Author Topic: LT15 Clamp upgrade  (Read 754 times)
Offline firefighter ontheside
  • I like trees.
LT15 Clamp upgrade
« on: August 30, 2019, 12:06:42 PM »
I ordered the new style of clamp yesterday for my mill.  They are arriving today, which is impressive.  Well done WM.  Do they come with instructions for installing on different versions of the mill?  I have the cross members that are C channel.  Presumably Ill just be drilling a few 3/8 or similar holes and be in business.  Thanks for any insight.
Woodmizer LT15
Kubota Grand L4200
Stihl 025 and MS291
2017 F350 Diesel 4WD
Kawasaki Mule 4010
Offline offrink
Re: LT15 Clamp upgrade
« Reply #1 on: December 16, 2019, 09:17:15 PM »
How do you like the upgrade? Any photos in use?
  • I like trees.
« Reply #2 on: December 17, 2019, 10:01:28 PM »
Ultimately Im very happy that I added them, but the clamps have their pluses and minuses.  The original clamps raise straight up and down, while these have to raise in an arc.  The problem with that is that I had to mount them on opposite sides of crossmembers, so as I lower them, they get closer to each other.  I moved one of the old ones to the far end of the mill, so now I often use one new one and one old one.  All in all its been an upgrade to the mill.
Woodmizer LT15
Kubota Grand L4200
Stihl 025 and MS291
Kawasaki Mule 4010
Offline booman
« Reply #3 on: February 01, 2020, 07:36:16 PM »
I have both on my LT15Wide but most of the time I use the straight up and down style.  The only problem I have with the newer style is that if you bump the log they fall down.  Not so with the old style.
2019 LT15G25WIDE, 2013 LT35HDG25, Stihl MS880 with 59" bar with Alaskan sawmill attachment.  John Deere 5045 tractor with forks, bucket and grapple.  Many chainsaws.
Offline Woodpecker52
« Reply #4 on: February 01, 2020, 08:00:38 PM »
I had to drill a hole through the screw and the end cap so it would not come off, used a small bolt to hold together.  I tired of the end coming off all the time.  Another gripe is that sawdust will get between the iron pipe and the body ring which can make moving the dog back and forth a pain, have to keep coated with ATF and blow out with air hose.  I do like how it lies across the secondary cross member, that way it can be slid up against and hold a cant in place without rising above the small  side square stops, the slit in the end cap is perfect for holding even a flat lying board etc.  I am thinking of buying an extra one  to install for longer logs.  The main problem with the arch is that in a rare circumstance the cant can lift because the dog is not being held down  vertically..  This always occurs when I am doing something stupid like cutting a rectangle with small end down and long end up.  I stopped that bad habit.
Woodmizer LT-15, Ross Pony #1 planner, Ford 2600 tractor, Stihl chainsaws, Kubota rtv900 Kubota L3830F tractor
Offline Kindlinmaker
« Reply #5 on: February 02, 2020, 02:57:00 PM »
I added the new design to my mill when they first came out. After a couple years, I removed the original clamps and cant think of a time Ive missed them. My only complaint is the ends falling off the clamps; wish they had some type of a snap ring to hold them on.
Ive experienced the log lift ocassionally on the first cut of small logs that werent braced properly or when using poor sawing technique.  I dont think the original clamps would have stopped this; I think the logs would have just popped out of the clamp and the log would have ended up on top of the clamp.  I generally cut large diameter logs so this is not a serious issue for me.
looking for extra log clamp for lt15
Started by forrestM on Wanted
Last post January 21, 2019, 11:36:37 PM
by forrestM
LT15 clamp problem
Started by whitepe on Sawmills and Milling
Last post September 25, 2004, 11:01:09 AM
by Plowboy
Upgrade to LT15
Started by JBS 181 on Sawmills and Milling
Last post January 10, 2018, 12:48:16 PM
by alanh
Reasonable sawmill upgrade progression: LT15-35-40WIDE
Started by seaview on Sawmills and Milling
Last post February 23, 2019, 07:19:53 PM
by Stephen1
