ANNUAL CHRISTMAS CONTEST!
1) There's a bolt sticking up on the end adjustable blade guide above the wheel itself: It's drilled and tapped into the square stock with a jamb nut, and for the life of me, I can't figure out what it does. Any ideas?
Quote from: Hoopty5.0 on September 13, 2019, 08:45:02 AM1) There's a bolt sticking up on the end adjustable blade guide above the wheel itself: It's drilled and tapped into the square stock with a jamb nut, and for the life of me, I can't figure out what it does. Any ideas?That is for height adjustment on the blade guide. Their is a small chunk of 1/2" square stock that will need to get drilled and tapped 1/2x13 goes on the bolt for the guide the small vertical bolt you are talking about pushes on it.That piece of angle is only supposed to be on the adjustable side. the fixed side uses 3/4" holes drilled to make it adjustable. The adjust ability that is gained by using 3/4" holes works but is not what I would have done. It is a pain to adjust, but once adjusted it stays pretty good. I think the cam bolts help alot for that.
Looking good. at least you didn't do what I did on mine. I built them with the rollers on the wrong side. Didn't guide the blade very well at all. but looked kool
Well, THAT has to feel good!? Congrats!
That looks like your pushing your blade through the cut instead of pulling? You may want to reconsider that. On the smaller pieces it won't be an issue but you get into a big heavy or sticky log and you will have issues.My Linn build has the engine on top of the sawframe running the other direction.
Started by richhiway on Sawmills and Milling
Started by ButchC on Drying and Processing
Started by DR_Buck on Sawmills and Milling
Started by firefighter ontheside on Sawmills and Milling
