Author Topic: Used Wood-Mizer info -help needed.  (Read 579 times)
Offline Rainwolf
« on: September 10, 2019, 10:10:52 PM »
I have a chance to buy a older Wood-Mizer. Based on what I was told it has been sitting for 11 years and ran when they stopped using it. Other then obvious rust issues and the engine possibly needing work what things should I look for before I commit to buying it? I believe it is a LT15 based on what cut and track size was given to me. Iíll be going tomorrow to view it.
Any help will be appreciated as this will be my first sawmill.
Offline Woodpecker52
Re: Used Wood-Mizer info -help needed.
« Reply #1 on: September 10, 2019, 10:41:11 PM »
Know what new sells for and remind them this ain't new and needs a lot of work.
Woodmizer LT-15, Ross Pony #1 planner, Ford 2600 tractor, Stihl chainsaws, Kubota rtv900 Kubota L3830F tractor
Offline Rainwolf
« Reply #2 on: September 10, 2019, 10:44:09 PM »
The asking price is around $1000
I figured even with a new engine thatís a fair price if all else is good. But I donít know what hidden things that would just make it a yard ornament.
Offline firefighter ontheside
  • I like trees.
« Reply #3 on: September 10, 2019, 10:47:40 PM »
LT15 is a pretty simple machine.  I think rusty things will be the biggest problem.  Rusty bearings, rusty track, rusty blade rollers.  Those wonít be too difficult to remedy though.  Replace some parts that may be frozen.  Get the motor running or replace it.  Make sure price reflects things that have to be replaced.
Woodmizer LT15
Kubota Grand L4200
Stihl 025 and MS291
2017 F350 Diesel 4WD
Offline Peter Drouin
    • A&P Saw mill LLC
« Reply #4 on: September 11, 2019, 07:07:04 AM »
A new motor I think you will have $800 to a 1000 into it with the rust an all you might have 3000 into it for it to cut good. Then all your work to fix it up.
Not looking at it my self I'm just thinking of the worse.
A&P saw Mill LLC.
License NH softwood grader.
Offline Rainwolf
« Reply #5 on: September 11, 2019, 07:20:05 AM »
So would at worse case (no obvious rust damage to bed/or motor carriage) would  it be worth $1k? Iíll have photos later today to post.
Offline GAB
« Reply #6 on: September 11, 2019, 10:32:42 AM »
At that price I would not go look at it, I would bring a trailer and pick it up.
The track sections are probably worth that much.
GAB
Offline Chuck White
  • Sawing Mobile since 2005
« Reply #7 on: September 11, 2019, 02:02:30 PM »
X2 what GAB said!
For $1,000 plus some elbow grease, touch-up paint, and might get lucky and have a running engine!  8)
~Chuck~
1995 Wood-Mizer LT40HDG25 Kohler - Shingle & LapSider, Cooks Cat Claw Sharpener and single-tooth setter, 4-foot Logrite cant hook.
Offline Rainwolf
« Reply #8 on: September 11, 2019, 03:18:59 PM »
Thatís what Iím hoping for, the main issue is this is a remote Alaska location (remote as everything has to fly or barge in) so my normal worry with anything metal here is rust in a marine environment. Second worry is cost, so as long as the tracks and carriage are sound metal Iím pretty sure Iíll be hauling it away :)
Offline Rainwolf
« Reply #9 on: September 12, 2019, 05:26:45 PM »
The seller is flaking out on me :(
Hoping he calls today or tomorrow for the visual check and possible purchase. Iíll post once I have photos
New at sawing with a wood mizer. NEED INFO PLEASE
Started by Larrywoodsaw on Sawmills and Milling
Last post May 06, 2013, 08:50:38 PM
by drobertson
Wood Mizer 12' extension needed.
Started by Dave Shepard on Wanted
Last post February 06, 2008, 07:32:49 PM
by Dave Shepard
help needed wood mizer lt40 acuset
Started by rl on Sawmills and Milling
Last post June 10, 2006, 02:25:41 PM
by rl
Sharpening and Setting (Helpful info from "Wood-Mizer" Tech support)
Started by Cutting Edge on Sawmills and Milling
Last post May 11, 2012, 02:47:51 PM
by Cutting Edge
