Dynamic Green Products Inc.
Author Topic: Do you use sawdust in woodworking?  (Read 1045 times)
Offline ponderosae
« on: September 16, 2019, 05:05:59 PM »
I see that there are a lot of topics here about what to do with lots of sawdust from milling. As far as what to do with a little bit, I watched a video about furniture restoration, where sawdust was being added to the glue, in order to make staining it look better. Maybe it would be good for filling holes in wood, so less glue or other filler would have to be used.
Offline doc henderson
Re: Do you use sawdust in woodworking?
« Reply #1 on: September 16, 2019, 05:46:08 PM »
i know a doc with an off grid cabin, and he takes mine to use for his low tech composting cabin toilet.  only # 2 into a 5 gallon bucket, then cover with sawdust.  dump when full. rinse and repeat!  the saw dust i use for filler is from fine sanding, and many will add glue to the crack and then just sand over it, with the wet glue in the imperfection. 8)
Offline ponderosae
« Reply #2 on: September 16, 2019, 06:12:25 PM »
Well, I don't think I'd want to add glue to that crack...
« Reply #3 on: September 16, 2019, 06:36:35 PM »
 :D :D :D :D :o :o :o 8) :) :) :)
Offline firefighter ontheside
  • I like trees.
« Reply #4 on: September 16, 2019, 08:04:40 PM »
I will take fine dust out of my orbital sander bag to mix with glue to fill cracks on woodwork.  We are talking about a minute amount.
Woodmizer LT15
Kubota Grand L4200
Stihl 025 and MS291
2017 F350 Diesel 4WD
Kawasaki Mule 4010
Offline ponderosae
« Reply #5 on: September 16, 2019, 09:11:13 PM »
Ah, maybe I'll try using more sawdust though, mixed with construction adhesive, next time I fill a dead knot hole.  I've used that by itself and it works, but doesn't look like wood.
Offline hackberry jake
« Reply #6 on: September 16, 2019, 09:48:24 PM »
I've had people come and get my planer/jointer shavings for all kinds of things. Hog bedding, leveling underneath above ground pools, putting in horse stalls, mixing with lawn clippings to make compost. But most of it still just washes down the mountain when it rains. It came from nature. I guess it's ok if it returns.
Offline Southside
    • White Oak Meadows
« Reply #7 on: September 16, 2019, 09:49:08 PM »
 dump when full
I do the same thing Doc, but what does that have to do with wood working? :D
« Reply #8 on: September 16, 2019, 10:33:11 PM »
we were talking about his bucket, not your bowels!!!  @Southside .  Is your wife not watching you today?    :D :D :D
Offline Don P
    • Calculator Index
« Reply #9 on: September 16, 2019, 10:43:51 PM »
Mostly I use it to without glue to fill imperfections in my land.
It also works good in the bottom of the box with the baby chickens.
Offline Southside
    • White Oak Meadows
« Reply #10 on: September 16, 2019, 11:13:20 PM »
See - Chickens come up in the discussion @K-Guy and I had nothing to do with it!  :D  It's a space time continuum thing I tell ya!!  @doc henderson Nope - she is on the left coast for two weeks, nobody to keep me in check.   8)
Offline WDH
  • Forester
  • April 1998 - August 2008
    • hamsleyhardwood.com
« Reply #11 on: September 17, 2019, 07:58:12 AM »
Southside, don't forget to take your meds.
Woodmizer LT40HDD35, John Deere 2155, Kubota M5-111, Nyle L53 Dehumidification Kiln, and a passion for all things with leafs, twigs, and bark.  hamsleyhardwood.com
Offline Southside
    • White Oak Meadows
« Reply #12 on: September 17, 2019, 09:32:09 AM »
Thanks for the love Danny.  :D We sure don't want a repeat of THAT situation now do we?   :o  :D
Offline Nebraska
« Reply #13 on: September 17, 2019, 03:30:02 PM »
Chickens and crack in the same thread what is this place coming too. :o
Offline Cosmo52
« Reply #14 on: November 14, 2019, 11:11:05 PM »
I've never tried it but is supposed to work as a replacement for gravel in making concrete.  Looks like sawmill sawdust or maybe planer shavings would work
Offline samandothers
« Reply #15 on: November 15, 2019, 12:16:32 PM »
While it is not a large volume at a time it works as a good oil dry.  I'll give it to my neighbor at times to use in his shop under his lift.   it does a good job absorbing mechanical device droppings, not just animal droppings.
Offline JRHill
« Reply #16 on: November 15, 2019, 12:36:10 PM »
A neighbor has an off grid rental and he just came by for another load. Along with others who use the saw dust in pens, I told him to put a scoop or two into burlap and place several around his cabin. The fresh cut ponderosa fills the inside with a forest scent that people love.
It's not so good in a garden, etc. as the saw dust robs nitrogen from the soil as it degrades - at least that's what the extension service says.
But for me the real problem is small trimmings and partial slabs. We use as much as possible (doug fir) in the wood burning season for starting and in the evening when we're around to keep reloading. Can't use it in the fire pit for cooking unless swinging a covered pot.
Offline Don P
    • Calculator Index
« Reply #17 on: November 16, 2019, 07:39:48 AM »
It does tie up nitrogen as it breaks down but there is a very slight positive N overall and organic matter is good for soil tilth. We've put down cardboard in the walk paths in the garden and cover that with fresh sawdust to keep weeds down and make clean walkways. Then a year or two later that goes into the beds and repeat. There is a big pile at one end of the garden that I periodically refresh for that.
Has anyone built their own woodworking bench with woodworking vices?
Started by LaneC on General Woodworking
Last post May 25, 2015, 08:44:07 AM
by Phorester
New to woodworking.
Started by mattyboy88 on General Woodworking
Last post January 28, 2017, 10:47:07 PM
by mattyboy88
woodworking with an axe
Started by 123maxbars on General Woodworking
Last post January 05, 2018, 12:44:04 PM
by Weekend_Sawyer
woodworking get together
Started by thedeeredude on General Woodworking
Last post November 15, 2008, 09:40:53 PM
by Dodgy Loner
