Author Topic: Which size cant hooks are needed with a hydraulic mill? Hookaroons, too?  (Read 1191 times)
Offline KenMac
  • I'm new, but don't feel so new!
As the title states, what does one need with a hydraulic mill? ::)
Cook's AC3667t, Cat Claw sharpener, Dual tooth setter, and Band Roller, Kubota B26 TLB
Online WV Sawmiller
    • Green's Sawmill Services
Re: Which size cant hooks are needed with a hydraulic mill? Hookaroons, too?
« Reply #1 on: September 09, 2019, 05:50:57 PM »
    What size logs are you rolling? I use a 60" Logrite. I sometimes also use my Magic Hook made from an old cant hook and a piece of 1/4" chain which I drive into the log and then hook to the movable clamp on my mill. This gives me about 2' of hydraulic assist to roll a log which is often enough to roll the log past the center of balance enough to roll it on to the loading arms. Remember - you can move a small log with an oversized cant hook a lot easier than you can move a big log with an undersized cant hook. And a pair of cant good Logrite cant hooks allows someone else to help you for those big logs. JM2˘.
Offline doc henderson
« Reply #2 on: September 09, 2019, 06:41:22 PM »
I have a timberking b2000, hydraulic mill.  it came with a Logrite cant, that I have never needed, and i just bought a pickaroon from Logrite to use for my firewood logs, mostly to pull them down the staging table.  get started and see what you are missing.  i have a skid steer to assist as well,
Online Dan_Shade
  • I don't want to edit my profile!
    • Shade Custom Sawing
« Reply #3 on: September 09, 2019, 08:07:53 PM »
I like that 60" peavey.  I stick one in the ground at each end of the log pile.
The 48" is a bit too short for my preference.
lots of dull bands and chains
Offline WDH
  • Forester
  • April 1998 - August 2008
    • hamsleyhardwood.com
« Reply #4 on: September 09, 2019, 08:44:58 PM »
60".  You will use it most.
Offline KenMac
« Reply #5 on: September 09, 2019, 09:22:22 PM »
That's kinda what I was thinking. I got a 60" one with my mill from Cook's, but it is very heavy. I think a 60" Logrite and a 30" Hookaroon will help a lot. I'll use the hookaroon to guide boards on the drag back when needed. I really don't have to manhandle logs much, but I do like to have good tools for the job at hand. Do y'all see any reason to get the heavy duty cant hooks or are the standard ones from Logrite strong enough?
Online WV Sawmiller
« Reply #6 on: September 09, 2019, 09:30:49 PM »
   Get the heavy duty one. Then when you cut a heavy tree on it, it is harder to bend. Don't ask me how I found out. :D
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
« Reply #7 on: September 09, 2019, 09:39:35 PM »
My vote goes to the 60" first, but don't let it end there.
Offline btulloh
« Reply #8 on: September 09, 2019, 09:51:24 PM »
My vote is for the 60”
On the hookaroon, I like it to be just long enough that the business end is about 2” off the ground when I hold it by my side and let it just hang naturally. That makes it real easy to back hand firewood splits.  Sawmill uses seem to Workout fine at that length.
Offline DPatton
    • D & S Sawmill Services
« Reply #9 on: September 09, 2019, 10:19:47 PM »
The 60” Logrite is what I have and use. I wouldn’t want anything less.
Offline Nebraska
  • I'm new! Lurked for quite a while, learning !
« Reply #10 on: September 09, 2019, 10:53:38 PM »
This could go under the I did something dumb thread, but...... before.. I bought my mill I bought an off brand wooden handled 48" awkward clunky can't hook.. I admit  it....Don't try and save money,  buy good chainsaws, support equipment etc.
That being said I've been fairly good this year and I'm hoping Mrs Claus will put a 60 inch Logrite under the Christmas tree this winter,  then the clunker will be retired to guest use status. Have fun with the mill best wishes on the adventure..
Offline Banjo picker
« Reply #11 on: September 10, 2019, 06:19:32 AM »
All of you bragging on those 60's make me want one, and I have made it fine for over 10 years with two mill specials.  I like the base ball bat handle.  Mine are longer than the one Magic man showed.  They will spin a good sized log.
Might not have to lean on it so hard with a 60.  Banjo
Offline Chuck White
  • Sawing Mobile since 2005
« Reply #12 on: September 10, 2019, 06:33:01 AM »
I have a 48" Logrite cant hook and a few of the old wooden handled cant hooks and a really old pickaroon!
I've seen a few times when it would have been nice to have a 60" hook.
I really like the Logrite hook, it's just that the handle is a little large for my liking, but it works and works well!
~Chuck~
Retired USAF 1989, Retired School Bus Driver 2012, now semi-retired Mobile Sawyer
1995 Wood-Mizer LT40HDG25 Kohler - Shingle & LapSider, Cooks Cat Claw Sharpener and single-tooth setter, 4-foot Logrite cant hook.
Online Old Greenhorn
« Reply #13 on: September 10, 2019, 08:29:14 AM »
I have two hookeroons, one is short like btulloh mentioned and is used exclusively for firewood wood as Doc said. The other is about 30" and i find it very handy for dragging smaller logs when I am bucking in the woods and also grabbing a log to roll toward me or dragging heavy filtches out of the way.. Useless on big stuff though. I rarely use either around the mill, but I have seen production operations where the tailgunner uses one to get hold of the board to pull it off. I don't like the idea of marking up the wood like that.
 On cant hooks, I think you already have enough opinions to reach a decision. Figure out what you need to do, then get what works best for you.
Oscar 328 Band Mill, Husky 450, 372 (Clone), Mule 3010, and too many hand tools. :) I mill for fun and my mental health. NYLT Certified.
I ain't the woodcutter, but I can cut wood 'til the woodcutter gets here. OK, maybe I am the woodcutter now.
I can work with wood, but I am NOT a Woodworker
Offline SawyerTed
  • Summey Lumber Services, LLC
« Reply #14 on: September 10, 2019, 10:29:49 AM »
I have two 48" cant hooks, one Woodmizer and one Logrite.  I prefer the Logrite because it is lighter.  I wish I'd bought 60" ones to start and I need to add a shorter one for use on the mill to turn ornery cants the hydraulics  don't turn well.
Woodmizer LT35HD25, Kubota MX5100, IH McCormick Farmall 140, Granberg Alaskan Chainsaw Mill, Husqvarna 372XP, Husqvarna 455 Rancher, Ram 3500 6.7 Cummins
Online WV Sawmiller
« Reply #15 on: September 10, 2019, 10:43:51 AM »
   I have a good (although handle has been customized slightly by a 1600 bf poplar tree as mentioned above) 60" Logrite and an old woodenhandled cant hook that stays at the front of the mill to turn small cants that are faster to turn by hand than with the hydraulics. One of these days I will hit the lottery or otherwise come into some spare cash and I will buy me a 78" Logrite megahook for those big sweepy logs I some times encounter. Then I will be set for life.
Offline Larry
« Reply #16 on: September 10, 2019, 11:38:19 AM »
Anything a 60" hook can do, can be done with a 78" Megahook faster, and easier.  It will also roll logs a 60" only dreams about.
I keep a 48" right at my console for help with cranky logs on the mill.  The 60" has an easy life doing very little.  The Megahook gets most of the work.
A little trivia.....I think the Megahook began life as the ASS (Arky Super Stick) named after a past member.
Offline redbeard
    • whidbeysawmill.comwww.whidbeysawmill.com
« Reply #17 on: September 10, 2019, 12:08:43 PM »
Have needed the 60" Logrite several times adjusting the bigger logs especially when you don't get square arms up quick enough and log role back too loader arms.
The 78" would make life alot easier!
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
« Reply #18 on: September 10, 2019, 02:00:34 PM »
Remember that the 48", 60", & 78" all have different sized hooks.  The 48" is designed to handle 8"-32" logs, the 60" is designed to handle 10"-36" logs, and the 78" is designed to handle 15"-45" logs.
I have tried to roll smaller logs with the 60" and the hook was too long, and I have tried to roll larger logs with the 48" and the hook simple would not open wide enough to bite.  I have no experience with the 78".
Offline WDH
  • Forester
« Reply #19 on: September 10, 2019, 08:39:37 PM »
I have a mill special (Thanks Mr. Goat), a 60" canthook, and a 78" megahook.  I use the 60" the most, but there are times that I would be up the creek without a paddle (old saying) if I did not have the megahook.  It is essential for those big nasty misshapen logs.
Size Of Mill Needed
Started by car on Sawmills and Milling
Last post April 23, 2006, 11:57:29 AM
by twoodward15
How many horse power is needed for X size mill?
Started by Modat22 on Sawmills and Milling
Last post November 09, 2005, 07:46:10 PM
by wiam
Hydraulic De-barker motor size?
Started by Cutting Edge on Sawmills and Milling
Last post July 22, 2012, 10:32:03 PM
by Cutting Edge
Milling For Future. Not Sure of Needed Size
Started by catvet on Sawmills and Milling
Last post June 20, 2008, 10:09:44 PM
by WDH
