Author Topic: lt-40 key switch  (Read 350 times)
Offline jmouton
  • never enough time
    • Log-Gistics
lt-40 key switch
« on: September 16, 2019, 08:49:34 PM »
so apparently if you leave the key switch on auxiliary , and forget about it for a week,  the battery goes dead ,  who knew :D :D,, so when its in travel mode with the head down it is a pain in the butt to get to the battery you cant get the cover off cuz the triangle part that goes underneath the top rail protector wont come out ,  not the best design ,,,,,  i know  before any of you say should nt leave the key on to begin with ,  , i was in a hurry and forgot ,  hopefully i learned my lesson ,   :D :D
        jim
lt-40 wide ,fiat tractor,bobcat,international flatbed,10 ton trailer, stihl 075,041,029,066,and a 2015 f-350,and a oldwheel loader ,grapple system coming soon!!
Offline donbj
Re: lt-40 key switch
« Reply #1 on: September 16, 2019, 09:50:47 PM »
Ha, don't worry about it, it's still a good design. Been there done that! I looked at your age and said ahh, now I know why it happened.
Woodmizer LT40HDG24. John Deere 5300 4WD with Loader/Forks. Husky 262xp. Jonsered 2065
Offline Dave Shepard
  • Geometrically proportional
    • My homepage
« Reply #2 on: September 16, 2019, 10:14:07 PM »
If you open the fuse box down near the battery box, you should find a hex shaped piece of steel in there that you can screw onto the lafthand solenoid lug to attach your jumper cable.
Offline terrifictimbersllc
    • Terrific Timbers LLC
« Reply #3 on: September 17, 2019, 01:45:17 AM »
You can charge it by putting a charger on the starter terminal big red wire post.
DJ Hoover, Terrific Timbers LLC,  Mystic CT Woodmizer Million Board Foot Club member. 2019 LT70 Super Wide,  LogRite fetching arch, WM BMS250 sharpener/BMT250 setter.  2001 F350 7.3L PSD 6 spd manual ZF 4x4 Crew Cab Long Bed
Offline Chuck White
  • Sawing Mobile since 2005
« Reply #4 on: September 17, 2019, 06:21:33 AM »
You can also charge or jump-start by hooking onto the positive wire (coming from the battery) on the alternator.
~Chuck~
Retired USAF 1989, Retired School Bus Driver 2012, now semi-retired Mobile Sawyer
1995 Wood-Mizer LT40HDG25 Kohler - Shingle & LapSider, Cooks Cat Claw Sharpener and single-tooth setter, 4-foot Logrite cant hook.
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
« Reply #5 on: September 17, 2019, 08:55:28 AM »
Actually I believe that it was designed that way to prevent/hinder the battery from being stolen.
Key switch
Started by Peter Drouin on Sawmills and Milling
Last post January 14, 2016, 09:10:31 PM
by Magicman
Going to switch i think
Started by furltech on Chainsaws
Last post July 16, 2014, 02:48:43 PM
by goose63
Lt 40 hyd switch
Started by CMI80 on Sawmills and Milling
Last post December 24, 2017, 07:15:26 PM
by CMI80
Planer switch
Started by flibob on General Woodworking
Last post May 24, 2010, 04:14:21 AM
by SwampDonkey
