Author Topic: New to me mill  (Read 1431 times)
Offline Cjross73
  • Work in progress
New to me mill
« on: August 30, 2019, 01:30:58 PM »
I officially have the sawdust bug, just brought home my first mill. 1996 WM LT40HD24, needs a little work to get it going but excited to get started would be an understatement.
LT40, Stihl saw, Old green tractor
Offline donbj
Re: New to me mill
« Reply #1 on: August 30, 2019, 01:47:25 PM »
Looks great! Looks just like my '94 Lt40HD minus the seat. I bought mine brand new back in the day and it still runs great with the 24hp Onan. Nice machines, enjoy!
Woodmizer LT40HDG24. John Deere 5300 4WD with Loader/Forks. Husky 262xp. Jonsered 2065
Offline A-z farmer
  • Still learning
Re: New to me mill
« Reply #2 on: August 30, 2019, 01:48:40 PM »
Cjross73
Congratulations on your woodmizer.
Did you get the manuals with it ?
You will bee making sawdust in no time .
Zeke
Offline CCCLLC
  • It's not to big, load it!
    • Carolina Custom Cut
Re: New to me mill
« Reply #3 on: August 30, 2019, 02:20:50 PM »
Looks like you may be making some siding or shakes as well. Good job.
Offline Cjross73
  • Work in progress
Re: New to me mill
« Reply #4 on: August 30, 2019, 04:17:51 PM »
Thanks everyone, I'm looking forward to learning everything. I did get the manuals, shingle attachment, seat, debarked and an offer to help me get started once I get it going. Just under 1600 hrs on it. It's been sitting for about a year under shelter. Fuel lines are rock hard and I'm sure the carb will need soaked but otherwise I think I've got a nice mill
Chuck
Offline SawyerTed
  • Summey Lumber Services, LLC
Re: New to me mill
« Reply #5 on: August 30, 2019, 04:58:49 PM »
Good for you!  Looks like a great machine.
Just a word of advice on getting started.  If you dont have much experience, practice on low value logs - pine or poplar are good choices.  Resist the temptation to put that walnut or cherry youve been saving on the mill first thing. Wait until you have a few hundred board feet of experience sawing lower value logs. Weve heard sad stories of the new guy trying to saw something really nice and he makes designer firewood (a borrowed term for boards that come off the mill and go to the firewood pile).
Woodmizer LT35HD25, Kubota MX5100, IH McCormick Farmall 140, Granberg Alaskan Chainsaw Mill, Husqvarna 372XP, Husqvarna 455 Rancher, Ram 3500 6.7 Cummins
Offline RAYAR
  • Retired May 2/19 more time to play with my mill
Re: New to me mill
« Reply #6 on: August 30, 2019, 05:25:29 PM »
Nice mill Chuck, I'm sure you'll have it going in no time.
mobile manual mill (local build) (mods & additions on-going)
Shop built auto band sharpener
Husqvarna 50, 61, 254XP (and others)
96 Polaris Sportsman 500
2006 Ranger 4X2 w/cap, manual trans
Offline Bruno of NH
Re: New to me mill
« Reply #7 on: August 30, 2019, 06:48:24 PM »
Nice mill
Congrats on your new adventure
Lt 40 wide with 38hp gas and command controls Riehl Steel edger,F350 4x4 dump and lot of contracting tools
Offline Cjross73
  • Work in progress
Re: New to me mill
« Reply #8 on: August 30, 2019, 07:53:20 PM »
Thanks guys, I'm sure I'll have a lot of questions as I get going.
Good advice Ted, I have some logs to practice on before I get into the good wood
Offline Poquo
Re: New to me mill
« Reply #9 on: August 30, 2019, 08:59:50 PM »
Congrats on your first mill . I got my first mill a week ago , the first thing I did was forget to tension the blade , it don't turn very long when you do that .
2015 Woodmizer LT40HD26
Offline Haleiwa
  • Clinton county, New York
Re: New to me mill
« Reply #10 on: August 30, 2019, 09:13:24 PM »
Practicing on low value logs is good advice, but try to find a few straight ones.  Dealing with a lot of sweep or crotch is a challenge of its own.  Start with a fairly short (eight feet or so) straight log that won't tax your mill to its maximum capacity.  The first few passes, you will feel like there are too many things to keep track of at once, so the less distractions the better.  Go ahead and hit the clamp or backstops; that way you will have it over with and can get on with sawing.
Socialism is people pretending to work while the government pretends to pay them.  Mike Huckabee
Offline Southside
Re: New to me mill
« Reply #11 on: August 30, 2019, 09:34:23 PM »
Just another thing - if you can find that pine log with a centered pith it would be a lot easier to start with.  Plantation pine can have a lot of stress in it and make a 6" cant curl 3/4" up off of the mill deck - poplar can be even worse at times.  So try to work with something as vanilla as possible at first.  Got any cedar lying around?
Offline SawyerTed
Re: New to me mill
« Reply #12 on: August 30, 2019, 09:41:06 PM »
And of sufficient diameter - 12 to 16" in diameter.  Big enough to use the hydraulics but not too big.
Offline Andries
  • Making buildings out of big curvy logs
Re: New to me mill
« Reply #13 on: August 31, 2019, 12:29:41 PM »
Well done on the mill.
I've loved my LT30 - its paid for itself a few times over since I bought it.
The Onan is a strong motor - and a bit "unusual" in design.
Do a search here on the Forum and you'll be up to speed in no time.
LT30G24, LT40G25
Ford 545 Series loaders
Stihl chainsaws
Offline Cjross73
  • Work in progress
Re: New to me mill
« Reply #14 on: September 08, 2019, 05:19:19 PM »
I've got the Mill running good, everything working well. I was about to cut up a practice log and saw the blade tension loose, pressure at 0. A little checking and found the plug in the bottom of the blade tensioner had come out. No chance of finding that tiny little plug in the grass so saw dust waits another day....
Offline terrifictimbersllc
    • Terrific Timbers LLC
Re: New to me mill
« Reply #15 on: September 08, 2019, 06:34:08 PM »
One of those round magnets on a stick from HF, or a wand metal detector, if the mill was in one place when it came out (??).
DJ Hoover, Terrific Timbers LLC,  Mystic CT Woodmizer Million Board Foot Club member. 2019 LT70 Super Wide,  Logrite fetching arch, WM BMS250 sharpener/BMT250 setter.  2001 F350 7.3L PSD 6 spd manual ZF 4x4 Crew Cab Long Bed
Offline Cjross73
  • Work in progress
Re: New to me mill
« Reply #16 on: September 08, 2019, 08:02:26 PM »
I had the metal detector out and a magnet, the mill was in one place but it's a tiny plug in the grass so I didn't have any luck
Offline Cjross73
  • Work in progress
Re: New to me mill
« Reply #17 on: September 09, 2019, 03:43:18 PM »
The learning curve continues... I got the tensioner cleaned up this afternoon and realized it wasn't a plug hole, ordered the cylinder rebuild kit.
Offline Woodpecker52
Re: New to me mill
« Reply #18 on: September 09, 2019, 03:55:23 PM »
Its not so much the adventure of cutting wood as it is the fun of mechanical innovation and trouble shooting, head scratching and cursing!!
Woodmizer LT-15, Ross Pony #1 planner, Ford 2600 tractor, Stihl chainsaws, Kubota rtv900 Kubota L3830F tractor
Offline SawyerTed
Re: New to me mill
« Reply #19 on: September 09, 2019, 04:57:28 PM »
Chalk it up to experience and learning.  At least it isn't in the "I did something dumb today" thread, YET!  :D
