Ridge
Re: Guide bars??
« Reply #8 on: November 13, 2019, 06:21:54 PM »
It was also mentioned about making a different angle for the oil hole, using a dremel tool and a flat file the guy said he could finish the entire job in about 10 minutes.
clearing guide bars and bow bars
Started by SPIKER on General Board
Last post January 17, 2007, 11:07:02 PM
by Brad_S.
guide bars
Started by 421Altered on Chainsaws
Last post November 28, 2019, 10:49:31 AM
by 421Altered
Stihl Guide Bars
Started by mpuste on Chainsaws
Last post December 17, 2010, 02:51:43 PM
by stump farmer
sugihara guide bars
Started by ga jones on Chainsaws
Last post January 03, 2011, 12:55:17 PM
by weimedog
