Dynamic Green Products Inc.
Author Topic: Building a walnut door  (Read 3943 times)
Online tule peak timber
  • The Wizard of Crap
    • tule peak timber
« on: September 15, 2019, 04:54:28 PM »
I started a couple weeks ago as the wood came out of the kiln.This project will be several  more months in fabrication as some of the thicker pieces still showed internal moisture. The walnut is orchard (grafted) wood I brought in this last spring.
  The door will measure 132 inches tall 51 inches wide including an arched transom/jamb assembly.  With 3 inch thick frame, 4-5 inch thick burl raised panels - sheer weight is the main challenge. Lots of hollow form layups in the design and engineering on this build.The customer also has a massive kitchen island in the works.
 Note the tree graft that will be the center of the transom.
 After a great deal of template router work and lamination of opposing grains for stability the layup is ready for carving today prior to assembly. Careful attention is paid to have all of these big parts floating after fabrication. Rob
Online Southside
    • White Oak Meadows
Re: Building a walnut door
« Reply #1 on: September 15, 2019, 05:16:58 PM »
WOW Rob - that is impressive!!
White Oak Meadows
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
« Reply #2 on: September 15, 2019, 06:24:49 PM »
Wow, this will be interesting to follow.  Thank You for including us as you progress.  :P
Offline thecfarm
« Reply #3 on: September 15, 2019, 06:48:23 PM »
You are one cleaver fellow to make that all work.
Offline Brad_bb
« Reply #4 on: September 15, 2019, 08:08:16 PM »
Yes, you always seem to be doing the coolest stuff.  Is there a drawing of the door to help me visualize?
Offline Poquo
« Reply #5 on: September 15, 2019, 08:18:31 PM »
That's amazing can't wait to see finished product!
2015 Woodmizer LT40HD26
    • tule peak timber
« Reply #6 on: September 15, 2019, 08:25:25 PM »
my drawing that I'm working from. I like to keep it simple !
Offline ljohnsaw
« Reply #7 on: September 15, 2019, 09:01:58 PM »
 :P
So just a "small" 11' tall door... I this the front door?  Pantry? Kitchen?
John Sawicky
    • tule peak timber
« Reply #8 on: September 15, 2019, 09:10:24 PM »
Yes an entry door + jamb, new construction.
Offline Brad_bb
« Reply #9 on: September 15, 2019, 11:17:59 PM »
well, your assembly table looks big enough!
Online Texas Ranger
  • Texan, by God and by choice.
« Reply #10 on: September 16, 2019, 11:05:41 AM »
Out standing, I used to build doors, but nothing of that order.
Offline Bill Gaiche
  • Home built bandsaw, Kioti DK4510. Sthil 211&361
« Reply #11 on: September 18, 2019, 09:20:19 AM »
Simple?? Man oh man, the things you build. Awesome.......bg
    • tule peak timber
« Reply #12 on: September 20, 2019, 07:13:08 PM »
Progress today on sculpting the transom panels and jointing the transom round to the head. Going from round to straight is very tricky........ :) The parts are cut so I can work through the weekend for a dry fit.
Offline Dakota
  • Swing'en in South Dakota
« Reply #13 on: September 21, 2019, 12:11:40 PM »
I drool every time I see your shop equipment.  Love seeing your projects.
Dave Rinker
    • tule peak timber
« Reply #14 on: September 21, 2019, 01:15:14 PM »
I was very disappointed that Costner shut down his casino. Is the old lady holdout still running the hardware store ?
Offline Dakota
« Reply #15 on: September 22, 2019, 09:47:21 AM »
I haven't been there in a year or so.  I trade mostly at the Twin Cities Hardware store between Deadwood and Lead on highway 385.
Dave Rinker
Offline Bruno of NH
« Reply #16 on: September 22, 2019, 12:37:31 PM »
Following
You are the truest of craftsman  :)
Lt 40 wide with 38hp gas and command controls Riehl Steel edger,F350 4x4 dump and lot of contracting tools
    • tule peak timber
« Reply #17 on: October 03, 2019, 07:53:00 PM »
I kicked the guys out of the shop to get some sunshine today. Coastal live oak.
    • tule peak timber
« Reply #18 on: October 18, 2019, 01:58:10 PM »
Back building on the door this morning.Template cutting of the burl faces for the raised panels.
    • tule peak timber
« Reply #19 on: October 18, 2019, 07:24:13 PM »
Finished sanding and oiled the transom this afternoon . I tried to show in the pics the 3-D wobble on the raised panels. Tree graft in the center.
Door building
Started by fishfighter on Timber Framing/Log construction
Last post September 28, 2016, 04:55:49 PM
by fishfighter
Building an exterior door with frame
Started by sbishop on General Woodworking
Last post July 10, 2009, 10:37:29 AM
by sbishop
Building a door jamb - 36" exterior
Started by tyb525 on General Woodworking
Last post April 01, 2012, 12:36:47 AM
by Handy Andy
Building a Walnut Table
Started by WDH on General Woodworking
Last post December 23, 2008, 04:43:55 PM
by metalspinner
