Author Topic: Can you use calking glue to glue logs together?  (Read 1465 times)
Offline Rod
« on: February 27, 2005, 08:06:19 PM »
I was thinking of building a log home out of some 8''X8'' Hemlocks and puting a 2''X 6'' in between them
I was thinking that would work better then nailing them because the glue wouldn't hold the logs apart like the nailes would.
It seems like it would work.I've used the contrustion glue before and it seems like it holds better then nails do.
Offline Jim_Rogers
  • Board Moderator
  • Keep your chisels sharp.
    • jrsawmill.com
Re: Can you use calking glue to glue logs together?
« Reply #1 on: February 28, 2005, 08:40:37 AM »
I'm not a log builder.
But, I think there are some drying, shrinkage and settling issues that will have to be addressed for your system to work.
Jim Rogers
Offline Rod
« Reply #2 on: February 28, 2005, 10:45:59 AM »
I agree Jim.I found this glue and I wonder if anyone has every used it?
http://www.loghome.org/stacknseal.html
Glue
Started by Tom Sawyer on Sawmills and Milling
Last post July 08, 2007, 11:30:21 PM
by LT40HDD51
Which glue?
Started by Brad_bb on General Woodworking
Last post January 01, 2012, 08:34:09 AM
by SwampDonkey
Glue up
Started by stumpy on General Woodworking
Last post May 15, 2019, 02:08:17 PM
by Larry
glue
Started by Dan_Shade on General Woodworking
Last post October 04, 2012, 09:41:13 AM
by Dodgy Loner
