Author Topic: Should I let it dry more  (Read 288 times)
Offline NewSprout008
  • Member*
« on: August 31, 2019, 05:33:09 PM »
Ive recently acquired some ash logs & stump slices. The tree was dropped about 4-5 months ago. Ive got some pieces 8-12 thick and some others thicker(taller).
Id like to start squaring them up with a router sled but perhaps I should wait. Currently, all end grains are sealed. My friend is a bowl turner and gave me a full gallon.
Where can I add a photo?
If that would help....
Offline scsmith42
    • Whispering Pines Farm
Re: Should I let it dry more
« Reply #1 on: August 31, 2019, 11:37:27 PM »
Welcome to the Forestry Forum.  When  you get a chance, please make an introductory post.
If you have applied end sealer to your rounds, they are not drying.  Bowl turners totally encapsulate blanks in end sealer so as to keep them green until turned.
When working with rounds or boards, the goal is to have them dry - not keep them green.
Ash shrinks almost 8% tangentially as it dries; accordingly it is difficult to dry w/o having it crack.  There are some products available (namely Pentacryl) that will help prevent cracking, but it is somewhat expensive.
There are other tricks such as stress relieving the bottom side of the round to give the wood cells more room to shrink.
If I were you I'd use your router sled to clean up the ends and get rid of the end sealer. Then go from there.
Tom's 3638D Baker band mill
